[petsc-users] reuse matrix aij structure
Fri Sep 25 11:12:17 CDT 2015
> On Sep 25, 2015, at 7:28 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 25, 2015 at 4:16 AM, Feng Xing <snakexf at gmail.com> wrote:
> Hello everyone,
> I want to solve many times A*x=b, where the non-zero structure of A (aij) is always same, but its values change. I would like to ask if it is possible to call assembly_begin/end only one time, then change the values of A each time.
> You need to call assembly when changing values, but it
   will
> should be fast.
>    Matt
> I find it is possible for a vector(Vec) through VecGetArray. It returns a pointer. Is there similar way for matrix? Thank you very much.
> Regards,
> Feng Xing
> Postdoc at Inria
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
