[petsc-users] KSP step not accelerating despite good preconditioning in SNES
Mon Sep 28 07:17:35 CDT 2015
On Mon, Sep 28, 2015 at 2:53 AM, Timothée Nicolas <
timothee.nicolas at gmail.com> wrote:
> Hi all,
> I have something strange in my application and I don't know what could
> cause this. I am trying to do an implicit MHD problem and I thought I
> finally figured out the preconditioner step, but somehow I don't get the
> expected result, not even close.
> For the preconditioning, I am using an approximate Schur complement, which
> requires two relatively easy KSP inversions at each preconditioner
> application. I apply this algorithm directly to the result function at the
> end of the routine FormFunction. I have checked that the approximation to
> the inversion of the Jacobian is good, in the sense that when I multiply
> the preconditioned vector by the *total* Jacobian matrix, I indeed
> recover almost the initial unpreconditioned vector. Also, I know that my
> Jacobian matrix is correct, because (i) I have checked manually that F(X +
> dX) ~ F(X) + J * dX and (ii) when I don't use -snes_mf and use the provided
> Jacobian matrix the result is pretty much equivalent to using -snes_mf.
> In my understanding, this means that what I effectively feed to SNES at
> the end of my FormFunction routine is a good approximation to J^(-1) F. As
> a result, I naturally expect that the number of KSP iterations necessary to
> achieve one SNES iteration be drastically reduced. However, I observe
> virtually no change whatsoever in the number of iterations.
> Any thoughts about what I could be missing ? Maybe I forgot to set a SNES
> or KSP option somewhere ? I can send pieces of code if needs be.
It sounds like you are putting this in the wrong place. If you have the
action of a good preconditioner for the Jacobian, then you
should use a PCSHELL and pass it to the KSP. It does not belong in the
FormFunction.
     Matt
> Best
> Timothee
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150928/6dcb8ab9/attachment.html>
