[petsc-users] number of converged eigenpairs
Jose E. Roman jroman at dsic.upv.es
Thu Sep 24 15:50:25 CDT 2015
By default only 1 eigenpair is computed. Use EPSSetDimensions() to specify how many eigenvalues you want. This is explained in the manual in basic examples.
http://slepc.upv.es/documentation/current/docs/manualpages/EPS/EPSSetDimensions.html
SLEPc is not intended for computing all eigenvalues. If you need all eigenvalues you should use another software.
In your code, the computed eigenvalues are those closest to the target.
Jose
> El 24/9/2015, a las 18:01, Soumya Mukherjee <soumyamechanics at gmail.com> escribió:
>  Hi.
> The following code generates nconv numbers of eigenpairs. This number, for my case is so few. And I am afraid, there are more important eigenmodes. Is it possible to generate all (or more) eigenpairs?
> Also, I was wondering, which eigenvalues/ eigenvectors does it calculate in this code, whose number is given by nconv?
>     MatCreateSeqAIJ( MPI_COMM_SELF, Natom * Norbit, Natom * Norbit, Nneighbor * Norbit, PETSC_NULL, &H );
>     MatSetFromOptions( H );
>     MatCreateSeqAIJ( MPI_COMM_SELF, Natom * Norbit, Natom * Norbit, Nneighbor * Norbit, PETSC_NULL, &S );
>     MatSetFromOptions( S );
> 	Hamiltonian ( );
> //	MatView(H,PETSC_VIEWER_STDOUT_WORLD);
> //	VecView(H0,PETSC_VIEWER_STDOUT_WORLD);
>     /*Setup the Ax=cBx generalized eigenproblem*/
>     EPSCreate( PETSC_COMM_WORLD, &eps );
>     EPSSetOperators( eps, H, S);
>     MatGetVecs(H,NULL,&xr);
>     MatGetVecs(H,NULL,&xi);
>     EPSGetST( eps, &st);
>     STSetType(st,STCAYLEY);
>     STCayleySetAntishift(st,1);
>     EPSSetDimensions( eps, nev, ncv, PETSC_DECIDE);
>     EPSSetTarget( eps,5.0);
>     EPSSetFromOptions( eps );
>     EPSSolve( eps );
>     EPSPrintSolution(eps,PETSC_NULL);
>     EPSGetConverged( eps, &nconv );
>     eigenval = new complex<double>[ nconv ];
>     eigenvec = new complex<double>*[ nconv ];
>     for (int i = 0; i < nconv; i ++ ) {
>         eigenvec[ i ] = new complex<double>[ Norbit * Natom ];
>     for ( jjj = 0; jjj < nconv; jjj ++ ) {
>         /*		Get converged eigenpairs: j-th eigenvalue is stored in kr (real part) and ki (imaginary part)	*/
>         EPSGetEigenpair(eps, jjj, &kr, &ki, xr, xi);
>         eigenval[ jjj ] = complex <double>(PetscRealPart(kr),PetscImaginaryPart(kr));
>         VecGetArray(xr, &Xr);
>         for ( int i = 0; i < Norbit * Natom; i ++ ) {
>             eigenvec[ jjj ][ i ] = complex <double>(PetscRealPart(Xr[i]),PetscImaginaryPart(Xr[i]));
>         VecRestoreArray(xr, &Xr);
> 	/*finalizing*/
> 	outputs( true );
>     VecDestroy(&xr);
>     VecDestroy(&xi);
>     EPSDestroy(&eps);
>     MatDestroy(&H);
>     MatDestroy(&S);
>     SlepcFinalize();
>     PetscFinalize();
> 	return 0;
> Regards,
> Soumya
