[petsc-users] 2D Poisson on nonuniform meshes
Tue Sep 1 05:13:54 CDT 2015
On Tue, Sep 1, 2015 at 4:38 AM, Filippo Leonardi <
filippo.leonardi at sam.math.ethz.ch> wrote:
> On Tuesday 01 September 2015 04:15:50 you wrote:
> > On Tue, Sep 1, 2015 at 4:12 AM, Filippo Leonardi <
> > > Thanks Matt,
> > > I use the "natural scaling" of the Laplacian Lapl * x = b. The grid is
> > > *still* uniform.
> > > I give you a couple of results:
> > > 1 ) This is e.g. gmres + gamg + 4 levels. As you can see it converges
> > > after 2 iterations which is totally strange. The solution is incorrect.
> > > 2 ) This is mg + galerkin matrices + levels. Result is incorrect
> > > 3 ) Default: works fine
> > > 4) LU: works fine
> > > I remove the constant nullspace as usual.
> > If you have a constant null space, how does 4) work? It should fail with
> a
> > zero pivot since
> > the matrix is singular.
> I do not care about the constant so any shift in the LU decomposition is
> fine and as far as I understood PETSc is robust in this respect.
1) The KSP view does not say it is shifting. Are you using the latest
release?
2) If it shifted, it would not solve in a single iterate.
3) Your GAMG results imply that something is wrong with the coarse solve.
This is exactly what would happen if
    that problem was not solved accurately (its off by > 10 orders of
magnitude).
It sounds like your operator is not singular, and its not the Laplacian
since it does not look like the Neumann version
has constants as a null space.
     Matt
> > Matt
> > > I use the usual setcomputeoperator business and compute rhs.
> > > Instead, if I scale to Lapl * dx * dy * x = b * dx * dy (things work
> fine
> > > also with MG). This is fine with uniform grid but I do not know how to
> do
> > > that properly on nonuniform.
> > > Let me know if you need code pieces or other details.
> > > 1)
> > > 0 KSP Residual norm 1.793027353791e-05
> > > 0 KSP preconditioned resid norm 1.793027353791e-05 true resid norm
> > > 7.912994695029e-03 ||r(i)||/||b|| 1.000000000000e+00
> > > 1 KSP Residual norm 2.662212708666e-20
> > > 1 KSP preconditioned resid norm 2.662212708666e-20 true resid norm
> > > 3.120963188535e-02 ||r(i)||/||b|| 3.944098674167e+00
> > > Linear solve converged due to CONVERGED_RTOL iterations 1
> > > KSP Object: 1 MPI processes
> > > type: gmres
> > > GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> > > Orthogonalization with no iterative refinement
> > > GMRES: happy breakdown tolerance 1e-30
> > > maximum iterations=10000, initial guess is zero
> > > tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> > > left preconditioning
> > > using PRECONDITIONED norm type for convergence test
> > > PC Object: 1 MPI processes
> > > type: gamg
> > > MG: type is MULTIPLICATIVE, levels=4 cycles=v
> > > Cycles per PCApply=1
> > > Using Galerkin computed coarse grid matrices
> > > GAMG specific options
> > > Threshold for dropping small values from graph 0
> > > AGG specific options
> > > Symmetric graph false
> > > Coarse grid solver -- level -------------------------------
> > > KSP Object: (mg_coarse_) 1 MPI processes
> > > type: gmres
