[petsc-users] conditioning of snes with dmcomposite & grid sequencing
Matthew Knepley
knepley at gmail.com
Sat Sep 12 13:36:57 CDT 2015
On Sat, Sep 12, 2015 at 1:26 PM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> Got it. I wanted to follow up on something that I had been suspicious of
> for some time. I took my initial solution, the one which we want to apply
> grid sequencing to, and did the following. I loved into spicy, and
> manually did grid refinement using SciPy, dumped to disk, and then ran that
> through petsc, with the refined mesh. When I say “manual” here, I just
> mean that I called the SciPy spline interplant commands on uniform meshes
> that had twice the resolution, not that I manually picked out the
> refinement points. When I use a linear interpolant, and run my solver on
> it, it fails miserably, just as the first grid sequence refinement does.
> The numbers are a little different, but the residuals are still O(100).
> If, instead, I use a second order interpolant, it solves it 11 iterations,
> wiithout a problem, and the result is physically consistent. While this
> may be two sides of the same coin, it makes me think that the real
> challenge in my is the interpolation strategy used under grid refinement.
> Is there a way to, manually, I suppose, set the interpolation that will be
> used under the grid sequence?
Excellent! And also somewhat bizarre. This would be great to analyze. Is
there any bribe we could give you to
convert this to a real PETSc example? It would be a nice way to show that
dumping in high frequency energy
when interpolating can be bad for coupled problems.
Actual Solution: I think this will involve some coding. The quick and dirty
way is to just stick the code you want
into dainterp.c:DMCreateInterpolation_DA(). If that works, we add it to
interptype and enable it from the command
line. It would be nice to have a spline interpolant.
Matt
> -gideon
> On Sep 12, 2015, at 7:14 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 11, 2015 at 4:30 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
>> Are there any built in routines for freezing variables in SNES, or will
>> that need to be handled by hand.
> We used to have this for KSP, but it looks like someone removed it. The
> only thing left is KSPMonitorRange().
> What we did is find the few largest residual elements, take a small halo
> around them, project the problem to this
> small space using MatGetSubMatrix() and VecScatter, solve, and VecScatter
> back.
> We do not have this for nonlinear stuff (like many other things) because
> there is no explicit matrix to manipulate,
> and language support for computing only parts of the nonlinear function is
> really weak. What we really want
> is something like what Victor Eijkout was proposing a few years ago,
> namely automatic discovery of index sets
> for communication, in this case with main memory. We would need the
> residual code, given an output set, to tell
> us what input set is needed. Then we make a Scatter, select part of the
> DM, and we could compute. Now it has
> to be done by hand.
> Thanks,
> Matt
>> Also, I remain curious about the starting guess that the grid sequence
>> uses during each refinement. Is there a way to dump those to disk for
>> inspection?
>> -gideon
>> On Sep 11, 2015, at 4:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Sep 11, 2015 at 1:05 PM, Gideon Simpson <gideon.simpson at gmail.com
>> > wrote:
>>> Since the problem has not only the two components in the DM, but the
>>> second component has 4 degrees of freedom per mesh point, I thought it best
>>> to do the post processing separately. See attached
>> So the whole thing is being controlled by 1 variable.
>> We should try freezing everything else, and just solving that scalar
>> equation I guess.
>> Matt
>>> -gideon
>>> <Screen Shot 2015-09-11 at 2.04.25 PM.png>
>>> On Sep 11, 2015, at 10:16 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Sep 11, 2015 at 9:08 AM, Gideon Simpson <
>>> gideon.simpson at gmail.com> wrote:
>>>> Following up on the previous thread, for my dm composite problem, I
>>>> find that at the end of the first grid sequence,where it fails to converge,
>>>> the distribution of the norms between the two pieces are:
>>>> 39 SNES Function norm 2.253098577796e+02
>>>> 40 SNES Function norm 2.253098577331e+02
>>>> 41 SNES Function norm 2.253098577228e+02
>>>> 42 SNES Function norm 2.253098577212e+02
>>>> 43 SNES Function norm 2.253098577174e+02
>>>> 44 SNES Function norm 2.253098577166e+02
>>>> 45 SNES Function norm 2.253098577158e+02
>>>> 46 SNES Function norm 2.253098577157e+02
>>>> 47 SNES Function norm 2.253098577156e+02
>>>> 48 SNES Function norm 2.253098577156e+02
>>>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations
>>>> 48
>>>> ||r|| = 225.31, 7999 entries
>>>> ||rp|| = 140.021, 3 entries
>>>> ||rQ|| = 176.518, 7996 entries
>>>> Since I think we were convinced that this was intrinsic to the problem,
>>>> and not a function of the Jacobian function, I am using my Jacobian.
>>> Okay, I see no pattern in the fields. Lets plot these 2 vectors,
>>> -vec_view draw, and screenshot.
>>> Matt
>>>> -gideon
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150912/122cf84d/attachment-0001.html>
