[petsc-users] Integrating TAO into SNES and TS
Justin Chang jychang48 at gmail.com
Tue Sep 1 18:10:52 CDT 2015
Let me back up a bit.
Say I am solving -div[D(x)grad[c]] = 0 on a unit cube with a hole. Interior
boundary has DirichletBC c = 1 and exterior boundary  has DirichletBC c =
0. If I solve the above in the strong sense (e.g., finite volume, finite
difference, etc) -div[D(x)grad[c]] = 0 at every grid cell (hence local mass
conservation).
According to discrete maximum principle and the prescribed BCs, my bounds
*should* be between 0 <= c <= 1. However, if D(x) is aniosotropic, the
KSP/SNES solver will return c's less than 0 and/or greater than 1. Local
mass balance still exists for all cells regardless.
Now, if TAO is used and Vec XL and XU of TaoSetVariable bounds are set to 0
and 1 respectively, I now ensure that 0 <= c <= 1 even for anisotropy.
However, our experiments have shown that the "corrected" regions i.e., the
regions where it would have violated DMP otherwise, no longer satisfy local
mass balance i.e., div[D(x)grad[c]] != at the element level. The unaffected
regions, i.e. the regions where DMP was satisfied regardless, are still
locally conservative.
We have shown through MATLAB's *quadprog* that we can achieve both DMP and
local mass balance if we applied the mixed form (using least-squares finite
element method) of the diffusion and subject the optimization solve to
satisfy both upper/lower bounds as well as equality constraints (which is
divergence of flux = 0 in Omega). If no bounds/constraints were set, the
objective function is equal to zero. If either only bounds or constraints,
the objective function is equal to some non-zero value. If both bounds and
constraints, the objective function is a slightly larger non-zero value.
Basically, the more constraints I apply, the further and further away my
overall solution may drift from the original discretization.
I am curious to see if 1) something like this is possible with TAO and 2)
if I can achieve the SNESVI equivalent in the sense I have described. Hope
this makes a little more sense.
Justin
On Tue, Sep 1, 2015 at 4:29 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   I really cannot understand what you are saying.
> > On Sep 1, 2015, at 5:14 PM, Justin Chang <jychang48 at gmail.com> wrote:
> > So in VI, the i-th component/cell/point of x is "corrected" if it is
> below lb_i or above ub_i. All other x_i that satisfy their respective
> bounds remain untouched. Hence only the corrected components will violated
> the original equation
>    I think what you say above is backwards. First of all x_i would never
> be < lb_i   or > ub_i since it is constrained to be between them. It is
> just that with a VI IF x_i is lb_i or ub_i then F_i(x) is allowed to be
> nonzero (that is that equation is allowed to violated).
> > In optimization, every single x_i will be "shifted" such that every
> single x_i meets lb_i and ub_i. Hence it's possible all components will
> violate the original equation
>   No. With constraints in optimization, they must all be satisfied for one
> to say that one has a solution.
>   With VIs the F(x) is NOT a constraint and should not be thought of as a
> constraint; only the bounds are constraints. Or think of F(x) as a special
> kind of constraint (that doesn't exist with optimization) that is allowed
> to be violated in a a very special way (when its x_i variable is on a
> constraint).
>   Barry
> > Is that the general idea here?
> > On Tue, Sep 1, 2015 at 12:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    I think we are talking past each other.
> >    With bound constraint VI's there is no optimization, there is an
> equation F(x) = 0 (where F may be linear or nonlinear) and constraints  a
> <= x <= c. With VIs the equation F_i(x) is simply not satisfied if x_i is
> on a bound (that is x_i = a_i or x_i = b_i),
> >    With optimization if you have an equality constraint and inequality
> constraints; if to satisfy an inequality constraint FORCES an equality
> constraint to not be satisfied then the constraints are not compatible and
> the problem isn't properly posed.
> >    Barry
> > > On Sep 1, 2015, at 4:15 AM, Justin Chang <jychang48 at gmail.com> wrote:
> > > But if I add those linear equality constraint equations to my original
> problem, would they not be satisfied anyway? Say I add this to my weak form:
> > > Ax = b
> > > But once i subject x to some bounded constraints, Ax != b. Unless I
> add some sort of penalty where extra weighting is added to this property...
> > > On Tue, Sep 1, 2015 at 3:02 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Tue, Sep 1, 2015 at 3:46 AM, Justin Chang <jychang48 at gmail.com>
> wrote:
> > > I would like to simultaneously enforce both discrete maximum principle
> and local mass/species balance. Because even if a locally conservative
> scheme like RT0 is used, as soon as these bounded constraints are applied,
> i lose the mass balance.
> > > What I am saying is, can't you just add "linear equality constraints"
> as more equations?
> > >   Thanks,
> > >     Matt
> > > On Tue, Sep 1, 2015 at 2:33 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Tue, Sep 1, 2015 at 3:11 AM, Justin Chang <jychang48 at gmail.com>
> wrote:
> > > Barry,
> > > That's good to know thanks.
> > > On a related note, is it possible for VI to one day include linear
> equality constraints?
> > > How are these different from just using more equations?
> > >   Thanks,
> > >     Matt
> > > Thanks,
> > > Justin
> > > On Mon, Aug 31, 2015 at 7:13 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > On Aug 31, 2015, at 7:36 PM, Justin Chang <jychang48 at gmail.com>
> wrote:
> > > > Coming back to this,
> > > > Say I now want to ensure the DMP for advection-diffusion equations.
