[petsc-users] multi-grid for anisotropy
Jed Brown jed at jedbrown.org
Tue Sep 29 09:17:36 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> Hi all,
> I think I have asked a previous question related to this, and have
> seen other threads about related issues, but say I have this
> anisotropic dispersion
Diffusion and dispersion are different phenomena.  Sounds like you mean
diffusion.
> tensor:
> D = (D_m + alpha_L*norm(v))*Identity + (alpha_L - alpha_T)*outer(v,v)/norm(v)
> The anisotropy of this tensor comes from the ratio of alpha_L/alpha_T and velocity v, and is mesh independent. That said, can tuning the multi-grid preconditioners parameters of GAMG/HYPRE/etc help prevent things like negative concentrations and violations of the discrete maximum principles?
Hell no!  Tuning an algebraic solver doesn't fix a non-monotone discretization.
That said, the linear solve could converge "from below", in which case
you might want to perform a cleaning step that fixes values by less than
the algebraic solver tolerance.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150929/f54e8214/attachment.pgp>
