[petsc-users] Petsc mesh scalability issue with iterative solver and direct solver
Jinlei Shen jshen25 at jhu.edu
Mon Aug 1 12:52:31 CDT 2016
Hi Barry,
Thanks for your reply.
Firstly, as you suggested, I checked my program under valgrind. The results
for both sequential and parallel cases showed there are no memory errors
detected.
Second, I coded a sequential program without using PETSC to generate the
global matrix of small mesh for the same problem. I then checked the matrix
both from petsc(sequential and parallel) and serial code, and they are same.
The way I assembled the global matrix in parallel is first distributing the
nodes and elements into processes, then I loop with  elements on the
calling process to put the element stiffness into the global. Since the
nodes and elements in cantilever beam are numbered successively, the
connectivity is simple. I didn't use any partition tools to optimize mesh.
It's also easy to determine the preallocation d_nnz and o_nnz since each
node only connects the left and right nodes except for beginning and end,
the maximum nonzeros in each row is 6. The MatSetValue process is shown as
follows:
    do iEL = idElStart, idElEnd
        g_EL = (/2*iEL-1-1,2*iEL-1,2*iEL+1-1,2*iEL+2-1/)
        call MatSetValues(SG,4,g_EL,4,g_El,SE,ADD_VALUES,ierr)
    end do
where idElStart and idElEnd are the global number of first element and end
element that the process owns, g_EL is the global index for DOF in element
iEL, SE is the element stiffness which is same for all elements.
>From above assembling, most of the elements are assembled within own
process while there are few elements crossing two processes.
The BC for my problem(cantilever under end point load) is to fix the first
two DOF, so I called the MatZeroRowsColumns to set the first two rows and
columns into zero with diagonal equal to one, without changing the RHS.
Now some new issues show up :
I run with -ksp_monitor_true_residual and -ksp_converged_reason, the
monitor showed two different residues, one is the residue I can
set(preconditioned, unpreconditioned, natural), the other is called true
residue.
I initially thought the true residue is same as unpreconditioned based on
definition. But it seems not true.  Is it the norm of the residue (b-Ax)
between computed RHS and true RHS?    But, how to understand unprecondition
residue since its definition is b-Ax as well?
Can I set the true residue as my converging criteria?
I found the accuracy of large mesh in my problem didn't necessary depend on
the tolerance I set, either preconditioned or unpreconditioned, sometimes,
it showed converged while the solution is not correct. But the true residue
looks reflecting the true convergence very well, if the true residue is
diverging, no matter what the first residue says, the results are bad!
For the preconditioner concerns, actually, I used BJACOBI before I sent the
first email, since the JACOBI or PBJACOBI didn't even converge when the
size was large.
But BJACOBI also didn't perform well in the paralleliztion for large mesh
as posed in my last email, while it's fine for small size (below 10k
elements)
Yesterday, I tried the ASM  with CG using the runtime option: -pc_type asm
-pc_asm_type basic -sub_pc_type lu (default is ilu).
For 15k elements mesh, I am now able to get the correct answer with 1-3, 6
and more processes, using either -sub_pc_type lu or ilu.
Based on all the results I have got, it shows the results varies a lot with
different PC and seems ASM is better for large problem.
But what is the major factor to produce such difference between different
PCs, since it's not just the issue of computational efficiency, but also
the accuracy.
Also, I noticed for large mesh, the solution is unstable with small number
of processes, for the 15k case, the solution is not correct with 4 and 5
processes, however, the solution becomes always correct with more than 6
processes. For the 50k mesh case, more processes are required to show the
stability.
What do you think about this? Anything wrong?
Since the iterative solver in parallel is first computed locally(if this is
correct), can it be possible that there are 'good' and 'bad' locals when
dividing the global matrix, and the result from 'bad' local will
contaminate the global results. But with more processes, such risk is
reduced.
It is highly appreciated if you could give me some instruction for above
questions.
Thank you very much.
