[petsc-users] Preserving nonzero structure during MatMatMult
Ghosh, Swarnava
sghosh2012 at gatech.edu
Thu Sep 3 17:55:34 CDT 2015
I want to do the following:
Matrices DM1, DM2 and DM3 (MPIAIJ type) have the same non zero structure. I want to multiply DM1*DM2=DM3. BUT the resulting matrix should preserve the initial non-zero pattern that was set to it. Basically multiplication should not create new non-zero locations.
For this I do:
/* after setting the nonzero locations/*
ierr = MatAssemblyBegin(DM1,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
ierr = MatAssemblyEnd(DM1,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
MatSetOption(DM1,MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE);
MatSetOption(DM1,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
Similarly for the matrices DM2 and DM3, the above is done.
However When I do MatMatMultSymbolic, the number of non-zeros change,
BEFORE MULT: NNZ allocated : 531441.000000 NNZ used: 518155.000000
AFTER MULT: NNZ allocated : 2350209.000000 NNZ used: 2350209.000000
Could you let me know how do I preserve the nonzero locations after MatMatMult?
Swarnava
Swarnava Ghosh
PhD Candidate,
Structural Engineering, Mechanics and Materials
School of Civil and Environmental Engineering
Georgia Institute of Technology
Atlanta, GA 30332