> > > maximum iterations=1, initial guess is zero
> > > using NONE norm type for convergence test
> > > PC Object: (mg_coarse_) 1 MPI processes
> > > type: bjacobi
> > > block Jacobi: number of blocks = 1
> > > Local solve is same for all blocks, in the following KSP and PC
> > > objects:
> > > KSP Object: (mg_coarse_sub_) 1 MPI processes
> > > type: preonly
> > > PC Object: (mg_coarse_sub_) 1 MPI processes
> > > type: lu
> > > LU: out-of-place factorization
> > > tolerance for zero pivot 2.22045e-14
> > > using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
> > > matrix ordering: nd
> > > factor fill ratio given 5, needed 1.10953
> > > Factored matrix follows:
> > > Mat Object: 1 MPI processes
> > > type: seqaij
> > > rows=33, cols=33
> > > package used to perform factorization: petsc
> > > total: nonzeros=1013, allocated nonzeros=1013
> > > total number of mallocs used during MatSetValues calls =0
> > > using I-node routines: found 21 nodes, limit used is 5
> > > linear system matrix = precond matrix:
> > > type: seqaij
> > > rows=33, cols=33
> > > total: nonzeros=913, allocated nonzeros=913
> > > not using I-node routines
> > > type: seqaij
> > > rows=33, cols=33
> > > Down solver (pre-smoother) on level 1 -------------------------------
> > > KSP Object: (mg_levels_1_) 1 MPI processes
> > > type: chebyshev
> > > Chebyshev: eigenvalue estimates: min = -1.79769e+307, max = -inf
> > > Chebyshev: eigenvalues estimated using gmres with translations [0
> > > 0.1; 0 1.1]
> > > KSP Object: (mg_levels_1_esteig_) 1 MPI processes
> > > type: gmres
> > > maximum iterations=10, initial guess is zero
> > > maximum iterations=2
> > > using nonzero initial guess
> > > PC Object: (mg_levels_1_) 1 MPI processes
> > > type: sor
> > > SOR: type = local_symmetric, iterations = 1, local iterations = 1,
> > > omega = 1
> > > type: seqaij
> > > rows=401, cols=401
> > > total: nonzeros=9777, allocated nonzeros=9777
> > > Up solver (post-smoother) same as down solver (pre-smoother)
> > > Down solver (pre-smoother) on level 2 -------------------------------
> > > KSP Object: (mg_levels_2_) 1 MPI processes
> > > type: chebyshev
> > > 0.1; 0 1.1]
> > > KSP Object: (mg_levels_2_esteig_) 1 MPI processes
> > > type: gmres
> > > PC Object: (mg_levels_2_) 1 MPI processes
> > > type: sor
> > > omega = 1
> > > type: seqaij
> > > rows=2296, cols=2296
> > > total: nonzeros=25038, allocated nonzeros=25038
> > > Down solver (pre-smoother) on level 3 -------------------------------
> > > KSP Object: (mg_levels_3_) 1 MPI processes
> > > type: chebyshev
> > > 0.1; 0 1.1]
> > > KSP Object: (mg_levels_3_esteig_) 1 MPI processes
> > > type: gmres
> > > PC Object: (mg_levels_3_) 1 MPI processes
> > > type: sor
> > > omega = 1
> > > type: seqaij
> > > rows=16384, cols=16384
> > > total: nonzeros=81920, allocated nonzeros=81920
> > > has attached null space
> > > type: seqaij
> > > 2)
> > > 0 KSP Residual norm 1.010294060491e-05
> > > 0 KSP preconditioned resid norm 1.010294060491e-05 true resid norm
> > > 1.086379257868e-03 ||r(i)||/||b|| 1.000000000000e+00
> > > 1 KSP Residual norm 8.803303876758e-20
