[petsc-users] Meaning of error message (gamg & fieldsplit related)
Safin, Artur
aks084000 at utdallas.edu
Tue Aug 16 17:21:29 CDT 2016
Barry, Mark,
Apologies for taking a while to respond.
Are you saying it works for a while but fails when the problem is large, or that it never works with fieldsplit_1? And how many processors are you using?
All of these are serial runs. The preconditioner always fails for large problems; but I also found an example where it fails for a fairly small matrix. fieldsplit_1 is the one that fails, although fieldpslit_0 always works.
This should be fixed in the master branch
I tried the developmental version (from today), but the same bug persists.
I have some code that reproduces the example. The index sets that I use are non-overlapping; I also checked with matlab that each fieldsplit submatrix is non-singular.
The issue is with fieldsplit_TA: if I do not use -fieldsplit_TA-pc_type_gamg, then the solver converges. Otherwise, it crashes with the same message.
Artur
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0001.html>
Desc: A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0002.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0004.htm>
Desc: A.info
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0003.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0005.htm>
Type: text/x-csrc
Desc: ex.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0001.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0006.htm>
Type: application/x-shellscript
Desc: run.sh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0001.bin>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160816/45f0bd4d/attachment-0007.htm>
