[petsc-users] pcfieldsplit for a composite dm with multiple subfields
Jed Brown
jed at jedbrown.org
Wed Sep 9 09:47:12 CDT 2015
Gideon Simpson <gideon.simpson at gmail.com> writes:
> I installed the gdb-apple via macports, but now it’s throwing a fit because my application has command line flags attached to it. Is there another way to diagnose this?
GDB can take command line options via
gdb --args ./blowup_batch_refine -your -options
unless you have the sort of heirloom version that Apple ships, in which
case you need
gdb ./blowup_batch_refine
(gdb) run -your -options
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150909/2676b86e/attachment.pgp>