> > > 1 KSP preconditioned resid norm 8.803303876758e-20 true resid norm
> > > 2.101751936637e-03 ||r(i)||/||b|| 1.934639235254e+00
> > > type: gmres
> > > type: mg
> > > type: preonly
> > > type: lu
> > > matrix ordering: nd
> > > factor fill ratio given 5, needed 4.83507
> > > type: seqaij
> > > rows=256, cols=256
> > > total: nonzeros=11140, allocated nonzeros=11140
> > > type: seqaij
> > > rows=256, cols=256
> > > total: nonzeros=2304, allocated nonzeros=2304
> > > type: chebyshev
> > > 0.1; 0 1.1]
> > > type: gmres
> > > type: sor
> > > omega = 1
> > > type: seqaij
> > > rows=1024, cols=1024
> > > total: nonzeros=9216, allocated nonzeros=9216
> > > type: chebyshev
> > > 0.1; 0 1.1]
> > > type: gmres
> > > type: sor
> > > omega = 1
> > > type: seqaij
> > > rows=4096, cols=4096
> > > total: nonzeros=36864, allocated nonzeros=36864
> > > type: chebyshev
> > > 0.1; 0 1.1]
> > > type: gmres
> > > type: sor
> > > omega = 1
> > > type: seqaij
> > > type: seqaij
> > > 3)
> > > 0 KSP Residual norm 2.990548680394e-08
> > > 0 KSP preconditioned resid norm 2.990548680394e-08 true resid norm
> > > 2.966915112865e-04 ||r(i)||/||b|| 1.000000000000e+00
> > > 1 KSP Residual norm 2.368703753809e-08
> > > 1 KSP preconditioned resid norm 2.368703753809e-08 true resid norm
> > > 3.109667150576e-04 ||r(i)||/||b|| 1.048114634993e+00
> > > 2 KSP Residual norm 2.236515515253e-08
> > > 2 KSP preconditioned resid norm 2.236515515253e-08 true resid norm
> > > 2.655771471955e-04 ||r(i)||/||b|| 8.951289035670e-01
> > > 3 KSP Residual norm 1.957630940223e-08
> > > 3 KSP preconditioned resid norm 1.957630940223e-08 true resid norm
> > > 2.158250768646e-04 ||r(i)||/||b|| 7.274393390250e-01
> > > 4 KSP Residual norm 1.771416739221e-08
> > > 4 KSP preconditioned resid norm 1.771416739221e-08 true resid norm
> > > 2.075204223802e-04 ||r(i)||/||b|| 6.994484657830e-01
> > > 5 KSP Residual norm 1.617056152936e-08
> > > 5 KSP preconditioned resid norm 1.617056152936e-08 true resid norm
> > > 1.908090487285e-04 ||r(i)||/||b|| 6.431227098516e-01
> > > 6 KSP Residual norm 1.467170521607e-08
> > > 6 KSP preconditioned resid norm 1.467170521607e-08 true resid norm
> > > 1.683698119419e-04 ||r(i)||/||b|| 5.674911668750e-01
> > > 7 KSP Residual norm 1.321526248809e-08
> > > 7 KSP preconditioned resid norm 1.321526248809e-08 true resid norm
> > > 1.473617884651e-04 ||r(i)||/||b|| 4.966835344432e-01
> > > 8 KSP Residual norm 1.174828665876e-08
> > > 8 KSP preconditioned resid norm 1.174828665876e-08 true resid norm
> > > 1.458902362707e-04 ||r(i)||/||b|| 4.917236615167e-01
> > > 9 KSP Residual norm 1.012151625603e-08
> > > 9 KSP preconditioned resid norm 1.012151625603e-08 true resid norm
> > > 1.303866699420e-04 ||r(i)||/||b|| 4.394688253015e-01
> > > 10 KSP Residual norm 7.876439970777e-09
> > > 10 KSP preconditioned resid norm 7.876439970777e-09 true resid norm
> > > 1.162414266035e-04 ||r(i)||/||b|| 3.917922224990e-01
> > > 11 KSP Residual norm 4.981821461221e-09
> > > 11 KSP preconditioned resid norm 4.981821461221e-09 true resid norm
> > > 9.075981784793e-05 ||r(i)||/||b|| 3.059063518683e-01
> > > 12 KSP Residual norm 2.426217812448e-09
