[petsc-users] false-positive leak report in log_view?
Mohammad Mirzadeh
mirzadeh at gmail.com
Wed Aug 3 13:18:49 CDT 2016
OK so I just ran the example under valgrind, and if I use two VecViews, it
complains about following leak:
==66838== 24,802 (544 direct, 24,258 indirect) bytes in 1 blocks are
definitely lost in loss record 924 of 926
==66838== at 0x100009EBB: malloc (in
/usr/local/Cellar/valgrind/3.11.0/lib/valgrind/vgpreload_memcheck-amd64-darwin.so)
==66838== by 0x10005E638: PetscMallocAlign (in
/usr/local/Cellar/petsc/3.7.2/real/lib/libpetsc.3.7.2.dylib)
==66838== by 0x100405F00: DMCreate_DA (in
==66838== by 0x1003CFFA4: DMSetType (in
==66838== by 0x100405B7F: DMDACreate (in
==66838== by 0x1003F825F: DMDACreate2d (in
==66838== by 0x100001D89: main (main_test.cpp:7)
By I am destroying the dm ... also I dont get this when using a single
VecView. As a bonus info, PETSC_VIEWER_STDOUT_WORLD is just fine, so this
looks like it is definitely vtk related.
On Wed, Aug 3, 2016 at 2:05 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>
wrote:
> On Wed, Aug 3, 2016 at 10:59 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Aug 2, 2016 at 12:40 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>
>> wrote:
>>> I often use the memory usage information in log_view as a way to check
>>> on memory leaks and so far it has worked perfect. However, I had long
>>> noticed a false-positive report in memory leak for Viewers, i.e.
>>> destruction count is always one less than creation.
>> Yes, I believe that is the Viewer being used to print this information.
> That makes sense.
>>> Today, I noticed what seems to be a second one. If you use VecView to
>>> write the same DA to vtk, i.e. call VecView(A, vtk); twice, it also report
>>> a memory leak for vectors, vecscatters, dm, etc. I am calling this a
>>> false-positive since the code is valgrind-clean.
>>> Is this known/expected?
>> The VTK viewers have to hold everything they output until they are
>> destroyed since the format does not allow immediate writing.
>> I think the VTK viewer is not destroyed at the time of this output. Can
>> you make a small example that does this?
> Here's a small example that illustrates the issues
> #include <petsc.h>
> int main(int argc, char *argv[]) {
> PetscInitialize(&argc, &argv, NULL, NULL);
> DM dm;
> DMDACreate2d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, DMDA_STENCIL_BOX,
> -10, -10, PETSC_DECIDE, PETSC_DECIDE, 1, 1, NULL, NULL,
> &dm);
> // DMDASetUniformCoordinates(dm, -1, 1, -1, 1, 0, 0);
> Vec sol;
> DMCreateGlobalVector(dm, &sol);
> VecSet(sol, 0);
> PetscViewer vtk;
> PetscViewerVTKOpen(PETSC_COMM_WORLD, "test.vts", FILE_MODE_WRITE, &vtk);
> VecView(sol, vtk);
> // VecView(sol, vtk);
> PetscViewerDestroy(&vtk);
> DMDestroy(&dm);
> VecDestroy(&sol);
> PetscFinalize();
> return 0;
> If you uncomment the second VecView you get reports for leaks in
> VecScatter and dm. If you also uncomment the DMDASetUniformCoordinates, and
> use both VecViews, you also get a leak report for Vecs ... its quite
> bizarre ...
>> I have switched to HDF5 and XDMF due to the limitations of VTK format.
> I had used XDMF + raw binary in the past and was satisfied with the
> result. Do you write a single XDMF as a "post-processing" step when the
> simulation is finished? If I remember correctly preview could not open xmf
> files as time-series.
>> Thanks,
>> Matt
>>> Here's the relevant bit from log_view:
>>> --- Event Stage 0: Main Stage
>>> Vector 8 7 250992 0.
>>> Vector Scatter 2 0 0 0.
>>> Distributed Mesh 2 0 0 0.
>>> Star Forest Bipartite Graph 4 0 0 0.
>>> Discrete System 2 0 0 0.
>>> Index Set 4 4 83136 0.
>>> IS L to G Mapping 2 0 0 0.
>>> Viewer 2 1 784 0.
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160803/cfee10f3/attachment.html>
