[petsc-users] Direct inversion methods in parallel
Timothée Nicolas
timothee.nicolas at gmail.com
Fri Sep 25 00:24:27 CDT 2015
Hi all, from the manual, I get that the options
-ksp_type preonly -pc_type lu
to solve a problem by direct LU inversion are available only for sequential
matrices. Should I conclude that there is no method to try a direct
inversion of a big problem in parallel ?
I plan to use the direct inversion only as a check that my approximation to
the inverse problem is OK, because so far my algorithm which should work is
not working at all and I need to debug what is going on. Namely I use an
approximation to the linear problem using an approximate Schur complement,
and I want to know if my approximation is false or if from the start my
matrices are false.
I have tried a direct inversion on one process with the above options for a
quite small problem (12x12x40 with 8 dof), but it did not work, I suppose
because of memory limitation (output with log_summary at the end attached
just in case).
Best
Timothee NICOLAS
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150925/a2cd0c29/attachment-0001.html>
This is an implicit MHD code based on the MIPS code
Setting all options
Start: Reading HINT2 equilibrium file
DATA: lr,lz,lphi= 12 12 40
lsymmetry= 1
r_min,r_max= 2.7000000000000002 4.5999999999999996
z_min,z_max= -0.94999999999999996 0.94999999999999996
phi_min,phi_max= 0.0000000000000000 6.2831853071795862
dr,dz,dphi= 0.17272727272727267 0.17272727272727273 0.15707963267948966
pmax= 4.0818670444571345E-003
bmax= 2.9663632417550203
End: Reading HINT2 equilibrium file
Creating nonlinear solver, getting geometrical info, and setting vectors
Second order centered finite differences are used
Allocating some arrays
Masks definition
Major radius, angles, and vacuum definition
Initializing PETSc Vecs with equilibrium values
Set the initial force local vectors (used to enforce the equilibrium)
Writing the unperturbed fields
Add a coherent perturbation to the velocity
Poloidal mode number of the perturbation: m = 1
Toroidal mode number of the perturbation: n = 1
Writing the perturbed fields
Creating the matrices. This takes some time
Creating the matrices took 1.7204E+00
Entering the main MHD Loop
Iteration number = 1
Time (tau_A) = 9.99999978E-03
CPU time used for Building TotLinmat: 7.7378E-01
Total CPU time since PetscInitialize: 1.7185E+02
CPU time used for SNESSolve: 1.7011E+02
Number of linear iterations : 0
Number of function evaluations : 1
Kinetic Energy = 8.863760E-17
Magnetic Energy = 0.000000E+00
Iteration number = 2
Time (tau_A) = 1.99999998E-02
CPU time used for Building TotLinmat: 7.3685E-01
Total CPU time since PetscInitialize: 3.3283E+02
CPU time used for SNESSolve: 1.6099E+02
Exiting the main MHD Loop
Deallocating remaining arrays
Destroying remaining Petsc elements
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./mips_implicit on a arch-darwin-c-debug named iMac27Nicolas.nifs.ac.jp with 1 processor, by timotheenicolas Fri Sep 25 13:57:08 2015
Using Petsc Release Version 3.6.1, Jul, 22, 2015
Max Max/Min Avg Total
Time (sec): 3.331e+02 1.00000 3.331e+02
Objects: 7.400e+01 1.00000 7.400e+01
Flops: 3.361e+11 1.00000 3.361e+11 3.361e+11
Flops/sec: 1.009e+09 1.00000 1.009e+09 1.009e+09
Memory: 2.362e+09 1.00000 2.362e+09
MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Reductions: 0.000e+00 0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 3.3309e+02 100.0% 3.3613e+11 100.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
# WARNING!!! #
# This code was compiled with a debugging option, #
# To get timing results run ./configure #
# using --with-debugging=no, the performance will #
# be generally two or three times faster. #
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
SNESSolve 2 1.0 3.2958e+02 1.0 3.36e+11 1.0 0.0e+00 0.0e+00 0.0e+00 99100 0 0 0 99100 0 0 0 1020
SNESFunctionEval 2 1.0 3.2958e+02 1.0 3.36e+11 1.0 0.0e+00 0.0e+00 0.0e+00 99100 0 0 0 99100 0 0 0 1020
VecView 5 1.0 1.6438e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNorm 6 1.0 3.7619e-04 1.0 5.53e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1470
VecCopy 14 1.0 5.7548e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 24 1.0 2.5896e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 7 1.0 9.8065e-04 1.0 6.45e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 658
