[petsc-users] conditioning of snes with dmcomposite & grid sequencing
Gideon Simpson
gideon.simpson at gmail.com
Fri Sep 11 16:30:22 CDT 2015
Are there any built in routines for freezing variables in SNES, or will that need to be handled by hand.
Also, I remain curious about the starting guess that the grid sequence uses during each refinement. Is there a way to dump those to disk for inspection?
-gideon
> On Sep 11, 2015, at 4:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 11, 2015 at 1:05 PM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
> Since the problem has not only the two components in the DM, but the second component has 4 degrees of freedom per mesh point, I thought it best to do the post processing separately. See attached
> So the whole thing is being controlled by 1 variable.
> We should try freezing everything else, and just solving that scalar equation I guess.
> Matt
> -gideon
> <Screen Shot 2015-09-11 at 2.04.25 PM.png>
>> On Sep 11, 2015, at 10:16 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Fri, Sep 11, 2015 at 9:08 AM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
>> Following up on the previous thread, for my dm composite problem, I find that at the end of the first grid sequence,where it fails to converge, the distribution of the norms between the two pieces are:
>> 39 SNES Function norm 2.253098577796e+02
>> 40 SNES Function norm 2.253098577331e+02
>> 41 SNES Function norm 2.253098577228e+02
>> 42 SNES Function norm 2.253098577212e+02
>> 43 SNES Function norm 2.253098577174e+02
>> 44 SNES Function norm 2.253098577166e+02
>> 45 SNES Function norm 2.253098577158e+02
>> 46 SNES Function norm 2.253098577157e+02
>> 47 SNES Function norm 2.253098577156e+02
>> 48 SNES Function norm 2.253098577156e+02
>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 48
>> ||r|| = 225.31, 7999 entries
>> ||rp|| = 140.021, 3 entries
>> ||rQ|| = 176.518, 7996 entries
>> Since I think we were convinced that this was intrinsic to the problem, and not a function of the Jacobian function, I am using my Jacobian.
>> Okay, I see no pattern in the fields. Lets plot these 2 vectors, -vec_view draw, and screenshot.
>> Matt
>> -gideon
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150911/7b3c5fb2/attachment.html>
