[petsc-users] Insert values into matrix using MatSetValuesStencil
TAY wee-beng zonexo at gmail.com
Wed Sep 23 04:13:09 CDT 2015
Hi Timothée,
Maybe I can send you part of it 1st. I'm trying to pinpoint why my
matrix using MatView shows zero for a lot of the values
For i=1,j=1,k=1,
It should be :
Mat Object: 1 MPI processes
   type: seqaij
row 0: (0, 2)  (12, -2)
but now it's:
row 0: (0, 0)  (1, 0)  (2, 0)  (3, 0)  (4, 0)  (5, 0)  (6, 0)  (7, 0)
(8, 0)  (12, 0)  (13, 0)  (14, 0)  (24, 0)  (25, 0)  (26, 0) (96, 0)
(97, 0)  (98, 0)  (192, 0)  (193, 0)  (194, 0)
I used:
/call
DMDACreate3d(MPI_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&//
//size_z,1,PETSC_DECIDE,PETSC_DECIDE,3,stencil_width,lx,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da_uvw_ast,ierr)//
//call DMSetMatType(da_uvw_ast,MATAIJ,ierr)//
//    call DMCreateMatrix(da_uvw_ast,A_semi_xyz,ierr)//
//    call MatSetFromOptions(A_semi_xyz,ierr)//
//i = 1, j = 1, k = 1//
//row(MatStencil_i,1) = i - 1//
//                    row(MatStencil_j,1) = j - 1//
//                    row(MatStencil_k,1) = k - 1//
//                    row(MatStencil_c,1) = 0//
//                    col(MatStencil_i,1) = i - 1//
//                    col(MatStencil_j,1) = j - 1//
//                    col(MatStencil_k,1) = k - 1//
//                    col(MatStencil_c,1) = 0//
//                    value_insert(1) = 2.//
//                    call
MatSetValuesStencil(A_mat,ione,row,ione,col(:,1),value_insert(1),INSERT_VALUES,ierr)//
//                    col(MatStencil_i,2) = i - 1 !north//
//                    col(MatStencil_j,2) = j + 1 - 1//
//                    col(MatStencil_k,2) = k - 1//
//                    col(MatStencil_c,2) = 0//
//                    value_insert(2) = -2.//
//                    call
MatSetValuesStencil(A_mat,ione,row,ione,col(:,2),value_insert(2),INSERT_VALUES,ierr)/
Thank you
Yours sincerely,
TAY wee-beng
On 23/9/2015 4:45 PM, Timothée Nicolas wrote:
> Yes, I had understood that, I am doing the same, but with 8 dof. This
> does not change the declaration for row and col.
> Can you send (i) the commands you use to create the DMDA, (ii) the
> commands to create the matrix and (iii) those for the definitions of
> ksta2,kend2,jsta2,jend2,size_x ?
> Timothée
> 2015-09-23 17:37 GMT+09:00 TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>>:
>     Hi Timothée,
>     The matrix is created with 3 dof - u,v,w. So for each i,j,k, there
>     are 3 values. Actually I got 3 eqns from the u,v,w momentum eqns.
>     They are not coupled together so I can also solve them
>     individually. But I was told it's faster to group them together.
>     The global indices is something like this:
>     i, j, k, ijk global indices, dof
>     1 1 1 1 u
>     1 1 1 2 v
>     1 1 1 3 w
>     2 1 1 4 u
>     Hope it's clearer now.
>     Ok, I changed the stencil, it's now working.
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
>     On 23/9/2015 4:22 PM, Timothée Nicolas wrote:
>>     Can you also tell how you created the matrix ? Just in case you
>>     created it with the 1 dof DMDA, it would not work if you try to
>>     input values at places where it is not allocated (which could
>>     explain the error message)
>>     2015-09-23 17:18 GMT+09:00 Timothée Nicolas
>>     <timothee.nicolas at gmail.com <mailto:timothee.nicolas at gmail.com>>:
>>         The first thing that strikes me is your definition of the
>>         stencils
>>         */MatStencil  :: row(6,1),col(6,7)/**/
>>         Why is it not defined with
>>         */MatStencil  :: row(4,1),col(4,7)/**/
>>         instead ?
>>         Where does the 6 come from ?
>>         Timothée
>>         2015-09-23 17:14 GMT+09:00 TAY wee-beng <zonexo at gmail.com
>>             Hi,
>>             I have successfully used MatSetValuesStencil to insert
>>             values into a Poisson eqn matrix which has 1 DOF
>>             (pressure). Now I'm trying to insert values in a momentum
>>             eqn matrix which has 3 DOF (u,v,w)
>>             However, I got the error:
>>             /*[0]PETSC ERROR: --------------------- Error Message
>>             *//*[0]PETSC ERROR: Argument out of range*//*
>>             *//*[0]PETSC ERROR: Inserting a new nonzero at (111,5) in
>>             the matrix*//*
>>             *//*[0]PETSC ERROR: See
>>             http://www.mcs.anl.gov/petsc/documentation/faq.html for
>>             trou*//*
>>             *//*ble shooting.*/
>>             I wonder what's wrong.  For the momentum eqn, for each
>>             DOF, at at node (dof,i,j,k), I have coupling i +/- 1, j
>>             +/- 1 and k +/- 1.