> The linear operator is now asymmetric and non-self-adjoint (assuming I do
> something like SUPG or finite volume), meaning I cannot simply solve this
> problem without any manipulation (e.g. normalizing the equations) using
> TAO's optimization solvers. Does this statement also hold true for SNESVI?
> > >   SNESVI doesn't care about symmetry etc
> > > > Thanks,
> > > > Justin
> > > > On Fri, Apr 3, 2015 at 7:38 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > > On Apr 3, 2015, at 7:35 PM, Justin Chang <jchang27 at uh.edu> wrote:
> > > > > I guess I will have to write my own code then :)
> > > > > I am not all that familiar with Variational Inequalities at the
> moment, but if my Jacobian is symmetric and positive definite and I only
> have lower and upper bounds, doesn't the problem simply reduce to that of a
> convex optimization? That is, with SNES act as if it were Tao?
> > > >   Yes, I think that is essentially correctly.
> > > >   Barry
> > > > > On Fri, Apr 3, 2015 at 6:35 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > >   Justin,
> > > > >    We haven't done anything with TS to handle variational
> inequalities. So you can either write your own backward Euler (outside of
> TS) that solves each time-step problem either as 1) an optimization problem
> using Tao or 2) as a variational inequality using SNES.
> > > > >    More adventurously you could look at the TSTHETA code in TS
> (which is a general form that includes Euler, Backward Euler and
> Crank-Nicolson and see if you can add the constraints to the SNES problem
> that is solved; in theory this is straightforward but it would require
> understanding the current code (which Jed, of course, overwrote :-). I
> think you should do this.
> > > > >   Barry
> > > > > > On Apr 3, 2015, at 12:31 PM, Justin Chang <jchang27 at uh.edu>
> wrote:
> > > > > > I am solving the following anisotropic transient diffusion
> equation subject to 0 bounds:
> > > > > > du/dt = div[D*grad[u]] + f
> > > > > > Where the dispersion tensor D(x) is symmetric and positive
> definite. This formulation violates the discrete maximum principles so one
> of the ways to ensure nonnegative concentrations is to employ convex
> optimization. I am following the procedures in Nakshatrala and Valocchi
> (2009) JCP and Nagarajan and Nakshatrala (2011) IJNMF.
> > > > > > The Variational Inequality method works gives what I want for my
> transient case, but what if I want to implement the Tao methodology in TS?
> That is, what TS functions do I need to set up steps a) through e) for each
> time step (also the Jacobian remains the same for all time steps so I would
> only call this once). Normally I would just call TSSolve() and let the
> libraries and functions do everything, but I would like to incorporate
> TaoSolve into every time step.
> > > > > > Thanks,
> > > > > > Justin Chang
> > > > > > PhD Candidate, Civil Engineering - Computational Sciences
> > > > > > University of Houston, Department of Civil and Environmental
> Engineering
> > > > > > Houston, TX 77004
> > > > > > (512) 963-3262
> > > > > > On Thu, Apr 2, 2015 at 6:53 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > > >   An alternative approach is for you to solve it as a
> (non)linear variational inequality. See src/snes/examples/tutorials/ex9.c
> > > > > >   How you should proceed depends on your long term goal. What
> problem do you really want to solve? Is it really a linear time dependent
> problem with 0 bounds on U? Can the problem always be represented as an
> optimization problem easily? What are  and what will be the properties of
> K? For example if K is positive definite then likely the bounds will remain
> try without explicitly providing the constraints.
> > > > > >   Barry
> > > > > > > On Apr 2, 2015, at 6:39 PM, Justin Chang <jchang27 at uh.edu>
> wrote:
> > > > > > > Hi everyone,
> > > > > > > I have a two part question regarding the integration of the
> following optimization problem
> > > > > > > min 1/2 u^T*K*u + u^T*f
> > > > > > > S.T. u >= 0
> > > > > > > into SNES and TS
> > > > > > > 1) For SNES, assuming I am working with a linear FE equation,
> I have the following algorithm/steps for solving my problem
> > > > > > > a) Set an initial guess x
> > > > > > > b) Obtain residual r and jacobian A through functions
> SNESComputeFunction() and SNESComputeJacobian() respectively
> > > > > > > c) Form vector b = r - A*x
> > > > > > > d) Set Hessian equal to A, gradient to A*x, objective function
> value to 1/2*x^T*A*x + x^T*b, and variable (lower) bounds to a zero vector
> > > > > > > e) Call TaoSolve
> > > > > > > This works well at the moment, but my question is there a more
> "efficient" way of doing this? Because with my current setup, I am making a
> rather bold assumption that my problem would converge in one SNES iteration
> without the bounded constraints and does not have any unexpected
> nonlinearities.
> > > > > > > 2) How would I go about doing the above for time-stepping
> problems? At each time step, I want to solve a convex optimization subject
> to the lower bounds constraint. I plan on using backward euler and my
> resulting jacobian should still be compatible with the above optimization
> problem.
> > > > > > > Thanks,
> > > > > > > Justin Chang
> Engineering
> > > > > > > Houston, TX 77004
> > > > > > > (512) 963-3262
> > > > > > Justin Chang
> Engineering
> > > > > > Houston, TX 77004
> > > > > > (512) 963-3262
> > > > > Justin Chang
> Engineering
> > > > > Houston, TX 77004
> > > > > (512) 963-3262
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150901/1e314490/attachment-0001.html>
