[petsc-users] problem linking(?) a third party fortran code that uses petsc
Matthew Knepley
knepley at gmail.com
Thu Sep 24 19:34:19 CDT 2015
On Thu, Sep 24, 2015 at 7:21 PM, Diana Valencia <valencia at astro.utoronto.ca>
wrote:
> Hi,
> I am trying to compile a third party software written in fortran90 that
> uses petsc. There is the option of compiling the code with or without
> petsc. Without it I have no problems, however when I use petsc, I
> encounter this:
> After building the subroutines the error is:
Nowhere in this link line do I see -lpetsc. Are you sure you have this
build system configured correctly?
Matt
> gfortran -fdefault-real-8 -fdefault-double-8 -w -O2 -o stagyy main.o
> advdif.o communication.o continents.o evocore.o geometry.o init.o io.o
> iter.o melting.o miscellaneous.o MPDATA.o multi.o refstate.o phase_change.o
> poisson.o prolongate_restrict.o relax_all.o relax_cell.o relax_point.o
> residues.o tracers.o v_advection.o vee_cycle.o viscosity.o crw.o geoid.o
> implicit_diffusion.o linpack.o plot.o wrtpng.o blas123.o lapack.o
> nxs_dummy.o PETScimple_mod.o xdmf_hdf5_io_dummy.o bcs_mod.o
> composition_mod.o control_mod.o continents_mod.o vgrid_mod.o init_mod.o
> io_mod.o iter_mod.o melting_mod.o meltingfns_mod.o multi_mod.o
> phase_change_mod.o plot_mod.o precision_mod.o refstat_mod.o stencil_mod.o
> timestep_mod.o timing_mod.o tracers_mod.o viscosity_mod.o thermochem_mod.o
> platesLea_mod.o /opt/X11/lib/libpng.dylib
> Undefined symbols for architecture x86_64:
> "_kspcreate_", referenced from:
> ___petscimple_MOD_simplepetsc_create_everything in PETScimple_mod.o
> "_kspdestroy_", referenced from:
> ___petscimple_MOD_simplepetsc_destroy_everything in PETScimple_mod.o
> "_kspgetpc_", referenced from:
> ___petscimple_MOD_simplepetsc_solve in PETScimple_mod.o
> "_kspsetfromoptions_", referenced from:
> "_kspsetoperators_", referenced from:
> "_kspsettype_", referenced from:
> "_kspsolve_", referenced from:
> "_matassemblybegin_", referenced from:
> "_matassemblyend_", referenced from:
> "_matcreateseqaij_", referenced from:
> "_matdestroy_", referenced from:
> "_matsetvalues_", referenced from:
> ___petscimple_MOD_simplepetsc_insert_compactrow in PETScimple_mod.o
> "_mpi_comm_size_", referenced from:
> ___petscimple_MOD_initialize in PETScimple_mod.o
> "_pcfactorsetmatsolverpackage_", referenced from:
> "_pcsettype_", referenced from:
> "_petscfinalize_", referenced from:
> ___petscimple_MOD_finalize in PETScimple_mod.o
> "_petscinitialize_", referenced from:
> "_veccreateseqwitharray_", referenced from:
> "_vecdestroy_", referenced from:
> "_vecplacearray_", referenced from:
> "_vecresetarray_", referenced from:
> ld: symbol(s) not found for architecture x86_64
> collect2: error: ld returned 1 exit status
> make: *** [stagyy] Error 1
> My machine is OS X 10.10 and I am working with 64 bytes. I configured
> petsc with the following flags:
> ./configure --with-fc=gfortran --with-fortran-datatypes --with-x=0
> --download-mpich --download-parmetis --download-superlu
> --download-superlu_dist --download-blacs --download-scalapack
> --download-mumps --download-umfpack --download-ml --with-debugging=no
> --download-f-blas-lapack=yes
> Any help is greatly appreciated!!
> Thanks
> Diana
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150924/53dc78e3/attachment.html>