>>             The error happens at 111,5, which corresponds to i = 2, j
>>             = 2, k = 2, which is an internal node.
>>             Here's part of my code below. Hope someone can help. Thanks!
>>             /**/PetscScalar :: value_insert(7)/**/
>>             /**/MatStencil  :: row(6,1),col(6,7)/**/
>>             /**/ione = 1;   iseven = 7/**/
>>             /**/if (cell_type == 'u') then/**/
>>             /**/    offset = 1/**/
>>             /**/else if (cell_type == 'v') then/**/
>>             /**/    offset = 2/**/
>>             /**/else if (cell_type == 'w') then/**/
>>             /**/    offset = 3/**/
>>             /**/end if/**/
>>             /**/do k=ksta2,kend2/**/
>>             /**/    do j = jsta2,jend2/**/
>>             /**/        do i=2,size_x-1/**/
>>             /**/row(MatStencil_i,1) = i - 1/**/
>>             /**/row(MatStencil_j,1) = j - 1/**/
>>             /**/row(MatStencil_k,1) = k - 1/**/
>>             /**/row(MatStencil_c,1) = offset - 1/**/
>>             /**/value_insert = 0.d0/**/
>>             /**/col(MatStencil_i,3) = i + 1 - 1 !east/**/
>>             /**/col(MatStencil_j,3) = j - 1/**/
>>             /**/col(MatStencil_k,3) = k - 1/**/
>>             /**/col(MatStencil_c,3) = offset - 1/**/
>>             /**/value_insert(3) = -(
>>             1./(cell_x(i)%pd_E+cell_x(i+1)%pd_W))*(c_yz(j,k)%fc_E)*inv_Re/**/
>>             /**/col(MatStencil_i,5) = i - 1 - 1 !west/**/
>>             /**/col(MatStencil_j,5) = j - 1/**/
>>             /**/col(MatStencil_k,5) = k - 1/**/
>>             /**/col(MatStencil_c,5) = offset - 1/**/
>>             /**/value_insert(5) = -(
>>             1./(cell_x(i)%pd_W+cell_x(i-1)%pd_E))*(c_yz(j,k)%fc_E)*inv_Re/**/
>>             /**/col(MatStencil_i,2) = i - 1 !north/**/
>>             /**/col(MatStencil_j,2) = j + 1 - 1/**/
>>             /**/col(MatStencil_k,2) = k - 1/**/
>>             /**/col(MatStencil_c,2) = offset - 1/**/
>>             /**/value_insert(2) = -(
>>             1./(cell_y(j)%pd_N+cell_y(j+1)%pd_S))*(c_zx(i,k)%fc_N)*inv_Re/**/
>>             /**/col(MatStencil_i,4) = i - 1 !south/**/
>>             /**/col(MatStencil_j,4) = j - 1 - 1/**/
>>             /**/col(MatStencil_k,4) = k - 1/**/
>>             /**/col(MatStencil_c,4) = offset - 1/**/
>>             /**/value_insert(4) = -(
>>             1./(cell_y(j)%pd_S+cell_y(j-1)%pd_N))*(c_zx(i,k)%fc_N)*inv_Re/**/
>>             /**/col(MatStencil_i,6) = i - 1 !front/**/
>>             /**/col(MatStencil_j,6) = j - 1/**/
>>             /**/col(MatStencil_k,6) = k + 1 - 1/**/
>>             /**/col(MatStencil_c,6) = offset - 1/**/
>>             /**/value_insert(6) = -(
>>             1./(cell_z(k)%pd_F+cell_z(k+1)%pd_B))*(c_xy(i,j)%fc_F)*inv_Re/**/
>>             /**/col(MatStencil_i,7) = i - 1 !back/**/
>>             /**/col(MatStencil_j,7) = j - 1/**/
>>             /**/col(MatStencil_k,7) = k - 1 - 1/**/
>>             /**/col(MatStencil_c,7) = offset - 1/**/
>>             /**/value_insert(7) = -(
>>             1./(cell_z(k)%pd_B+cell_z(k-1)%pd_F))*(c_xy(i,j)%fc_F)*inv_Re/**/
>>             /**/col(MatStencil_i,1) = i - 1/**/
>>             /**/col(MatStencil_j,1) = j - 1/**/
>>             /**/col(MatStencil_k,1) = k - 1/**/
>>             /**/col(MatStencil_c,1) = offset - 1/**/
>>             /**/value_insert(1) = 2.*c(i,j,k)%vol/del_t -
>>             (value_insert(2)+value_insert(3)+value_insert(4)+value_insert(5)+value_insert(6)+value_insert(7))/**/
>>             /**/            call
>>             MatSetValuesStencil(A_semi_xyz,ione,row,iseven,col,value_insert,INSERT_VALUES,ierr)/**/
>>             /**/        end do/**/
>>             /**/    end do/**/
>>             /**/end do /*
>>             Thank you
>>             Yours sincerely,
>>             TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150923/529deb3c/attachment-0001.html>