> > > 12 KSP preconditioned resid norm 2.426217812448e-09 true resid norm
> > > 5.145334699067e-05 ||r(i)||/||b|| 1.734237247556e-01
> > > 13 KSP Residual norm 1.049060114422e-09
> > > 13 KSP preconditioned resid norm 1.049060114422e-09 true resid norm
> > > 2.107527819651e-05 ||r(i)||/||b|| 7.103431475044e-02
> > > 14 KSP Residual norm 5.887222551677e-10
> > > 14 KSP preconditioned resid norm 5.887222551677e-10 true resid norm
> > > 9.047187295472e-06 ||r(i)||/||b|| 3.049358323817e-02
> > > 15 KSP Residual norm 4.536407095834e-10
> > > 15 KSP preconditioned resid norm 4.536407095834e-10 true resid norm
> > > 6.032647097712e-06 ||r(i)||/||b|| 2.033306268708e-02
> > > 16 KSP Residual norm 3.564018350025e-10
> > > 16 KSP preconditioned resid norm 3.564018350025e-10 true resid norm
> > > 5.116056274149e-06 ||r(i)||/||b|| 1.724368941991e-02
> > > 17 KSP Residual norm 2.744968239957e-10
> > > 17 KSP preconditioned resid norm 2.744968239957e-10 true resid norm
> > > 3.648248676660e-06 ||r(i)||/||b|| 1.229643767306e-02
> > > 18 KSP Residual norm 2.281847233955e-10
> > > 18 KSP preconditioned resid norm 2.281847233955e-10 true resid norm
> > > 2.900148270786e-06 ||r(i)||/||b|| 9.774962074955e-03
> > > 19 KSP Residual norm 1.881670741813e-10
> > > 19 KSP preconditioned resid norm 1.881670741813e-10 true resid norm
> > > 2.473850917169e-06 ||r(i)||/||b|| 8.338125032436e-03
> > > 20 KSP Residual norm 1.581922522755e-10
> > > 20 KSP preconditioned resid norm 1.581922522755e-10 true resid norm
> > > 1.965254213304e-06 ||r(i)||/||b|| 6.623897680059e-03
> > > 21 KSP Residual norm 1.349952347592e-10
> > > 21 KSP preconditioned resid norm 1.349952347592e-10 true resid norm
> > > 1.709953736235e-06 ||r(i)||/||b|| 5.763406336838e-03
> > > 22 KSP Residual norm 1.148754892680e-10
> > > 22 KSP preconditioned resid norm 1.148754892680e-10 true resid norm
> > > 1.452723184020e-06 ||r(i)||/||b|| 4.896409667135e-03
> > > 23 KSP Residual norm 9.889008860663e-11
> > > 23 KSP preconditioned resid norm 9.889008860663e-11 true resid norm
> > > 1.259317356950e-06 ||r(i)||/||b|| 4.244534504846e-03
> > > 24 KSP Residual norm 8.468070834423e-11
> > > 24 KSP preconditioned resid norm 8.468070834423e-11 true resid norm
> > > 1.097968496396e-06 ||r(i)||/||b|| 3.700707484468e-03
> > > 25 KSP Residual norm 7.340678871498e-11
> > > 25 KSP preconditioned resid norm 7.340678871498e-11 true resid norm
> > > 9.388293102378e-07 ||r(i)||/||b|| 3.164328181036e-03
> > > 26 KSP Residual norm 6.452497596580e-11
> > > 26 KSP preconditioned resid norm 6.452497596580e-11 true resid norm
> > > 7.907509627807e-07 ||r(i)||/||b|| 2.665229481464e-03
> > > 27 KSP Residual norm 5.817349095331e-11
> > > 27 KSP preconditioned resid norm 5.817349095331e-11 true resid norm
> > > 6.712549222809e-07 ||r(i)||/||b|| 2.262467568992e-03
> > > 28 KSP Residual norm 5.382715584394e-11
> > > 28 KSP preconditioned resid norm 5.382715584394e-11 true resid norm
> > > 5.883671521302e-07 ||r(i)||/||b|| 1.983093987351e-03
> > > 29 KSP Residual norm 5.072666199584e-11
> > > 29 KSP preconditioned resid norm 5.072666199584e-11 true resid norm
> > > 5.417512216577e-07 ||r(i)||/||b|| 1.825974795533e-03
