[petsc-users] Offloading linear solves in time stepper to GPU
Harshad Sahasrabudhe hsahasra at purdue.edu
Sat May 30 23:02:40 CDT 2015
> which preconditioner are you using and how many iterations does it
> require?
 This is a linear autonomous system?
> How long does it take to solve that system stand-alone using MAGMA,
> including
> >> the data transfers?
> > I'm still working on these tests.
> Do that first.
Thank you very much for the guidance. I'll get back with the answers
tomorrow.
On Sat, May 30, 2015 at 11:50 PM, Jed Brown <jed at jedbrown.org> wrote:
> Harshad Sahasrabudhe <hsahasra at purdue.edu> writes:
> >>  Surely you're familiar with this.
> > Yes, I'm familiar with this. We are running on Intel Xeon E5 processor.
> It
> > has enough bandwidth and performance.
> One core saturates a sizeable fraction of the memory bandwidth for the
> socket.  You certainly can't expect 10x speedups when moving from 1 to
> 16 cores for a memory bandwidth limited application.
> > Is the poor scaling due to increased iteration count?  What method are
> you
> >> using?
> > This is exactly why we have poor scaling. We have tried KSPGMRES.
> GMRES is secondary for this discussion; which preconditioner are you
> using and how many iterations does it require?
> > This sounds like a problem with your code (non-scalable data structure).
> > We need to work on the algorithm for matrix assembly. In it's current
> > state, one CPU ends up doing much of the work.This could be the cause of
> > bad memory scaling. This doesn't contribute to the bad scaling to time
> > stepping, time taken for time stepping is counted separately from
> assembly.
> including
> >> the data transfers?
> Do that first.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150531/5c01f67e/attachment.html>