VecWAXPY 3 1.0 4.4243e-04 1.0 1.38e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 312
VecAssemblyBegin 5 1.0 1.7768e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAssemblyEnd 5 1.0 1.6867e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 4 1.0 5.7678e-04 1.0 1.84e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 320
VecScatterBegin 10 1.0 1.2419e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatSolve 2 1.0 5.8557e-01 1.0 6.31e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1077
MatLUFactorSym 1 1.0 7.7204e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
MatLUFactorNum 2 1.0 3.2121e+02 1.0 3.35e+11 1.0 0.0e+00 0.0e+00 0.0e+00 96100 0 0 0 96100 0 0 0 1044
MatAssemblyBegin 3 1.0 1.1565e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyEnd 3 1.0 3.6987e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 1.2978e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 5.1436e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSetUp 2 1.0 1.4995e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 2 1.0 3.2957e+02 1.0 3.36e+11 1.0 0.0e+00 0.0e+00 0.0e+00 99100 0 0 0 99100 0 0 0 1020
PCSetUp 2 1.0 3.2898e+02 1.0 3.35e+11 1.0 0.0e+00 0.0e+00 0.0e+00 99100 0 0 0 99100 0 0 0 1020
PCApply 2 1.0 5.8560e-01 1.0 6.31e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1077
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
SNES 1 1 1324 0
SNESLineSearch 1 1 856 0
DMSNES 2 2 1312 0
Vector 27 27 8261968 0
Vector Scatter 3 3 1944 0
MatMFFD 1 1 752 0
Matrix 3 3 1999326700 0
Distributed Mesh 3 3 14392 0
Star Forest Bipartite Graph 6 6 4928 0
Discrete System 3 3 2520 0
Index Set 11 11 519936 0
IS L to G Mapping 2 2 51920 0
Krylov Solver 2 2 2272 0
DMKSP interface 1 1 640 0
Preconditioner 2 2 1968 0
Viewer 6 5 3800 0
Average time to get PetscTime(): 2.61003e-08
#PETSc Option Table entries:
-cimplicit 1
-dt 1e-2
-fixed_dt
-ksp_monitor
-ksp_type preonly
-log_summary
-nts 2
-pc_type lu
-snes_mf
-snes_monitor
-total_matrix
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich
Libraries compiled on Thu Sep 24 09:58:51 2015 on iMac27Nicolas.nifs.ac.jp
Machine characteristics: Darwin-14.5.0-x86_64-i386-64bit
Using PETSc directory: /Users/timotheenicolas/PETSC/petsc-3.6.1
Using PETSc arch: arch-darwin-c-debug
Using C compiler: /Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/bin/mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/bin/mpif90 -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/include -I/Users/timotheenicolas/PETSC/petsc-3.6.1/include -I/Users/timotheenicolas/PETSC/petsc-3.6.1/include -I/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/include -I/opt/X11/include
Using C linker: /Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/bin/mpicc
Using Fortran linker: /Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/bin/mpif90
Using libraries: -Wl,-rpath,/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/lib -L/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/lib -lpetsc -Wl,-rpath,/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/lib -L/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/lib -lflapack -lfblas -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -lX11 -lssl -lcrypto -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/7.0.0/lib/darwin -L/Library/Developer/CommandLineTools/usr/lib/clang/7.0.0/lib/darwin -lmpifort -lgfortran -Wl,-rpath,/usr/local/lib/gcc/x86_64-apple-darwin14.0.0/5.0.0 -L/usr/local/lib/gcc/x86_64-apple-darwin14.0.0/5.0.0 -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpicxx -lc++ -Wl,-rpath,/Library/Developer/CommandLineTools/usr/bin/../lib/clang/7.0.0/lib/darwin -L/Library/Developer/CommandLineTools/usr/bin/../lib/clang/7.0.0/lib/darwin -lclang_rt.osx -Wl,-rpath,/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/lib -L/Users/timotheenicolas/PETSC/petsc-3.6.1/arch-darwin-c-debug/lib -ldl -lmpi -lpmpi -lSystem -Wl,-rpath,/Library/Developer/CommandLineTools/usr/bin/../lib/clang/7.0.0/lib/darwin -L/Library/Developer/CommandLineTools/usr/bin/../lib/clang/7.0.0/lib/darwin -lclang_rt.osx -ldl
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
Option left: name:-ksp_monitor (no value)
