[petsc-users] Moving from KSPSetNullSpace to MatSetNullSpace
Gil Forsyth gforsyth at gwu.edu
Tue Sep 29 12:00:59 CDT 2015
Hi Barry,
We aren't explicitly setting GMRES anywhere in the code and I'm not sure
why it's being used.  Running our 3.5.4 code using KSPSetNullSpace works
with:
$PETIBM_DIR/petibm3.5/bin/petibm2d -directory . -poisson_pc_type gamg
-poisson_pc_gamg_type agg -poisson_pc_gamg_agg_nsmooths 1 -poisson_ksp_view
-poisson_ksp_monitor_true_residual -poisson_ksp_converged_reason >
kspview3.5.4
and shows that the coarse grid solver is of type:preonly
running the newer version that uses MatSetNullSpace in its stead and adding
in -poisson_mg_coarse_ksp_type preonly
$PETIBM_DIR/petibm3.6/bin/petibm2d -directory . -poisson_pc_type gamg
-poisson_mg_coarse_ksp_type preonly -poisson_ksp_view
kspview3.6.1
still shows
KSP Object:(poisson_) 1 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object:(poisson_) 1 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
      GAMG specific options
        Threshold for dropping small values from graph 0
        AGG specific options
          Symmetric graph false
  Coarse grid solver -- level -------------------------------
    KSP Object:    (poisson_mg_coarse_)     1 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=1, initial guess is zero
      using NONE norm type for convergence test
both logs are attached.
On Tue, Sep 29, 2015 at 12:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    This can't work. You can't use a GMRES inside a CG.   Try changing to
>   type: cg
>       type: gmres
> > On Sep 29, 2015, at 10:53 AM, Gil Forsyth <gforsyth at gwu.edu> wrote:
> > On Tue, Sep 29, 2015 at 11:42 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Tue, Sep 29, 2015 at 10:28 AM, Gil Forsyth <gforsyth at gwu.edu> wrote:
> > Hi all,
> > I've been having some trouble with what should be a relatively simple
> update to an immersed boundary CFD solver from PETSc 3.5.4 to 3.6.1
> > I'm getting indefinite PC errors for a simple lid-driven cavity test
> problem, 32x32 at Re 100
> > Under PETSc 3.5.4 using KSPSetNullSpace we used the following to set the
> null space.  This is for a 2D Poisson system with no immersed boundary and
> so the null space is the constant vector.
> >   MatNullSpace nsp;
> >   ierr = MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_TRUE, 0, NULL,
> &nsp); CHKERRQ(ierr);
> >   ierr = KSPSetNullSpace(ksp2, nsp); CHKERRQ(ierr);
> >   ierr = MatNullSpaceDestroy(&nsp); CHKERRQ(ierr);
> > Clearly this has to happen in the reverse order, since ksp2 would not be
> created yet.
> > For questions about solvers, we HAVE to see the complete output of
> -ksp_view so we
> > know what we are dealing with. Its also nice to have
> -ksp_monitor_true_residual -ksp_converged_reason
> >   Matt
> > Yes -- sorry, those are both in inline files and are called in the
> reverse order that I wrote them out.
> > I've attached the output of
> -poisson_pc_gamg_type agg -poisson_gamg_agg_nsmooths 1 -poisson_ksp_view
> kspview.log
> > And then setup the KSP with
> >   ierr = KSPCreate(PETSC_COMM_WORLD, &ksp2); CHKERRQ(ierr);
> >   ierr = KSPSetOptionsPrefix(ksp2, "poisson_"); CHKERRQ(ierr);
> >   ierr = KSPSetOperators(ksp2, QTBNQ, QTBNQ); CHKERRQ(ierr);
> >   ierr = KSPSetInitialGuessNonzero(ksp2, PETSC_TRUE); CHKERRQ(ierr);
> >   ierr = KSPSetType(ksp2, KSPCG); CHKERRQ(ierr);
> >   ierr = KSPSetReusePreconditioner(ksp2, PETSC_TRUE); CHKERRQ(ierr);
> >   ierr = KSPSetFromOptions(ksp2); CHKERRQ(ierr);
> > The matrix QTBNQ does not change, only the rhs of the system is updated.
> > We run this with `-pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths
> 1` and everything seems to work as expected.
> > Under PETSc 3.6.1, we change only the KSPSetNullSpace line, to
> >   ierr = MatSetNullSpace(QTBNQ, nsp); CHKERRQ(ierr);
> > and the same code diverges after 1 timestep and returns a -8
> KSP_DIVERGED_INDEFINITE_PC
> > This is weird, especially because if we change nsmooths to 2, it runs
> for 264 timesteps and the returns the same error.  But we have explicitly
> set KSPSetReusePreconditioner so it should be using the same PC, right?
> > Change nsmooths to 3 and it again diverges after 1 timestep.
> > Change nsmooths to 4 and it runs to completion.
> > It seems like either gamg's behavior has changed, or that
> KSPSetNullSpace was doing something implicitly that we now need to do
> explicitly in addition to MatSetNullSpace?
> > Thanks,
> > Gil Forsyth
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > <kspview.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150929/c175640b/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150929/c175640b/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150929/c175640b/attachment-0003.obj>
