[petsc-users] pcfieldsplit for a composite dm with multiple subfields
Barry Smith
bsmith at mcs.anl.gov
Wed Sep 9 12:52:51 CDT 2015
Please run with the -snes_fd and one level of grid sequencing (where Newton was having trouble converging on the second level) with -snes_monitor -ksp_monitor_true_residual and send the output. Too much speculation and not enough data.
Barry
> On Sep 9, 2015, at 11:14 AM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
> Checking the Jacobian, this is a pretty standard output:
> Testing hand-coded Jacobian, if the ratio is O(1.e-8), the hand-coded Jacobian is probably correct.
> Finite difference Jacobian
> Hand-coded Jacobian
> Hand-coded minus finite difference Jacobian
> 6.08281e-10 = ||J - Jfd||//J|| 0.000151055 = ||J - Jfd||
> Things look favorable in terms of relative difference, but the absolute difference is a bit more suspect.
> -gideon
>> On Sep 8, 2015, at 11:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Sep 8, 2015, at 10:28 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>> I should clarify, in that run, I ran with the analytic jacobian, but I did not use -snes_mf_operator. If I use that flag, the performance is a bit different. In particular, the true residual norms are not as good. How should I interpret that?
>> The "analytic Jacobians" are wrong. Of course, that is easy to say, the hard part is figuring out exactly what entries are wrong.
>> You can try the following options. They are experimental so may be flaky run with the options below (but not -snes_fd or -snes_mf_operators)
>> -snes_check_jacobian
>> -snes_check_jacobian_view
