[petsc-users] A question about DMPlexDistribute
leejearl
leejearl at 126.com
Tue Aug 16 20:48:19 CDT 2016
Thank you for your help. The problem has been overcome following your
advices.
Now, I give some notes for this problem which might be useful for others.
1. Up to now, we must use the code in the master branch. The source code
can be downloaded using git with:
git clone https://bitbucket.org/petsc/petsc petsc.
2. Just the other day, I download the code using git with: git clone -b
maint https://bitbucket.org/petsc/petsc petsc.
But, this copy of code still has such a problem. I am not sure
whether it is available now.
3. The code downloaded from website of PETSc(Version of 3.7.3) is not
available for this problem, although it is in the branch master.
Thanks for all helps again. Best wishes to you.
leejearl
On 2016年08月16日 19:34, Matthew Knepley wrote:
> On Mon, Aug 15, 2016 at 9:28 PM, leejearl <leejearl at 126.com
> <mailto:leejearl at 126.com>> wrote:
> Thank you for all your helps. I have tried and reinstalled PETSc
> lots of times. The error are still existed.
> I can not find out the reasons. Now, I give the some messages in
> this letter.
> 1> The source code is downloaded from the website of PETSc, and
> the version is 3.7.2.
> You will need to run in the 'master' branch, not the release since we
> have fixed some bugs. It is best to
> use master for very new features like this. The instructions are here:
> http://www.mcs.anl.gov/petsc/developers/index.html
> Thanks,
> Matt
> 2> Configure:
> >export PETSC_DIR=./
> >export PETSC_ARCH=arch
> >./configure --prefix=$HOME/Install/petsc
> --with-mpi-dir=/home/leejearl/Install/mpich_3.1.4/gnu
> --download-exodusii=../externalpackages/exodus-5.24.tar.bz2
> --download-netcdf=../externalpackages/netcdf-4.3.2.tar.gz
> --download-hdf5=../externalpackages/hdf5-1.8.12.tar.gz
> --download-metis=../externalpackages/git.metis.tar.gz
> --download-parmetis=yes
> 3> The process of installation has no error.
> 4> After the installation, I added the following statement into
> the file ~/.bashrc:
> export PETSC_ARCH=""
> export PETSC_DIR=$HOME/Install/pets/
> I wish to get some helps as follows:
> 1> Is there any problems in my installation?
> 2> Can any one help me a simple code in which the value of overlap
> used in DMPlexDistribute function is greater than 1.
> 3> I attach the code, makefile, grid and the error messages again,
> I hope some one can help me to figure out the problems.
> 3.1> code: cavity.c
> 3.2> makefile: makefile
> 3.3> grid: cavity.exo
> 3.4> error messages: error.dat
> It is very strange that there is no error message when I run
> it using "mpirun -n 3 ./cavity", but when I run it using "mpirun
> -n 2 ./cavity", the errors happed.
> The error messages are shown in the file error.dat.
> Any helps are appreciated.
> On 2016年08月13日 09:04, leejearl wrote:
>> Thank you for your reply. The source code I have used is from the
>> website of PETSc, not from the git repository.
>> I will have a test with the code from git repository.
>> leejearl
>> On 2016年08月13日 08:49, Oxberry, Geoffrey Malcolm wrote:
>>>> On Aug 12, 2016, at 5:41 PM, leejearl <leejearl at 126.com
>>>> Hi, Matt:
>>>> > Can you verify that you are running the master branch?
>>> cd ${PETSC_DIR}
>>> git branch
>>> The last command should return something like a list of branch
>>> names, and the branch name with an asterisk to the left of it
>>> will be the branch you are currently on.
>>> Geoff
>>>> I am not sure, how can I verify this?
>>>> And I configure PETSc with this command
>>>> "./configure --prefix=$HOME/Install/petsc-openmpi
>>>> --with-mpi=/home/leejearl/Install/openmpi/gnu/1.8.4
>>>> --download-exodusii=yes --download-netcdf
>>>> --with-hdf5-dir=/home/leejearl/Install/hdf5-1.8.14
>>>> --download-metis=yes".
>>>> Is there some problem? Can you show me your command for
>>>> configuring PETSc?
