[petsc-users] SNES stuck with small residual
Zou (Non-US), Ling ling.zou at inl.gov
Thu Sep 24 17:57:37 CDT 2015
I would suggest try '-snes_mffd_type ds' if you are using Jacobian free.
It is a magic word that always helps me out of trouble.
Ling
On Thu, Sep 24, 2015 at 4:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   I completely disagree with Matt, looking at the numbers one sees very
> typical Newton behavior
> a little slow at the beginning because it is not in the quadratic basin
> 0 SNES Function norm 5.979113140046e+02
>   1 SNES Function norm 5.106334303399e+02
>   2 SNES Function norm 4.522093337153e+02
>   3 SNES Function norm 4.042911112972e+02
>   4 SNES Function norm 3.618952927134e+02
>   5 SNES Function norm 3.239307814846e+02
>   6 SNES Function norm 2.899625386925e+02
>   7 SNES Function norm 2.596235386610e+02
>   8 SNES Function norm 2.178613867932e+02
>   9 SNES Function norm 1.541279494063e+02
>  10 SNES Function norm 1.361917300390e+02
>  suddenly fast convergence as it gets in the quadratic basin and behaves
> like Newton should behave
>  11 SNES Function norm 6.951420638296e+00
>  12 SNES Function norm 3.249486326694e-03
>  13 SNES Function norm 4.590368792536e-05
> no more convergence as it "runs out of digits"
>  14 SNES Function norm 4.422797479565e-05
>  15 SNES Function norm 4.371345326958e-05
>  16 SNES Function norm 4.348609553058e-05
>  17 SNES Function norm 4.324907311342e-05
>  18 SNES Function norm 4.324904992696e-05
>  19 SNES Function norm 4.324904992565e-05
> The only difference between this run and most other runs of Newton (when
> it works in the standard way) is that it "runs out of digits" early (after
> only reducing the residual norm by 1e-7 when for super nice problems it can
> do like 1e-12).
> I don't think your Jacobian is crap, I don't think the Jacobian direction
> is crap and the Jacobian is not not terribly ill-conditioned since the
> direct solver reduces the residual norm by 1e-8.
> My recommendation when Newton "runs out of digits" is to try using quad
> precision. With PETSc you just need a recent version of the GNU compilers
> and the configure options --with-precision=__float128
> --download-f2cblaslapack   plus you need to make sure your code always uses
> PetscReal and PetscScalar instead of "double" or whatever and whenever you
> call elementary functions like sin() you call PetscSinReal() or
> PetscSinScalar() etc so that it uses the quad precision version (if you
> miss one of these you will never see the quad precision).
>   Barry
> What does it mean for Newton to "run out of digits"; this is not a
> technical term but I believe it is related to how accurate your function
> evaluations can be (I think some people call this noise) when expressed
> using floating point numbers. Perhaps it is something like "ill-conditioned
> functions". If the function evaluations are only valid for 8 digits then it
> is not reasonable to expect Newton (or any floating point algorithm) to
> squeeze the norm of the function values to 1e.-12.
> > On Sep 24, 2015, at 5:28 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Sep 24, 2015 at 5:23 PM, Gideon Simpson <
> gideon.simpson at gmail.com> wrote:
> > Just wondering if anyone has any suggestions for this scenario:
> > I have seen this happen a bunch. Your Newton directions are crap. That
> means
> >   a) you have a crap Jacobian
> >   b) your Jacobian direction is crap (unlikely here)
> >   c) your Jacobian is very ill-conditioned
> > Something to try in order to see what is happening is to start doing
> Picard when Newton stalls. If it
> > converges, then you have something like c) I think. We can try to
> mitigate this by NPC. Something
> > as simple as Newton + NCG or Newton + NRichardson can work.
