[petsc-users] Release object
Sang pham van
pvsang002 at gmail.com
Thu Sep 17 19:12:56 CDT 2015
I have the below code section, every time it runs through this section,
used memory increases very much and not decreases then. Could you please
let me know what object did I forgot to release in the for-loop?
Many thanks.
PVS
int mu_x[20]={0,1,0,0,2,0,0,1,0,1,3,0,0,2,2,1,0,1,0,1};
int mu_y[20]={0,0,1,0,0,2,0,1,1,0,0,3,0,1,0,2,2,0,1,1};
int mu_z[20]={0,0,0,1,0,0,2,0,1,1,0,0,3,0,1,0,1,2,2,1};
for (int ib=0;ib<isur->BIPoints.N;ib++)
Mat W,V;
int Mm = isur->iSolidCellsNearBIPoint[ib+1] -
isur->iSolidCellsNearBIPoint[ib];
PetscScalar val=0;
MatCreateSeqAIJ(PETSC_COMM_SELF,Mm,Mm,Mm,NULL,&W);
MatCreateSeqAIJ(PETSC_COMM_SELF,Mm,L3D,L3D,NULL,&V);
double xm, ym, zm, dm;
for (int i=0;i<Mm;i++)
xm =
Mesh->Cells[isur->SolidCellsNearBIPoint[isur->iSolidCellsNearBIPoint[ib]+i]].Cen.xyz[0]
- isur->BIPoints.x[ib];
ym =
Mesh->Cells[isur->SolidCellsNearBIPoint[isur->iSolidCellsNearBIPoint[ib]+i]].Cen.xyz[1]
- isur->BIPoints.y[ib];
zm =
Mesh->Cells[isur->SolidCellsNearBIPoint[isur->iSolidCellsNearBIPoint[ib]+i]].Cen.xyz[2]
- isur->BIPoints.z[ib];
dm = sqrt(xm*xm+ym*ym+zm*zm);
val = WeightFunc(dm,isur->R_solid[ib]);
MatSetValue(W,i,i,val,INSERT_VALUES);
MatAssemblyBegin(W,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(W,MAT_FINAL_ASSEMBLY);
for (int j=0;j<L3D;j++)
xm =
ym =
zm =
val = power(xm,mu_x[j])*power(ym,mu_y[j])*power(zm,mu_z[j]);
MatSetValue(V,i,j,val,INSERT_VALUES);
MatAssemblyBegin(V,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(V,MAT_FINAL_ASSEMBLY);
//if(ib==13) MatView(V,PETSC_VIEWER_STDOUT_SELF);
/// Solve least square problem:
Mat Amat,W2,VtW2,VtW2V,invVtW2V, VtW2V1Vt,I,invVtW2V_b;
MatDuplicate(W,MAT_DO_NOT_COPY_VALUES,&W2);
MatDuplicate(W2,MAT_DO_NOT_COPY_VALUES,&VtW2);
MatDuplicate(W2,MAT_DO_NOT_COPY_VALUES,&VtW2V);
MatMatMult(W,W,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&W2);
MatTransposeMatMult(V,W2,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&VtW2);
MatMatMult(VtW2,V,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&VtW2V);
MatCreateSeqDense(PETSC_COMM_SELF,L3D,L3D,NULL,&I);
MatDuplicate(I,MAT_DO_NOT_COPY_VALUES,&invVtW2V);
Vec ivec;
VecCreateSeq(PETSC_COMM_SELF,L3D,&ivec);
VecSet(ivec,1.0);
MatDiagonalSet(I,ivec,INSERT_VALUES);
IS rperm,cperm;
MatFactorInfo info;
MatGetOrdering(VtW2V, MATORDERINGNATURAL, &rperm, &cperm);
MatFactorInfoInitialize(&info);
MatLUFactor(VtW2V, rperm, cperm, &info);
MatMatSolve(VtW2V,I,invVtW2V);
MatConvert(invVtW2V,MATSEQAIJ,MAT_INITIAL_MATRIX,&invVtW2V_b);
MatMatTransposeMult(invVtW2V_b,V,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&VtW2V1Vt);
MatMatMult(VtW2V1Vt,W2,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&Amat);
for (int i=0;i<L3D;i++)
for (int j=0;j<Mm;j++)
MatGetValues(Amat,1,&i,1,&j,&A[ib][i][j]);
MatDestroy(&W2);
MatDestroy(&Amat);
MatDestroy(&VtW2);
MatDestroy(&VtW2V);
MatDestroy(&invVtW2V);
MatDestroy(&invVtW2V_b);
MatDestroy(&VtW2V1Vt);
MatDestroy(&I);
MatDestroy(&W);
MatDestroy(&V);
VecDestroy(&ivec);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150918/7aa2f9a9/attachment.html>
