[petsc-users] PETSC error: Caught signal number 8 FPE
Soumya Mukherjee
soumyamechanics at gmail.com
Mon Sep 21 22:59:20 CDT 2015
Hi.
I am trying to solve an eigenvalue problem. I have a code that works for a
particular input file. And, whenever I change the input file, the following
error message appears. Any hint for debugging, please?
PETSC ERROR:
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] EPSGetConverged line 233
/home/soumya/slepc-3.6.0/src/eps/interface/epssolve.c
[0]PETSC ERROR: [0] EPSErrorView line 447
/home/soumya/slepc-3.6.0/src/eps/interface/epsview.c
[0]PETSC ERROR: [0] MatLUFactorSymbolic_SeqAIJ line 295
/home/soumya/petsc-3.6.1/src/mat/impls/aij/seq/aijfact.c
[0]PETSC ERROR: [0] MatLUFactorSymbolic line 2877
/home/soumya/petsc-3.6.1/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] PCSetUp_LU line 99
/home/soumya/petsc-3.6.1/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: [0] PCSetUp line 944
/home/soumya/petsc-3.6.1/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: [0] KSPSetUp line 247
/home/soumya/petsc-3.6.1/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: [0] STSetUp_Cayley line 161
/home/soumya/slepc-3.6.0/src/sys/classes/st/impls/cayley/cayley.c
[0]PETSC ERROR: [0] STSetUp line 273
/home/soumya/slepc-3.6.0/src/sys/classes/st/interface/stsolve.c
[0]PETSC ERROR: [0] EPSSetUp line 58
/home/soumya/slepc-3.6.0/src/eps/interface/epssetup.c
[0]PETSC ERROR: [0] EPSSolve line 83
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.6.1, Jul, 22, 2015
[0]PETSC ERROR: ./main on a arch-linux2-cxx-debug named
soumya-OptiPlex-9010 by soumya Mon Sep 21 21:36:29 2015
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
--with-cxx=g++ --with-clanguage=cxx --download-fblaslapack --download-mpich
--with-scalar-type=complex
[0]PETSC ERROR: #12 User provided function() line 0 in unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: aborting job:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150921/8a02172d/attachment.html>
