[petsc-users] How to solve nonlinear F(x) = b(x)?
Neiferd, David John
david.neiferd at wright.edu
Mon Aug 8 16:23:15 CDT 2016
Thanks for the suggestions Geoff and Dave. Using G(x) = F(x) - b(x) = 0, will required redefinition of the Jacobian correct? If I understand correctly, the Jacobian is the derivative of F(x) with respect to x. Since we are redefining F(x) to G(x), it would be necessary to change the Jacobian from dF(x)/dx to dF(x)/dx - db(x)/dx, correct?
Also, I noticed when I implemented G(x) = F(x) - b = 0 (where b is constant) the method seems less robust when using newton's method with a line search, at least for one particular problem, the line search (using default settings) diverges (converged reason = -6), but using a trust region newton method or a quasi-newton method it converges to the answer.
From: Oxberry, Geoffrey Malcolm <oxberry1 at llnl.gov>
Sent: Monday, August 8, 2016 4:20:27 PM
To: Neiferd, David John
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] How to solve nonlinear F(x) = b(x)?
David,
What about solving G(x) = F(x) - b(x) = 0?
Geoff
On Aug 8, 2016, at 1:12 PM, Neiferd, David John <david.neiferd at wright.edu<mailto:david.neiferd at wright.edu>> wrote:
Hello all,
I've been searching through the PETSc documentation to try to find how to solve a nonlinear system where the right hand side (b) varies as a function of the state variables (x). According to the PETSc documentation, SNES solves the equations F(x) = b where b is a constant vector. What would I do to solve F(x) = b(x)? An example of this would be a nonlinear thermoelastic structure where as the structure deforms the direction of the loads generated by the thermal expansion changes as well. Any insight into how to implement this is appreciated.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/fd9ac526/attachment.html>