Bests,
Jinlei
On Fri, Jul 29, 2016 at 2:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   First run  under valgrind all the cases to make sure there is not some
> use of uninitialized data or overwriting of data. Go to
> http://www.mcs.anl.gov/petsc follow the link to FAQ and search for
> valgrind (the web server seems to be broken at the moment).
>   Second it is possible that your code the assembles the matrices and
> vectors is not correctly assembling it for either the sequential or
> parallel case. Hence a different number of processes could be generating a
> different linear system hence inconsistent results. How are you handling
> the parallelism? How do you know the matrix generated in parallel is
> identically to that sequentially?
> Simple preconditioners such as pbjacobi will converge slower and slower
> with more elements.
> Note that you should run with -ksp_monitor_true_residual and
> -ksp_converged_reason to make sure that the iterative solver is even
> converging. By default PETSc KSP solvers do not stop with a big error
> message if they do not converge so you need make sure they are always
> converging.
>    Barry
> > On Jul 29, 2016, at 11:46 AM, Jinlei Shen <jshen25 at jhu.edu> wrote:
> > Dear PETSC developers,
> > Thank you for developing such a powerful tool for scientific
> computations.
> > I'm currently trying to run a simple cantilever beam FEM to test the
> scalability of PETSC on multi-processors. I also want to verify whether
> iterative solver or direct solver is more efficient for parallel large FEM
> problem.
> > Problem description, An Euler elementary cantilever beam with point load
> at the end along -y direction. Each node has 2 DOF (deflection and
> rotation)). MPIBAIJ is used with bs = 2, dnnz and onnz are determined based
> on the connectivity. Loop with elements in each processor to assemble the
> global matrix with same element stiffness matrix. The boundary condition is
> set using call
> MatZeroRowsColumns(SG,2,g_BC,one,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr);
> > Based on what I have done, I find the computations work well, i.e the
> results are correct compared with theoretical solution, for small mesh size
> (small than 5000 elements) using both solvers with different numbers of
> processes.
> > However, there are several confusing issues when I increase the mesh
> size to 10000 and more elements with iterative solve(CG + PCBJACOBI)
> > 1. For 10k elements, I can get accurate solution using iterative solver
> with uni-processor(i.e. only one process). However, when I use 2-8
> processes, it tells the linear solver converged with different iterations,
> but, the results are all different for different processes and erroneous.
> The wired thing is when I use >9 processes, the results are correct again.
> I am really confused by this. Could you explain me why?  If my
> parallelization is not correct, why it works for small cases? And I check
> the global matrix and RHS vector and didn't see any mallocs during the
> process.
> > 2. For 30k elements, if I use one process, it says: Linear solve did not
> converge due to DIVERGED_INDEFINITE_PC. Does this commonly happen for large
> sparse matrix? If so, is there any stable solver or pc for large problem?
> > For parallel computing using direct solver(SUPERLU_DIST + PCLU), I can
> only get accuracy when the number of elements are below 5000. There must be
> something wrong. The way I use the superlu_dist solver is first convert
> MatType to AIJ, then call PCFactorSetMatSolverPackage, and change the PC to
> PCLU. Do I miss anything else to run SUPER_LU correctly?
> > I also use SUPER_LU and iterative solver(CG+PCBJACOBI) to solve the
> sequential version of the same problem. The results shows that iterative
> solver works well for <50k elements, while SUPER_LU only gets right
> solution below 5k elements. Can I say iterative solver is better than
> SUPER_LU for large problem? How can I improve the solver to copy with very
> large problem, such as million by million? Another thing is it's still
> doubtable of performance of SUPER_LU.
> > For the inaccuracy issue, do you think it may be due to the memory?
> However, there is no memory error showing during the execution.
> > I really appreciate someone could resolve those puzzles above for me. My
> goal is to replace the current SUPER_LU  solver in my parallel CPFEM main
> program with the iterative solver using PETSC.
> > Please let me if you would like to see my code in detail.
> > Bests,
> > Jinlei
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/263a2805/attachment.html>
