[petsc-users] NASM FormFunctionLocal
Rongliang Chen rongliang.chan at gmail.com
Sat May 30 20:02:39 CDT 2015
Hi Barry and Matt,
Many thanks for your reply. I only have one DA and I do not think I
changed others when I changed the overlap.
This error can be reproduced using the attached code (added some lines
in the src/snes/examples/tutorials/ex19.c) run with:
runex19_1:
         -@${MPIEXEC} -n 2 ./ex19 -da_refine 3 -snes_type nasm
-da_overlap 2 -snes_monitor
The full error messages are followed:
lid velocity = 0.0016, prandtl # = 1, grashof # = 1
   0 SNES Function norm 4.066115181565e-02
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Arguments are incompatible
[1]PETSC ERROR: Vector local size 1300 is not compatible with DMDA local
sizes 1400 1728
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.5.2, unknown
[1]PETSC ERROR: ./ex19 on a 64bit-debug named rlchen by rlchen Sun May
31 08:55:16 2015
[1]PETSC ERROR: Configure options --download-fblaslapack
--download-blacs --download-scalapack --download-metis
--download-parmetis --download-exodusii --download-netcdf
--download-hdf5 --with-64-bit-indices --with-c2html=0 --with-mpi=1
--with-debugging=1 --with-shared-libraries=0
[1]PETSC ERROR: #1 DMDAVecGetArray() line 71 in
/home/rlchen/soft/petsc-3.5.2/src/dm/impls/da/dagetarray.c
[1]PETSC ERROR: #2 FormFunctionLocal() line 275 in
/home/rlchen/soft/petsc-3.5.2/src/snes/examples/tutorials/ex19.c
[1]PETSC ERROR: #3 SNESComputeFunction_DMDA() line 90 in
/home/rlchen/soft/petsc-3.5.2/src/snes/utils/dmdasnes.c
[1]PETSC ERROR: #4 SNESComputeFunction() line 2033 in
/home/rlchen/soft/petsc-3.5.2/src/snes/interface/snes.c
[1]PETSC ERROR: #5 SNESSolve_NEWTONLS() line 174 in
/home/rlchen/soft/petsc-3.5.2/src/snes/impls/ls/ls.c
[1]PETSC ERROR: #6 SNESSolve() line 3743 in
[1]PETSC ERROR: #7 SNESNASMSolveLocal_Private() line 716 in
/home/rlchen/soft/petsc-3.5.2/src/snes/impls/nasm/nasm.c
[1]PETSC ERROR: #8 SNESSolve_NASM() line 859 in
[1]PETSC ERROR: #9 SNESSolve() line 3743 in
[1]PETSC ERROR: #10 main() line 162 in
[1]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 75) - process 1
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Arguments are incompatible
[0]PETSC ERROR: Vector local size 1400 is not compatible with DMDA local
sizes 1500 1836
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
[0]PETSC ERROR: Petsc Release Version 3.5.2, unknown
[0]PETSC ERROR: ./ex19 on a 64bit-debug named rlchen by rlchen Sun May
31 08:55:16 2015
[0]PETSC ERROR: Configure options --download-fblaslapack
[0]PETSC ERROR: #1 DMDAVecGetArray() line 71 in
[0]PETSC ERROR: #2 FormFunctionLocal() line 275 in
[0]PETSC ERROR: #3 SNESComputeFunction_DMDA() line 90 in
[0]PETSC ERROR: #4 SNESComputeFunction() line 2033 in
[0]PETSC ERROR: #5 SNESSolve_NEWTONLS() line 174 in
[0]PETSC ERROR: #6 SNESSolve() line 3743 in
[0]PETSC ERROR: #7 SNESNASMSolveLocal_Private() line 716 in
[0]PETSC ERROR: #8 SNESSolve_NASM() line 859 in
[0]PETSC ERROR: #9 SNESSolve() line 3743 in
[0]PETSC ERROR: #10 main() line 162 in
[0]PETSC ERROR: ----------------End of Error Message -------send entire
application called MPI_Abort(MPI_COMM_WORLD, 75) - process 0
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 19200
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
make: [runex19_1] Error 75 (ignored)
Best regards,
Rongliang
On 05/31/2015 01:09 AM, Barry Smith wrote:
>> On May 30, 2015, at 5:05 AM, Rongliang Chen <rongliang.chan at gmail.com> wrote:
>> Hi there,
>> I am trying to use NASM to solve a nonlinear problem. In my FormFunctionLocal, I need to call DMDAVecGetArray(da, myvec, z). For the "-da_overlap 0" case, the code works fine.
>> For the "-da_overlap 1" case, when I use the vector "myvec" created by DMCreateLocalVector, it works fine. But if I use the vector "myvec" created by DMCreateGlobalVector, I got the error messages:
>> [6]Arguments are incompatible
>> [6]PETSC ERROR: Vector local size 597870 is not compatible with DMDA local sizes 619528 664392
> I think you are changing something else at the same time you changed the overlap.  The number ^^^^  619528 is the local size of the global vector and it should remain the same when you change the overlap but below you have TWO other numbers 633144 and 650256  Do you have more than one DMDA?
> Run changing absolutely nothing except the overlap.
>> And when I switch to "-da_overlap 2", both of the global and local version of "mrvec" got error messages:
>> [10]PETSC ERROR: Arguments are incompatible
>> [10]PETSC ERROR: Vector local size 589680 is not compatible with DMDA local sizes 633144 678680
>> [3]PETSC ERROR: Arguments are incompatible
>> [3]PETSC ERROR: Vector local size 619528 is not compatible with DMDA local sizes 650256 696540
>> Can any one tell me how to use DMDAVecGetArray in FormFunctionLocal for NASM? Thanks.