> >   Matt
> >     0 KSP preconditioned resid norm 1.609660749629e+03 true resid norm
> 5.979113140046e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.083640787055e-06 true resid norm
> 4.070012556358e-04 ||r(i)||/||b|| 6.807050579289e-07
> >     0 KSP preconditioned resid norm 1.304622870569e+03 true resid norm
> 5.106334303399e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.542022975926e-06 true resid norm
> 3.284828506619e-04 ||r(i)||/||b|| 6.432850478341e-07
> >     0 KSP preconditioned resid norm 1.017788935768e+03 true resid norm
> 4.522093337153e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.338757544659e-06 true resid norm
> 2.556045980853e-04 ||r(i)||/||b|| 5.652351223829e-07
> >     0 KSP preconditioned resid norm 7.996536035697e+02 true resid norm
> 4.042911112972e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 8.612178921208e-07 true resid norm
> 2.026756625099e-04 ||r(i)||/||b|| 5.013112008810e-07
> >     0 KSP preconditioned resid norm 6.392806337991e+02 true resid norm
> 3.618952927134e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 5.099112497936e-07 true resid norm
> 1.605851784448e-04 ||r(i)||/||b|| 4.437338138353e-07
> >     0 KSP preconditioned resid norm 5.205889419531e+02 true resid norm
> 3.239307814846e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 3.364948858968e-07 true resid norm
> 1.326652268287e-04 ||r(i)||/||b|| 4.095480714142e-07
> >     0 KSP preconditioned resid norm 4.305631057215e+02 true resid norm
> 2.899625386925e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 2.472775427751e-07 true resid norm
> 1.094956512355e-04 ||r(i)||/||b|| 3.776199909453e-07
> >     0 KSP preconditioned resid norm 3.606693697722e+02 true resid norm
> 2.596235386610e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.804499181789e-07 true resid norm
> 9.162646660567e-05 ||r(i)||/||b|| 3.529204904849e-07
> >     0 KSP preconditioned resid norm 2.791607776778e+02 true resid norm
> 2.178613867932e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.269331257925e-07 true resid norm
> 7.151934347788e-05 ||r(i)||/||b|| 3.282791160499e-07
> >     0 KSP preconditioned resid norm 1.781925534106e+02 true resid norm
> 1.541279494063e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.095285568305e-07 true resid norm
> 4.530373014757e-05 ||r(i)||/||b|| 2.939358521416e-07
> >     0 KSP preconditioned resid norm 4.801281559143e+01 true resid norm
> 1.361917300390e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.158004981151e-07 true resid norm
> 1.216364616255e-05 ||r(i)||/||b|| 8.931266354477e-08
> >     0 KSP preconditioned resid norm 2.808725633599e+00 true resid norm
> 6.951420638296e+00 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 2.361764665651e-09 true resid norm
> 7.088079744061e-07 ||r(i)||/||b|| 1.019659162188e-07
> >     0 KSP preconditioned resid norm 1.388995922430e-03 true resid norm
> 3.249486326694e-03 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 1.757348050151e-12 true resid norm
> 3.473453149942e-10 ||r(i)||/||b|| 1.068923762322e-07
> >     0 KSP preconditioned resid norm 4.360884570719e-06 true resid norm
> 4.590368792536e-05 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 3.926789585311e-15 true resid norm
> 1.102338507065e-12 ||r(i)||/||b|| 2.401416001385e-08
> >     0 KSP preconditioned resid norm 5.831925614907e-06 true resid norm
> 4.422797479565e-05 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 5.584144701532e-15 true resid norm
> 1.478006791605e-12 ||r(i)||/||b|| 3.341791701821e-08
> >     0 KSP preconditioned resid norm 4.897666437748e-06 true resid norm
> 4.371345326958e-05 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 4.080247182926e-15 true resid norm
> 1.236587295819e-12 ||r(i)||/||b|| 2.828848336902e-08
> >     0 KSP preconditioned resid norm 3.738450099362e-06 true resid norm
> 4.348609553058e-05 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 3.655406222015e-15 true resid norm
> 9.403440338690e-13 ||r(i)||/||b|| 2.162401619174e-08
> >     0 KSP preconditioned resid norm 5.296206632183e-06 true resid norm
> 4.324907311342e-05 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 5.018283198612e-15 true resid norm
> 1.334862856428e-12 ||r(i)||/||b|| 3.086454252850e-08
> >     0 KSP preconditioned resid norm 5.289306428405e-06 true resid norm
> 4.324904992696e-05 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 5.691985954854e-15 true resid norm
> 1.335680822478e-12 ||r(i)||/||b|| 3.088347200075e-08
> >     0 KSP preconditioned resid norm 5.289311834250e-06 true resid norm
> 4.324904992565e-05 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP preconditioned resid norm 5.455286406170e-15 true resid norm
> 1.337387995906e-12 ||r(i)||/||b|| 3.092294508677e-08
> > At this point, it terminates with a diverged line search.
> > -gideon
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150924/c65bbbf1/attachment.html>