>>>> Thanks
>>>> leejearl
>>>> On 2016年08月13日 01:10, Matthew Knepley wrote:
>>>>> On Thu, Aug 11, 2016 at 8:00 PM, leejearl <leejearl at 126.com
>>>>> Thank you for your reply. I have attached the code, grid
>>>>> and the error message.
>>>>> cavity.c is the code file, cavity.exo is the grid, and
>>>>> error.dat is the error message.
>>>>> The command is "mpirun -n 2 ./cavity
>>>>> Can you verify that you are running the master branch? I just
>>>>> ran this and got
>>>>> DM Object: 2 MPI processes
>>>>> type: plex
>>>>> DM_0x84000004_0 in 2 dimensions:
>>>>> 0-cells: 5253 5252
>>>>> 1-cells: 10352 10350
>>>>> 2-cells: 5298 (198) 5297 (198)
>>>>> Labels:
>>>>> ghost: 2 strata of sizes (199, 400)
>>>>> vtk: 1 strata of sizes (4901)
>>>>> Cell Sets: 1 strata of sizes (5100)
>>>>> Face Sets: 3 strata of sizes (53, 99, 50)
>>>>> depth: 3 strata of sizes (5253, 10352, 5298)
>>>>> Thanks,
>>>>> Matt
>>>>> On 2016年08月11日 23:29, Matthew Knepley wrote:
>>>>>> On Thu, Aug 11, 2016 at 3:14 AM, leejearl
>>>>>> <leejearl at 126.com <mailto:leejearl at 126.com>> wrote:
>>>>>> Hi,
>>>>>> Thank you for your reply. It help me very much.
>>>>>> But, for
>>>>>> "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c", when
>>>>>> I set the overlap to 2 levels, the command is
>>>>>> "mpirun -n 3 ./ex11 -f annulus-20.exo
>>>>>> -ufv_mesh_overlap 2 -physics sw", it suffers a error.
>>>>>> It seems to me that setting overlap to 2 is very
>>>>>> common. Are there issues that I have not take into
>>>>>> consideration?
>>>>>> Any help are appreciated.
>>>>>> I will check this out. I have not tested an overlap of 2
>>>>>> here since I generally use nearest neighbor FV methods for
>>>>>> unstructured stuff. I have test examples that run fine
>>>>>> for overlap > 1. Can you send the entire error message?
>>>>>> If the error is not in the distribution, but rather in
>>>>>> the analytics, that is understandable because this
>>>>>> example is only
>>>>>> intended to be run using a nearest neighbor FV method,
>>>>>> and thus might be confused if we give it two layers of ghost
>>>>>> cells.
>>>>>> Matt
>>>>>> leejearl
>>>>>> On 2016年08月11日 14:57, Julian Andrej wrote:
>>>>>>> Hi,
>>>>>>> take a look at slide 10 of [1], there is visually
>>>>>>> explained what the overlap between partitions is.
>>>>>>> [1]
>>>>>>> https://www.archer.ac.uk/training/virtual/files/2015/06-PETSc/slides.pdf
>>>>>>> <https://www.archer.ac.uk/training/virtual/files/2015/06-PETSc/slides.pdf>
>>>>>>> On Thu, Aug 11, 2016 at 8:48 AM, leejearl
>>>>>>> Hi, all:
>>>>>>> I want to use PETSc to build my FVM code.
>>>>>>> Now, I have a question about
>>>>>>> the function DMPlexDistribute(DM dm, PetscInt
>>>>>>> overlap, PetscSF *sf, DM *dmOverlap) .
>>>>>>> In the example
>>>>>>> "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c".
>>>>>>> When I set the overlap
>>>>>>> as 0 or 1, it works well. But, if I set the
>>>>>>> overlap as 2, it suffers a problem.
>>>>>>> I am confused about the value of overlap.
>>>>>>> Can it be set as 2? What is the meaning of
>>>>>>> the parameter overlap?
>>>>>>> Any helps are appreciated!
>>>>>>> leejearl
>>>>>> What most experimenters take for granted before they
>>>>>> begin their experiments is infinitely more interesting
>>>>>> than any results to which their experiments lead.
>>>>>> -- Norbert Wiener
>>>>> What most experimenters take for granted before they begin
>>>>> their experiments is infinitely more interesting than any
>>>>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160817/9f60f790/attachment-0001.html>
