[petsc-users] Code performance for solving multiple RHS
Barry Smith
bsmith at mcs.anl.gov
Thu Aug 11 22:27:13 CDT 2016
> On Aug 11, 2016, at 10:14 PM, Harshad Ranadive <harshadranadive at gmail.com> wrote:
> Hi Barry,
> Thanks for this recommendation.
> As you mention, the matrix factorization should be on a single processor.
> If the factored matrix A is available on all processors can I then use MatMatSolve(A,B,X) in parallel? That is could the RHS block matrix 'B' and solution matrix 'X' be distributed in different processors as is done while using MatCreateDense(...) ?
Note sure what you mean.
You can have different processes handle different right hand sides. So give the full linear system matrix to each process; each process factors it and then each process solves a different set of right hand sides. Embarrassingly parallel except for any communication you need to do to get the matrix and right hand sides to the right processes.
If the linear system involves say millions of unknowns this is the way to go. If the linear system is over say 1 billion unknowns then it might be worth each linear system in parallel.
Barry
> Thanks,
> Harshad
> On Fri, Aug 12, 2016 at 2:09 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> If it is sequential, which it probably should be, then you can you MatLUFactorSymbolic(), MatLUFactorNumeric() and MatMatSolve() where you put a bunch of your right hand side vectors into a dense array; not all million of them but maybe 10 to 100 at a time.
> Barry
> > On Aug 10, 2016, at 10:18 PM, Harshad Ranadive <harshadranadive at gmail.com> wrote:
> > Hi Barry
> > The matrix A is mostly tridiagonal
> > 1 α 0 ......... 0
> > α 1 α 0 .......0
> > 0 α 1 α 0 ....0
> > 0..............α 1
> > In some cases (periodic boundaries) there would be an 'α' in right-top-corner and left-bottom corner.
> > I am not using multigrid approach. I just implemented an implicit filtering approach (instead of an explicit existing one) which requires the solution of the above system.
> > Thanks
> > Harshad
> > On Thu, Aug 11, 2016 at 1:07 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Effectively utilizing multiple right hand sides with the same system can result in roughly 2 or at absolute most 3 times improvement in solve time. A great improvement but when you have a million right hand sides not a giant improvement.
> > The first step is to get the best (most efficient) preconditioner for you problem. Since you have many right hand sides it obviously pays to spend more time building the preconditioner so that each solve is faster. If you provide more information on your linear system we might have suggestions. CFD so is your linear system a Poisson problem? Are you using geometric or algebraic multigrid with PETSc? It not a Poisson problem how can you describe the linear system?
> > Barry
> > > On Aug 10, 2016, at 9:54 PM, Harshad Ranadive <harshadranadive at gmail.com> wrote:
> > > Hi All,
> > > I have currently added the PETSc library with our CFD solver.
> > > In this I need to use KSPSolve(...) multiple time for the same matrix A. I have read that PETSc does not support passing multiple RHS vectors in the form of a matrix and the only solution to this is calling KSPSolve multiple times as in example given here:
> > > http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex16.c.html
> > > I have followed this technique, but I find that the performance of the code is very slow now. I basically have a mesh size of 8-10 Million and I need to solve the matrix A very large number of times. I have checked that the statement KSPSolve(..) is taking close to 90% of my computation time.
> > > I am setting up the matrix A, KSPCreate, KSPSetup etc just once at the start. Only the following statements are executed in a repeated loop
> > > Loop begin: (say million times !!)
> > > loop over vector length
> > > VecSetValues( ....)
> > > end
> > > VecAssemblyBegin( ... )
> > > VecAssemblyEnd (...)
> > > KSPSolve (...)
> > > VecGetValues
> > > Loop end.
> > > Is there an efficient way of doing this rather than using KSPSolve multiple times?
> > > Please note my matrix A never changes during the time steps or across the mesh ... So essentially if I can get the inverse once would it be good enough? It has been recommended in the FAQ that matrix inverse should be avoided but would it be okay to use in my case?
> > > Also could someone please provide an example of how to use MatLUFactor and MatCholeskyFactor() to find the matrix inverse... the arguments below were not clear to me.
> > > IS row
> > > IS col
> > > const MatFactorInfo *info
> > > Apologies for a long email and thanks to anyone for help.
> > > Regards
> > > Harshad
