[petsc-users] gamg and zero pivots
Gideon Simpson
gideon.simpson at gmail.com
Sat Sep 19 18:10:43 CDT 2015
It gives zero pivots on:
-ksp_type gmres -pc_type gamg -mg_coarse_sub_pc_factor_shift_type NONZERO
It has no problem with:
-ksp_type gmres -pc_type bjacobi -sub_pc_factor_shift_type NONZERO
-gideon
> On Sep 19, 2015, at 12:37 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Sep 18, 2015, at 10:42 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>> I’m getting a zero pivot in LU factorization error when I use the gamg preconditioner. I know there is some issue with my matrix, as I get the same error if I use pc_type lu in serial, or if I use pc_type bjacobi in parallel, both of which are corrected by adding -pc_factor_shift_type NONZERO -sub_pc_factor_shift_type NONZERO, respectively. However, I can’t quite seem to figure out the analogous command to use for the gamg preconditioner.
> You need to figure out the prefix to the option that is added by gamg to set it. One way is to run with the gamg options and -help and grep for factor_shift.
> The option is like something like -mg_coarse_pc_factor_shift_type nonzero or -mg_coarse_sub_pc_factor_shift_type
> Barry
>> -gideon
