[petsc-users] What exactly goes into DMPlexSetRefinementLimit
Matthew Knepley
knepley at gmail.com
Wed Aug 17 14:46:01 CDT 2016
On Wed, Aug 17, 2016 at 2:35 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Because the base mesh starts off with 6 elements and 8 vertices. This is
> enough data for one cell per MPI process. Refinement is done after
> DMPlexDistribute(...). If I use anymore than 6 cores, some of the MPI ranks
> will have an empty DM Object. For example:
You could
1) Just stick an explicit call to uniform refinement in for the serial mesh
2) Use a cell volume that is 1/N, where N is the number of cells you want
Matt
> $ mpirun -n 8 --bind-to-core --bysocket ./ex12 -dim 3 -run_type full
> -interpolate 1 -petscspace_order 1 -bc_type dirichlet -ksp_rtol 1.0e-7
> -pc_type ml -refinement_limit 1 -dm_refine 1 -dm_view
> DM Object: Parallel Mesh 8 MPI processes
> type: plex
> Parallel Mesh in 3 dimensions:
> 0-cells: 10 0 10 10 10 0 10 10
> 1-cells: 25 0 25 25 25 0 25 25
> 2-cells: 24 0 24 24 24 0 24 24
> 3-cells: 8 0 8 8 8 0 8 8
> Labels:
> marker: 1 strata of sizes (18)
> depth: 4 strata of sizes (10, 25, 24, 8)
> Number of SNES iterations = 1
> L_2 Error: 0.118178
> On Wed, Aug 17, 2016 at 2:28 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Aug 17, 2016 at 2:04 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> When I enter values like 1/16, 1/12, 1/24, and so on, I was expecting
>>> to get roughly the same dm object as if I simply did -dm_refine <0/1/2/3>.
>>> Instead it seems I get highly unstructured grids, and the smaller the
>>> number gets, the fewer additional cells I get. Is there a way to make the
>>> refinement limit uniform?
>> Why not just use -dm_refine ?
>> Matt
>>> On Wed, Aug 17, 2016 at 9:38 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Aug 17, 2016 at 5:23 AM, Justin Chang <jychang48 at gmail.com>
>>>> wrote:
>>>>> Hi all,
>>>>> Playing around with SNES ex12.c and I am attempting to tinker around
>>>>> with 3D options. I am trying to understand what kind of values go into
>>>>> -refinement_limit for 3D simplices.
>>>> The cell volume limits for any cells created out of the existing cells.
>>>> This is how TetGen understands refinement. I think a
>>>> better way is to use a metric tensor field, and we now have an
>>>> interface to pragmatic for this (I think currently I only hooked it up
>>>> to DMCoarsen() but it does both). Clearly the interface is immature,
>>>> but this is the way we are headed.
>>>> Matt
>>>>> Thanks,
>>>>> Justin
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160817/881ab7d4/attachment.html>
