[petsc-users] conditioning of snes with dmcomposite & grid sequencing
Matthew Knepley
knepley at gmail.com
Sat Sep 12 13:57:40 CDT 2015
On Sat, Sep 12, 2015 at 1:54 PM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> I’m not sure how good a problem this would be as a toy model, but, once
> this is all done, I’d be happy to share the code.
> I’ve got a few comments on this:
> 1. The underlying problem is in the study of derivative nonlinear
> Schrödinger equations - see http://arxiv.org/abs/1301.1048 for details of
> the equation. The problem has features of the Airy equation, which as
> you’d guess, has exactly this problem of highly oscillatory structures
> which don’t get along with linear interpolation.
> 2. The problem is complex valued with a real and imaginary components at
> each site on the mesh. At the origin, the boundary conditions are
> Dirichlet on the imaginary component, and Neumann on the real component.
> This led me to make the value of the real component at the origin, u0, one
> of the three parameters in the first component of the DMComposite
> structure. Consequently, (u0, 0), the values of the function at the
> origin, should be involved in the interpolation strategy. Is there a way,
> through ghost points, for the current DM interpolation strategy to make use
> of these under refinement? Does it use ghost point values?
> 3. Is DMShellSetCreateInterpolation what I want to use here? Where I
> would define my own interpolation strategy across dm’s?
Ah, crap. This breaks the current DMComposite interpolation (in packm.c),
which assumes that it is block diagonal. However, it produces
a MatNest object, so we could conceivably just stick in another block, but
that would not be general in any sense.
Matt
> -gideon
> On Sep 12, 2015, at 2:36 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Sep 12, 2015 at 1:26 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
>> Got it. I wanted to follow up on something that I had been suspicious of
>> for some time. I took my initial solution, the one which we want to apply
>> grid sequencing to, and did the following. I loved into spicy, and
>> manually did grid refinement using SciPy, dumped to disk, and then ran that
>> through petsc, with the refined mesh. When I say “manual” here, I just
>> mean that I called the SciPy spline interplant commands on uniform meshes
>> that had twice the resolution, not that I manually picked out the
>> refinement points. When I use a linear interpolant, and run my solver on
>> it, it fails miserably, just as the first grid sequence refinement does.
>> The numbers are a little different, but the residuals are still O(100).
>> If, instead, I use a second order interpolant, it solves it 11
>> iterations, wiithout a problem, and the result is physically consistent.
>> While this may be two sides of the same coin, it makes me think that the
>> real challenge in my is the interpolation strategy used under grid
>> refinement. Is there a way to, manually, I suppose, set the interpolation
>> that will be used under the grid sequence?
> Excellent! And also somewhat bizarre. This would be great to analyze. Is
> there any bribe we could give you to
> convert this to a real PETSc example? It would be a nice way to show that
> dumping in high frequency energy
> when interpolating can be bad for coupled problems.
> Actual Solution: I think this will involve some coding. The quick and
> dirty way is to just stick the code you want
> into dainterp.c:DMCreateInterpolation_DA(). If that works, we add it to
> interptype and enable it from the command
> line. It would be nice to have a spline interpolant.
> Thanks,
> Matt
>> -gideon
>> On Sep 12, 2015, at 7:14 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Sep 11, 2015 at 4:30 PM, Gideon Simpson <gideon.simpson at gmail.com
>> > wrote:
>>> Are there any built in routines for freezing variables in SNES, or will
>>> that need to be handled by hand.
>> We used to have this for KSP, but it looks like someone removed it. The
>> only thing left is KSPMonitorRange().
>> What we did is find the few largest residual elements, take a small halo
>> around them, project the problem to this
>> small space using MatGetSubMatrix() and VecScatter, solve, and VecScatter
>> back.
>> We do not have this for nonlinear stuff (like many other things) because
>> there is no explicit matrix to manipulate,
>> and language support for computing only parts of the nonlinear function
>> is really weak. What we really want
>> is something like what Victor Eijkout was proposing a few years ago,
>> namely automatic discovery of index sets
>> for communication, in this case with main memory. We would need the
>> residual code, given an output set, to tell
>> us what input set is needed. Then we make a Scatter, select part of the
>> DM, and we could compute. Now it has
>> to be done by hand.
>> Thanks,
>> Matt
>>> Also, I remain curious about the starting guess that the grid sequence
>>> uses during each refinement. Is there a way to dump those to disk for
>>> inspection?
>>> -gideon
>>> On Sep 11, 2015, at 4:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Sep 11, 2015 at 1:05 PM, Gideon Simpson <
>>> gideon.simpson at gmail.com> wrote:
>>>> Since the problem has not only the two components in the DM, but the
>>>> second component has 4 degrees of freedom per mesh point, I thought it best
>>>> to do the post processing separately. See attached
>>> So the whole thing is being controlled by 1 variable.
>>> We should try freezing everything else, and just solving that scalar
>>> equation I guess.
>>> Matt
>>>> -gideon
>>>> <Screen Shot 2015-09-11 at 2.04.25 PM.png>
>>>> On Sep 11, 2015, at 10:16 AM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>> On Fri, Sep 11, 2015 at 9:08 AM, Gideon Simpson <
>>>>> Following up on the previous thread, for my dm composite problem, I
>>>>> find that at the end of the first grid sequence,where it fails to converge,
>>>>> the distribution of the norms between the two pieces are:
>>>>> 39 SNES Function norm 2.253098577796e+02
>>>>> 40 SNES Function norm 2.253098577331e+02
>>>>> 41 SNES Function norm 2.253098577228e+02
>>>>> 42 SNES Function norm 2.253098577212e+02
>>>>> 43 SNES Function norm 2.253098577174e+02
>>>>> 44 SNES Function norm 2.253098577166e+02
>>>>> 45 SNES Function norm 2.253098577158e+02
>>>>> 46 SNES Function norm 2.253098577157e+02
>>>>> 47 SNES Function norm 2.253098577156e+02
>>>>> 48 SNES Function norm 2.253098577156e+02
>>>>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH
>>>>> iterations 48
>>>>> ||r|| = 225.31, 7999 entries
>>>>> ||rp|| = 140.021, 3 entries
>>>>> ||rQ|| = 176.518, 7996 entries
>>>>> Since I think we were convinced that this was intrinsic to the
>>>>> problem, and not a function of the Jacobian function, I am using my
>>>>> Jacobian.
>>>> Okay, I see no pattern in the fields. Lets plot these 2 vectors,
>>>> -vec_view draw, and screenshot.
>>>> Matt
>>>>> -gideon
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150912/ed10f398/attachment-0001.html>
