[petsc-users] Moving from KSPSetNullSpace to MatSetNullSpace
Gil Forsyth
gforsyth at gwu.edu
Tue Sep 29 12:12:44 CDT 2015
Ah, got it. I'll checkout the master branch and see if the behavior
persists.
Many thanks,
Gil
On Tue, Sep 29, 2015 at 1:10 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 29, 2015 at 12:08 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>> PETSc is version 3.6.1 -- I just included a log from 3.5.4 to show that
>> the behavior seems to have changed between versions. The only difference
>> in our code between 3.5.4 and 3.6.1 is the change from KSPSetNullSpace to
>> MatSetNullSpace.
> Mark made some GAMG changes which were later reversed because they had
> unintended consequences like this.
> I think what Barry means is, "you should get the behavior you expect using
> the master branch from PETSc development"
> Thanks,
> Matt
>> On Tue, Sep 29, 2015 at 1:04 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Update your PETSc
>>> > On Sep 29, 2015, at 12:00 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>>> > Hi Barry,
>>> > We aren't explicitly setting GMRES anywhere in the code and I'm not
>>> sure why it's being used. Running our 3.5.4 code using KSPSetNullSpace
>>> works with:
>>> > $PETIBM_DIR/petibm3.5/bin/petibm2d -directory . -poisson_pc_type gamg
>>> -poisson_pc_gamg_type agg -poisson_pc_gamg_agg_nsmooths 1 -poisson_ksp_view
>>> -poisson_ksp_monitor_true_residual -poisson_ksp_converged_reason >
>>> kspview3.5.4
>>> > and shows that the coarse grid solver is of type:preonly
>>> > running the newer version that uses MatSetNullSpace in its stead and
>>> adding in -poisson_mg_coarse_ksp_type preonly
>>> > $PETIBM_DIR/petibm3.6/bin/petibm2d -directory . -poisson_pc_type gamg
>>> -poisson_mg_coarse_ksp_type preonly -poisson_ksp_view
>>> kspview3.6.1
>>> > still shows
>>> > KSP Object:(poisson_) 1 MPI processes
>>> > type: cg
>>> > maximum iterations=10000
>>> > tolerances: relative=1e-05, absolute=1e-50, divergence=10000
>>> > left preconditioning
>>> > using nonzero initial guess
>>> > using PRECONDITIONED norm type for convergence test
>>> > PC Object:(poisson_) 1 MPI processes
>>> > type: gamg
>>> > MG: type is MULTIPLICATIVE, levels=3 cycles=v
>>> > Cycles per PCApply=1
>>> > Using Galerkin computed coarse grid matrices
>>> > GAMG specific options
>>> > Threshold for dropping small values from graph 0
>>> > AGG specific options
>>> > Symmetric graph false
>>> > Coarse grid solver -- level -------------------------------
>>> > KSP Object: (poisson_mg_coarse_) 1 MPI processes
>>> > type: gmres
>>> > GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>> > GMRES: happy breakdown tolerance 1e-30
>>> > maximum iterations=1, initial guess is zero
>>> > using NONE norm type for convergence test
>>> > both logs are attached.
>>> > On Tue, Sep 29, 2015 at 12:37 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> > This can't work. You can't use a GMRES inside a CG. Try changing
>>> to -poisson_mg_coarse_ksp_type preonly
>>> > type: cg
>>> > type: gmres
>>> > > On Sep 29, 2015, at 10:53 AM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>>> > > On Tue, Sep 29, 2015 at 11:42 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > > On Tue, Sep 29, 2015 at 10:28 AM, Gil Forsyth <gforsyth at gwu.edu>
>>> wrote:
>>> > > Hi all,
>>> > > I've been having some trouble with what should be a relatively
>>> simple update to an immersed boundary CFD solver from PETSc 3.5.4 to 3.6.1
>>> > > I'm getting indefinite PC errors for a simple lid-driven cavity test
>>> problem, 32x32 at Re 100
>>> > > Under PETSc 3.5.4 using KSPSetNullSpace we used the following to set
>>> the null space. This is for a 2D Poisson system with no immersed boundary
>>> and so the null space is the constant vector.
>>> > > MatNullSpace nsp;
>>> > > ierr = MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_TRUE, 0, NULL,
>>> &nsp); CHKERRQ(ierr);
>>> > > ierr = KSPSetNullSpace(ksp2, nsp); CHKERRQ(ierr);
>>> > > ierr = MatNullSpaceDestroy(&nsp); CHKERRQ(ierr);
>>> > > Clearly this has to happen in the reverse order, since ksp2 would
>>> not be created yet.
>>> > > For questions about solvers, we HAVE to see the complete output of
>>> -ksp_view so we
>>> > > know what we are dealing with. Its also nice to have
>>> -ksp_monitor_true_residual -ksp_converged_reason
>>> > > Matt
>>> > > Yes -- sorry, those are both in inline files and are called in the
>>> reverse order that I wrote them out.
>>> > > I've attached the output of
>>> gamg -poisson_pc_gamg_type agg -poisson_gamg_agg_nsmooths 1
>>> -poisson_ksp_view -poisson_ksp_monitor_true_residual
>>> -poisson_ksp_converged_reason > kspview.log
>>> > > And then setup the KSP with
>>> > > ierr = KSPCreate(PETSC_COMM_WORLD, &ksp2); CHKERRQ(ierr);
>>> > > ierr = KSPSetOptionsPrefix(ksp2, "poisson_"); CHKERRQ(ierr);
>>> > > ierr = KSPSetOperators(ksp2, QTBNQ, QTBNQ); CHKERRQ(ierr);
>>> > > ierr = KSPSetInitialGuessNonzero(ksp2, PETSC_TRUE); CHKERRQ(ierr);
>>> > > ierr = KSPSetType(ksp2, KSPCG); CHKERRQ(ierr);
>>> > > ierr = KSPSetReusePreconditioner(ksp2, PETSC_TRUE); CHKERRQ(ierr);
>>> > > ierr = KSPSetFromOptions(ksp2); CHKERRQ(ierr);
>>> > > The matrix QTBNQ does not change, only the rhs of the system is
>>> updated.
>>> > > We run this with `-pc_type gamg -pc_gamg_type agg
>>> -pc_gamg_agg_nsmooths 1` and everything seems to work as expected.
>>> > > Under PETSc 3.6.1, we change only the KSPSetNullSpace line, to
>>> > > ierr = MatSetNullSpace(QTBNQ, nsp); CHKERRQ(ierr);
>>> > > and the same code diverges after 1 timestep and returns a -8
>>> KSP_DIVERGED_INDEFINITE_PC
>>> > > This is weird, especially because if we change nsmooths to 2, it
>>> runs for 264 timesteps and the returns the same error. But we have
>>> explicitly set KSPSetReusePreconditioner so it should be using the same PC,
>>> right?
>>> > > Change nsmooths to 3 and it again diverges after 1 timestep.
>>> > > Change nsmooths to 4 and it runs to completion.
>>> > > It seems like either gamg's behavior has changed, or that
>>> KSPSetNullSpace was doing something implicitly that we now need to do
>>> explicitly in addition to MatSetNullSpace?
>>> > > Thanks,
>>> > > Gil Forsyth
>>> > > What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> > > -- Norbert Wiener
>>> > > <kspview.log>
>>> > <kspview3.5.4><kspview3.6.1>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150929/58ba6579/attachment.html>