> > > 30 KSP Residual norm 4.806650672230e-11
> > > 30 KSP preconditioned resid norm 4.806650672230e-11 true resid norm
> > > 5.151866485899e-07 ||r(i)||/||b|| 1.736438789084e-03
> > > 31 KSP Residual norm 4.675001898732e-11
> > > 31 KSP preconditioned resid norm 4.675001898732e-11 true resid norm
> > > 4.825947510614e-07 ||r(i)||/||b|| 1.626587659919e-03
> > > 32 KSP Residual norm 4.530536181592e-11
> > > 32 KSP preconditioned resid norm 4.530536181592e-11 true resid norm
> > > 4.648650267512e-07 ||r(i)||/||b|| 1.566829548764e-03
> > > 33 KSP Residual norm 4.357157235509e-11
> > > 33 KSP preconditioned resid norm 4.357157235509e-11 true resid norm
> > > 4.567209908707e-07 ||r(i)||/||b|| 1.539380041209e-03
> > > 34 KSP Residual norm 4.135715715343e-11
> > > 34 KSP preconditioned resid norm 4.135715715343e-11 true resid norm
> > > 4.469703503011e-07 ||r(i)||/||b|| 1.506515465721e-03
> > > 35 KSP Residual norm 3.851871986267e-11
> > > 35 KSP preconditioned resid norm 3.851871986267e-11 true resid norm
> > > 4.364097171314e-07 ||r(i)||/||b|| 1.470920806730e-03
> > > 36 KSP Residual norm 3.526035391634e-11
> > > 36 KSP preconditioned resid norm 3.526035391634e-11 true resid norm
> > > 4.065382561286e-07 ||r(i)||/||b|| 1.370238920439e-03
> > > 37 KSP Residual norm 3.144895012756e-11
> > > 37 KSP preconditioned resid norm 3.144895012756e-11 true resid norm
> > > 3.810168560499e-07 ||r(i)||/||b|| 1.284218932985e-03
> > > 38 KSP Residual norm 2.735239124106e-11
> > > 38 KSP preconditioned resid norm 2.735239124106e-11 true resid norm
> > > 3.407338934429e-07 ||r(i)||/||b|| 1.148445036278e-03
> > > 39 KSP Residual norm 2.306734554159e-11
> > > 39 KSP preconditioned resid norm 2.306734554159e-11 true resid norm
> > > 2.940484127641e-07 ||r(i)||/||b|| 9.910914251948e-04
> > > 40 KSP Residual norm 1.924842110922e-11
> > > 40 KSP preconditioned resid norm 1.924842110922e-11 true resid norm
> > > 2.443693779909e-07 ||r(i)||/||b|| 8.236480273107e-04
> > > 41 KSP Residual norm 1.618672399310e-11
> > > 41 KSP preconditioned resid norm 1.618672399310e-11 true resid norm
> > > 2.034502467604e-07 ||r(i)||/||b|| 6.857299215548e-04
> > > 42 KSP Residual norm 1.378885267147e-11
> > > 42 KSP preconditioned resid norm 1.378885267147e-11 true resid norm
> > > 1.689714775892e-07 ||r(i)||/||b|| 5.695190834970e-04
> > > 43 KSP Residual norm 1.179601185051e-11
> > > 43 KSP preconditioned resid norm 1.179601185051e-11 true resid norm
> > > 1.483783124701e-07 ||r(i)||/||b|| 5.001097329234e-04
> > > 44 KSP Residual norm 9.928908801463e-12
> > > 44 KSP preconditioned resid norm 9.928908801463e-12 true resid norm
> > > 1.276885725440e-07 ||r(i)||/||b|| 4.303748765523e-04
> > > 45 KSP Residual norm 8.512555069524e-12
> > > 45 KSP preconditioned resid norm 8.512555069524e-12 true resid norm
> > > 1.020939171370e-07 ||r(i)||/||b|| 3.441079817022e-04
> > > 46 KSP Residual norm 7.600214409478e-12
> > > 46 KSP preconditioned resid norm 7.600214409478e-12 true resid norm
> > > 8.873369034852e-08 ||r(i)||/||b|| 2.990772805186e-04
> > > 47 KSP Residual norm 6.577382322417e-12
