[petsc-users] matrix-free method with preconditioning for a linear system
Lailai Zhu
lailaizhu00 at gmail.com
Tue Aug 9 11:11:46 CDT 2016
hi, Dear Matt,
thanks very much. I think I found the problem, in the pcshell part, i was
using 'MatGetDiagonal' which is not supported for the shell-type matrix.
This
caused the problem.
best,
lailai
On 2016/8/9 17:57, Matthew Knepley wrote:
> On Tue, Aug 9, 2016 at 10:27 AM, Lailai Zhu <lailaizhu00 at gmail.com
> <mailto:lailaizhu00 at gmail.com>> wrote:
> Hi, dear developers,
> I am currently facing such a problem. I would like to use a
> matrix-free
> method to solve a linear system. So I use 'MatCreateShell' with
> user-defined
> subroutine to evaluate matrix-vector product. This works well, but
> is much slower
> than the traditional matrix-assembling approach where different
> preconditioning
> can be applied.
> Now I would like to build a user-defined preconditioning for this
> matrix-free approach,
> then I used to 'PCSHELL'. However, petsc told me that
> '[0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Mat type shell'.
> Send the ENTIRE error message. You should get a stack trace, which
> tells us where this
> is happening. Make sure you are checking all return values using
> CHKERRQ().
> Thanks,
> Matt
> I am using petsc 3.7.2. It seems that this user-defined PC is not
> supported with the 'MatCreateShell'. Is this
> indeed the case? Is there any way to circumvent this, for example
> by using 'MatCreateMFFD'
> or a SNSE artificially for a linear problem? Thanks in advance,
> best,
> lailai
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160809/f5c4211c/attachment.html>
