[petsc-users] function set by TSSetRHSJacobian() not being called
Hong Zhang
hongzhang at anl.gov
Tue Aug 9 14:34:52 CDT 2016
I guess Barry meant “implicit method”.
To use backward Euler, change TSEULER to TSBEULER in the function call of TSSetType().
Hong
> On Aug 9, 2016, at 2:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> The Euler method is an explicit method that does not require the Jacobian. Hence the Jacobian you provide is never used.
> If you use any implement method, for example backward Euler beuler then you will see the Jacobian being used.
> Barry
>> On Aug 9, 2016, at 2:08 PM, Scott Dossa <doss0032 at umn.edu> wrote:
>> Hi all,
>> I adapted ex13.c from .../ts/examples/tutorials/ex13.c to solve a 1D TD PDE (swift-hohenberg).
>> Long story short: the function which sets the Jacobian is never being called despite being assigned by TSSetRHSJacobian().
>> I create the TS environment with the following commands (omitting some code before and after -- Full code attached):
>> ierr = DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, 15, 1, 1, NULL, &da); CHKERRQ(ierr);
>> Let DMDA create vector
>> ierr = DMCreateGlobalVector(da, &x);CHKERRQ(ierr);
>> Create timestepper context which will use Euler Method
>> ierr = TSCreate(PETSC_COMM_WORLD,&ts);CHKERRQ(ierr);
>> ierr = TSSetDM(ts, da);CHKERRQ(ierr);
>> ierr = TSSetType(ts, TSEULER);CHKERRQ(ierr);
>> ierr = TSSetRHSFunction(ts, x, RHSFunction, NULL);CHKERRQ(ierr);
>> Create Jacobian for Euler Method
>> ierr = DMSetMatType(da, MATAIJ);CHKERRQ(ierr);
>> ierr = DMCreateMatrix(da,&J);CHKERRQ(ierr);
>> ierr = TSSetRHSJacobian(ts,J,J,RHSJacobian,NULL); CHKERRQ(ierr)
>> I define the function RHSJacobian later, PetscPrintf(PETSC_COMM_WORLD, "Jacobian function called") is used to see if the function is ever called.
>> Neither is the message ever called, nor is the Jacobian matrix ever non-zero. The J matrix is checked with MatView( ). No error messages are produced either at compiling nor runtime.
>> Has anyone else run into such an issue or have any advice of how best to probe the problem?
>> Thanks so much!
>> -Scott Dossa
>> <swift.cpp>