> > > 47 KSP preconditioned resid norm 6.577382322417e-12 true resid norm
> > > 8.285748008098e-08 ||r(i)||/||b|| 2.792714888326e-04
> > > 48 KSP Residual norm 5.701374824383e-12
> > > 48 KSP preconditioned resid norm 5.701374824383e-12 true resid norm
> > > 6.754179947516e-08 ||r(i)||/||b|| 2.276499222452e-04
> > > 49 KSP Residual norm 5.201909133133e-12
> > > 49 KSP preconditioned resid norm 5.201909133133e-12 true resid norm
> > > 5.807496359589e-08 ||r(i)||/||b|| 1.957419116714e-04
> > > 50 KSP Residual norm 4.803415857522e-12
> > > 50 KSP preconditioned resid norm 4.803415857522e-12 true resid norm
> > > 5.648916764539e-08 ||r(i)||/||b|| 1.903969796791e-04
> > > 51 KSP Residual norm 4.213404847970e-12
> > > 51 KSP preconditioned resid norm 4.213404847970e-12 true resid norm
> > > 5.312367187239e-08 ||r(i)||/||b|| 1.790535618699e-04
> > > 52 KSP Residual norm 3.583723287544e-12
> > > 52 KSP preconditioned resid norm 3.583723287544e-12 true resid norm
> > > 4.482581392980e-08 ||r(i)||/||b|| 1.510855964009e-04
> > > 53 KSP Residual norm 3.055433343791e-12
> > > 53 KSP preconditioned resid norm 3.055433343791e-12 true resid norm
> > > 3.733365588478e-08 ||r(i)||/||b|| 1.258332458617e-04
> > > 54 KSP Residual norm 2.632415195178e-12
> > > 54 KSP preconditioned resid norm 2.632415195178e-12 true resid norm
> > > 3.259461418510e-08 ||r(i)||/||b|| 1.098602856676e-04
> > > 55 KSP Residual norm 2.358953414259e-12
> > > 55 KSP preconditioned resid norm 2.358953414259e-12 true resid norm
> > > 2.755891784400e-08 ||r(i)||/||b|| 9.288744974367e-05
> > > 56 KSP Residual norm 2.131084837625e-12
> > > 56 KSP preconditioned resid norm 2.131084837625e-12 true resid norm
> > > 2.435335186857e-08 ||r(i)||/||b|| 8.208307599694e-05
> > > 57 KSP Residual norm 1.906113965754e-12
> > > 57 KSP preconditioned resid norm 1.906113965754e-12 true resid norm
> > > 2.234444331024e-08 ||r(i)||/||b|| 7.531204116139e-05
> > > 58 KSP Residual norm 1.666029207693e-12
> > > 58 KSP preconditioned resid norm 1.666029207693e-12 true resid norm
> > > 2.187608862971e-08 ||r(i)||/||b|| 7.373344971974e-05
> > > 59 KSP Residual norm 1.397594452516e-12
> > > 59 KSP preconditioned resid norm 1.397594452516e-12 true resid norm
> > > 1.884281030995e-08 ||r(i)||/||b|| 6.350977224879e-05
> > > 60 KSP Residual norm 1.000720808126e-12
> > > 60 KSP preconditioned resid norm 1.000720808126e-12 true resid norm
> > > 1.495264965711e-08 ||r(i)||/||b|| 5.039796923166e-05
> > > 61 KSP Residual norm 8.368281175845e-13
> > > 61 KSP preconditioned resid norm 8.368281175845e-13 true resid norm
> > > 1.198110007063e-08 ||r(i)||/||b|| 4.038234871863e-05
> > > 62 KSP Residual norm 6.975866756145e-13
> > > 62 KSP preconditioned resid norm 6.975866756145e-13 true resid norm
> > > 8.713139114636e-09 ||r(i)||/||b|| 2.936767242465e-05
> > > 63 KSP Residual norm 6.055685829863e-13
> > > 63 KSP preconditioned resid norm 6.055685829863e-13 true resid norm
> > > 7.208696201852e-09 ||r(i)||/||b|| 2.429694119186e-05
> > > 64 KSP Residual norm 5.321880026091e-13
> > > 64 KSP preconditioned resid norm 5.321880026091e-13 true resid norm
> > > 6.450668328122e-09 ||r(i)||/||b|| 2.174200502115e-05
