[petsc-users] A question about DMPlexDistribute
leejearl
leejearl at 126.com
Fri Aug 12 20:04:39 CDT 2016
Thank you for your reply. The source code I have used is from the
website of PETSc, not from the git repository.
I will have a test with the code from git repository.
leejearl
On 2016年08月13日 08:49, Oxberry, Geoffrey Malcolm wrote:
>> On Aug 12, 2016, at 5:41 PM, leejearl <leejearl at 126.com
>> <mailto:leejearl at 126.com>> wrote:
>> Hi, Matt:
>> > Can you verify that you are running the master branch?
> cd ${PETSC_DIR}
> git branch
> The last command should return something like a list of branch names,
> and the branch name with an asterisk to the left of it will be the
> branch you are currently on.
> Geoff
>> I am not sure, how can I verify this?
>> And I configure PETSc with this command
>> "./configure --prefix=$HOME/Install/petsc-openmpi
>> --with-mpi=/home/leejearl/Install/openmpi/gnu/1.8.4
>> --download-exodusii=yes --download-netcdf
>> --with-hdf5-dir=/home/leejearl/Install/hdf5-1.8.14 --download-metis=yes".
>> Is there some problem? Can you show me your command for configuring
>> PETSc?
>> Thanks
>> leejearl
>> On 2016年08月13日 01:10, Matthew Knepley wrote:
>>> On Thu, Aug 11, 2016 at 8:00 PM, leejearl <leejearl at 126.com
>>> Thank you for your reply. I have attached the code, grid and the
>>> error message.
>>> cavity.c is the code file, cavity.exo is the grid, and error.dat
>>> is the error message.
>>> The command is "mpirun -n 2 ./cavity
>>> Can you verify that you are running the master branch? I just ran
>>> this and got
>>> DM Object: 2 MPI processes
>>> type: plex
>>> DM_0x84000004_0 in 2 dimensions:
>>> 0-cells: 5253 5252
>>> 1-cells: 10352 10350
>>> 2-cells: 5298 (198) 5297 (198)
>>> Labels:
>>> ghost: 2 strata of sizes (199, 400)
>>> vtk: 1 strata of sizes (4901)
>>> Cell Sets: 1 strata of sizes (5100)
>>> Face Sets: 3 strata of sizes (53, 99, 50)
>>> depth: 3 strata of sizes (5253, 10352, 5298)
>>> Thanks,
>>> Matt
>>> On 2016年08月11日 23:29, Matthew Knepley wrote:
>>>> On Thu, Aug 11, 2016 at 3:14 AM, leejearl <leejearl at 126.com
>>>> Hi,
>>>> Thank you for your reply. It help me very much.
>>>> But, for
>>>> "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c", when I set
>>>> the overlap to 2 levels, the command is
>>>> "mpirun -n 3 ./ex11 -f annulus-20.exo -ufv_mesh_overlap 2
>>>> -physics sw", it suffers a error.
>>>> It seems to me that setting overlap to 2 is very
>>>> common. Are there issues that I have not take into
>>>> consideration?
>>>> Any help are appreciated.
>>>> I will check this out. I have not tested an overlap of 2 here
>>>> since I generally use nearest neighbor FV methods for
>>>> unstructured stuff. I have test examples that run fine for
>>>> overlap > 1. Can you send the entire error message?
>>>> If the error is not in the distribution, but rather in the
>>>> analytics, that is understandable because this example is only
>>>> intended to be run using a nearest neighbor FV method, and thus
>>>> might be confused if we give it two layers of ghost
>>>> cells.
>>>> Matt
>>>> leejearl
>>>> On 2016年08月11日 14:57, Julian Andrej wrote:
>>>>> Hi,
>>>>> take a look at slide 10 of [1], there is visually
>>>>> explained what the overlap between partitions is.
>>>>> [1]
>>>>> https://www.archer.ac.uk/training/virtual/files/2015/06-PETSc/slides.pdf
>>>>> <https://www.archer.ac.uk/training/virtual/files/2015/06-PETSc/slides.pdf>
>>>>> On Thu, Aug 11, 2016 at 8:48 AM, leejearl
>>>>> <leejearl at 126.com <mailto:leejearl at 126.com>> wrote:
>>>>> Hi, all:
>>>>> I want to use PETSc to build my FVM code. Now, I
>>>>> have a question about
>>>>> the function DMPlexDistribute(DM dm, PetscInt overlap,
>>>>> PetscSF *sf, DM *dmOverlap) .
>>>>> In the example
>>>>> "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c". When
>>>>> I set the overlap
>>>>> as 0 or 1, it works well. But, if I set the overlap as
>>>>> 2, it suffers a problem.
>>>>> I am confused about the value of overlap. Can it
>>>>> be set as 2? What is the meaning of
>>>>> the parameter overlap?
>>>>> Any helps are appreciated!
>>>>> leejearl
>>>> What most experimenters take for granted before they begin
>>>> their experiments is infinitely more interesting than any
>>>> results to which their experiments lead.
>>>> -- Norbert Wiener
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
李季
西北工业大学航空学院流体力学系
Phone: 13324530085
QQ: 188524324
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160813/172070ef/attachment.html>
