[petsc-users] [petsc-maint] GAMG with PETSc
Mark Adams mfadams at lbl.gov
Fri Aug 12 10:03:30 CDT 2016
Yes, we should check the type.
#define MATAIJ             "aij"
#define MATSEQAIJ          "seqaij"
#define MATMPIAIJ          "mpiaij"
I assume that MATAIJ is mapped to SEQ or MPI, and so just need to check for
the latter two.  I'll do that now.
On Fri, Aug 12, 2016 at 7:02 AM, Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> [Added petsc-maint to cc, since I think this is an actual bug]
> > On 12 Aug 2016, at 01:16, Gaetan Kenway <gaetank at gmail.com> wrote:
> > Hi
> > I'm attempting to try out using GAMG for a preconditioner for my
> compressible CFD problem. However, I'm getting segfaults when trying to run
> the code. The code is based on ksp ex23.c which is attached. It just reads
> in two precomputed matrices (the actual jacobian and an approximate
> jacobian used to build the PC) and solves with a RHS of ones.
> > My normal approach to solving the system is with ASM+ILU. With the
> following options, everything works fine.
> This appears to be a problem that GAMG doesn't work with BAIJ matrices.
> But there is no checking of the input matrix type anywhere.
> For example, with a debug PETSc:
> cd src/ksp/ksp/examples/tutorials
> make ex23
> ./ex23 -pc_type gamg -mat_type baij
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> argument 1 "mat" before MatSetValues()
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.3-1123-g21143a8  GIT
> Date: 2016-08-08 17:24:17 -0700
> [0]PETSC ERROR: ./ex23 on a arch-darwin-c-dbg named yam-laptop.local by
> lmitche1 Fri Aug 12 11:51:17 2016
> [0]PETSC ERROR: Configure options --download-chaco=1 --download-ctetgen=1
> --download-exodusii=1 --download-hdf5=1 --download-hypre=1
> --download-metis=1 --download-ml=1 --download-mumps=1 --download-netcdf=1
> --download-parmetis=1 --download-ptscotch=1 --download-scalapack=1
> --download-triangle=1 --with-c2html=0 --with-debugging=1
> --with-shared-libraries=1 PETSC_ARCH=arch-darwin-c-dbg
> [0]PETSC ERROR: #1 MatSetValues() line 1195 in /Users/lmitche1/Documents/
> work/src/deps/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #2 PCGAMGFilterGraph() line 342 in
> /Users/lmitche1/Documents/work/src/deps/petsc/src/ksp/pc/impls/gamg/util.c
> [0]PETSC ERROR: #3 PCGAMGGraph_AGG() line 908 in /Users/lmitche1/Documents/
> work/src/deps/petsc/src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: #4 PCSetUp_GAMG() line 525 in /Users/lmitche1/Documents/
> work/src/deps/petsc/src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: #5 PCSetUp() line 968 in /Users/lmitche1/Documents/
> work/src/deps/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #6 KSPSetUp() line 393 in /Users/lmitche1/Documents/
> work/src/deps/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #7 KSPSolve() line 602 in /Users/lmitche1/Documents/
> [0]PETSC ERROR: #8 main() line 158 in /Users/lmitche1/Documents/
> work/src/deps/petsc/src/ksp/ksp/examples/tutorials/ex23.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -mat_type baij
> [0]PETSC ERROR: -pc_type gamg
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> Looking in PCGAMGFilterGraph I see:
>   ierr = MatGetType(Gmat,&mtype);CHKERRQ(ierr);
>   ierr = MatCreate(comm, &tGmat);CHKERRQ(ierr);
>   ierr = MatSetSizes(tGmat,nloc,nloc,MM,MM);CHKERRQ(ierr);
>   ierr = MatSetBlockSizes(tGmat, 1, 1);CHKERRQ(ierr);
>   ierr = MatSetType(tGmat, mtype);CHKERRQ(ierr);
>   ierr = MatSeqAIJSetPreallocation(tGmat,0,d_nnz);CHKERRQ(ierr);
>   ierr = MatMPIAIJSetPreallocation(tGmat,0,d_nnz,0,o_nnz);CHKERRQ(ierr);
>           ierr = MatSetValues(tGmat,1,&Ii,1,&idx[jj],&sv,ADD_VALUES);
> CHKERRQ(ierr);
> So if Gmat is neither SEQAIJ nor MPIAIJ, then no preallocation has
> happened (and MatSetUp is not called).
> Fixing the few instances here by just changing the type of these matrices
> to AIJ.  One runs into to the problem that creating the coarse grid
> operators doesn't work, since MatMatMult and friends do not exist for BAIJ
> matrices.
> I guess GAMG could MatConvert from BAIJ to AIJ (but this uses extra
> memory).
> But it should probably barf with a comprehensible error message.
> Thoughts?
> Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160812/f9cbe78c/attachment.html>