> > > 65 KSP Residual norm 4.652520314729e-13
> > > 65 KSP preconditioned resid norm 4.652520314729e-13 true resid norm
> > > 5.767198491137e-09 ||r(i)||/||b|| 1.943836703022e-05
> > > 66 KSP Residual norm 4.095554125778e-13
> > > 66 KSP preconditioned resid norm 4.095554125778e-13 true resid norm
> > > 5.117612129931e-09 ||r(i)||/||b|| 1.724893343844e-05
> > > 67 KSP Residual norm 3.575261581129e-13
> > > 67 KSP preconditioned resid norm 3.575261581129e-13 true resid norm
> > > 4.479181564454e-09 ||r(i)||/||b|| 1.509710050359e-05
> > > 68 KSP Residual norm 3.109053579360e-13
> > > 68 KSP preconditioned resid norm 3.109053579360e-13 true resid norm
> > > 3.779777902208e-09 ||r(i)||/||b|| 1.273975748689e-05
> > > 69 KSP Residual norm 2.721884401030e-13
> > > 69 KSP preconditioned resid norm 2.721884401030e-13 true resid norm
> > > 3.393605957929e-09 ||r(i)||/||b|| 1.143816330711e-05
> > > Linear solve converged due to CONVERGED_RTOL iterations 69
> > > type: gmres
> > > type: ilu
> > > ILU: out-of-place factorization
> > > 0 levels of fill
> > > matrix ordering: natural
> > > factor fill ratio given 1, needed 1
> > > type: seqaij
> > > type: seqaij
> > > 4)
> > > Linear solve converged due to CONVERGED_ITS iterations 1
> > > type: preonly
> > > type: lu
> > > matrix ordering: nd
> > > factor fill ratio given 5, needed 9.6582
> > > type: seqaij
> > > total: nonzeros=791200, allocated nonzeros=791200
> > > type: seqaij
> > > On Tuesday 01 September 2015 03:40:14 Matthew Knepley wrote:
> > > > On Tue, Sep 1, 2015 at 2:22 AM, Filippo Leonardi <
> > > > > Dear PETSc Users,
> > > > > I want to use multigrid to solve uniform (just Laplace) poisson in
> > > 2D/3D
> > > > > on cartesian, non-uniform meshes with a standard 5 (7)-points
> stencil
> > > FD.
> > > > > I always scaled my Poisson matrix like in the doc examples, i.e.
> > > > > multiplying by dx*dy (so that in ComputeRHS I need to scale b, in
> A*x
> > > = b,
> > > > > as well). This always worked properly with both MG/GAMG and with
> > > galerkin
> > > > > matrices.
> > > > > Now I'd like to use non-uniform meshes, therefore the scaling is
> > > > > non-uniform. However I cannot get my matrices to scale properly
> with
> > > any
> > > > > sort of multigrid.
> > > > > One would think that without scaling, i.e. solving the original
> > > system, at
> > > > > least MG+galerkin or GAMG should work anyways provided the matrix A
> > > and b
> > > > > are consistent.
> > > > > I tried without boundaries (i.e. torus), so this is not the
> problem.
> > > > The point of that scaling is to make the boundary values the same
> size
> > > > as
> > > > the residuals. If you have
> > > > no boundary values, the problem is scale invariant since its linear.
> It
> > > > would be nice to scale it so everything
> > > > is about size 1.
> > > > When asking about convergence always run with -ksp_view
> > > > -ksp_monitor_true_residual -ksp_converged_reason
> > > > Thanks,
> > > > Matt
> > > > > Anyone did/knows how to do this properly?
> > > > > Thanks,
> > > > > F
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150901/88d26b6f/attachment-0001.html>
