[petsc-users] TaoSetVariableBounds in petsc4py
Justin Chang
jychang48 at gmail.com
Thu Sep 17 16:00:47 CDT 2015
Matt,
This is the error I get if I use None:
Traceback (most recent call last):
File "2D_plume_ADR_ex1.py", line 146, in <module>
tao_D.setVariableBounds(lb_vec,None)
File "PETSc/TAO.pyx", line 198, in petsc4py.PETSc.TAO.setVariableBounds
(src/petsc4py.PETSc.c:189484)
TypeError: Cannot convert NoneType to petsc4py.PETSc.Vec
Justin
On Thu, Sep 17, 2015 at 2:59 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Sep 17, 2015 at 3:55 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> Hi all,
>> I am attempting to use TaoSetVariableBounds via petsc4py. Is there a way
>> to set only lower bounds or upper bounds and not both? In PETSc I could
>> replace one of the Vecs with NULL, but how would I do that with
>> tao.setVariableBounds(...)?
>> It seems right now I can only do tao.setVariableBounds(lb_vec,ub_vec),
>> and from inspection of the python source code, it seems I have to specify
>> both?
> Can you jsut give None?
> Matt
>> Thanks,
>> Justin
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150917/8cc8b4e8/attachment.html>