>> Best regards,
>> Rongliang
static char help[] = "Nonlinear driven cavity with multigrid in 2d.\n\
  \n\
The 2D driven cavity problem is solved in a velocity-vorticity formulation.\n\
The flow can be driven with the lid or with bouyancy or both:\n\
  -lidvelocity <lid>, where <lid> = dimensionless velocity of lid\n\
  -grashof <gr>, where <gr> = dimensionless temperature gradent\n\
  -prandtl <pr>, where <pr> = dimensionless thermal/momentum diffusity ratio\n\
  -contours : draw contour plots of solution\n\n";
      See src/ksp/ksp/examples/tutorials/ex45.c
/*T
   Concepts: SNES^solving a system of nonlinear equations (parallel multicomponent example);
   Concepts: DMDA^using distributed arrays;
   Concepts: multicomponent
   Processors: n
T*/
/*F-----------------------------------------------------------------------
    We thank David E. Keyes for contributing the driven cavity discretization within this example code.
    This problem is modeled by the partial differential equation system
\begin{eqnarray}
        - \triangle U - \nabla_y \Omega & = & 0  \\
        - \triangle V + \nabla_x\Omega & = & 0  \\
        - \triangle \Omega + \nabla \cdot ([U*\Omega,V*\Omega]) - GR* \nabla_x T & = & 0  \\
        - \triangle T + PR* \nabla \cdot ([U*T,V*T]) & = & 0
\end{eqnarray}
    in the unit square, which is uniformly discretized in each of x and y in this simple encoding.
    No-slip, rigid-wall Dirichlet conditions are used for $ [U,V]$.
    Dirichlet conditions are used for Omega, based on the definition of
    vorticity: $ \Omega = - \nabla_y U + \nabla_x V$, where along each
    constant coordinate boundary, the tangential derivative is zero.
    Dirichlet conditions are used for T on the left and right walls,
    and insulation homogeneous Neumann conditions are used for T on
    the top and bottom walls.
    A finite difference approximation with the usual 5-point stencil
    is used to discretize the boundary value problem to obtain a
    nonlinear system of equations.  Upwinding is used for the divergence
    (convective) terms and central for the gradient (source) terms.
    The Jacobian can be either
      * formed via finite differencing using coloring (the default), or
      * applied matrix-free via the option -snes_mf
        (for larger grid problems this variant may not converge
        without a preconditioner due to ill-conditioning).
  ------------------------------------------------------------------------F*/
   Include "petscdmda.h" so that we can use distributed arrays (DMDAs).
   Include "petscsnes.h" so that we can use SNES solvers.  Note that this
   file automatically includes:
     petscsys.h       - base PETSc routines   petscvec.h - vectors
     petscmat.h - matrices
     petscis.h     - index sets            petscksp.h - Krylov subspace methods
     petscviewer.h - viewers               petscpc.h  - preconditioners
     petscksp.h   - linear solvers
#if defined(PETSC_APPLE_FRAMEWORK)
#import <PETSc/petscsnes.h>
#import <PETSc/petscdmda.h>
#else
#include <petscsnes.h>
#include <petscdm.h>
#include <petscdmda.h>
#endif
   User-defined routines and data structures
typedef struct {
  PetscScalar u,v,omega,temp;
} Field;
PetscErrorCode FormFunctionLocal(DMDALocalInfo*,Field**,Field**,void*);
typedef struct {
  PassiveReal lidvelocity,prandtl,grashof;  /* physical parameters */
  PetscBool   draw_contours;                /* flag - 1 indicates drawing contours */
  Vec temp; // added by rlchen
} AppCtx;
extern PetscErrorCode FormInitialGuess(AppCtx*,DM,Vec);
extern PetscErrorCode NonlinearGS(SNES,Vec,Vec,void*);
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
  AppCtx         user;                /* user-defined work context */
  PetscInt       mx,my,its;
  PetscErrorCode ierr;
  MPI_Comm       comm;
  SNES           snes;
  DM             da;
  Vec            x;
  ierr = PetscInitialize(&argc,&argv,(char*)0,help);if (ierr) return(1);
  PetscFunctionBeginUser;
  comm = PETSC_COMM_WORLD;
  ierr = SNESCreate(comm,&snes);CHKERRQ(ierr);
      Create distributed array object to manage parallel grid and vectors
      for principal unknowns (x) and governing residuals (f)
  ierr = DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,-4,-4,PETSC_DECIDE,PETSC_DECIDE,4,1,0,0,&da);CHKERRQ(ierr);
  ierr = SNESSetDM(snes,(DM)da);CHKERRQ(ierr);
  ierr = SNESSetNGS(snes, NonlinearGS, (void*)&user);CHKERRQ(ierr);
  ierr = DMDAGetInfo(da,0,&mx,&my,PETSC_IGNORE,PETSC_IGNORE,PETSC_IGNORE,PETSC_IGNORE,PETSC_IGNORE,PETSC_IGNORE,
                     PETSC_IGNORE,PETSC_IGNORE,PETSC_IGNORE,PETSC_IGNORE);CHKERRQ(ierr);
     Problem parameters (velocity of lid, prandtl, and grashof numbers)
  user.lidvelocity = 1.0/(mx*my);
  user.prandtl     = 1.0;
  user.grashof     = 1.0;
  ierr = PetscOptionsGetReal(NULL,"-lidvelocity",&user.lidvelocity,NULL);CHKERRQ(ierr);
  ierr = PetscOptionsGetReal(NULL,"-prandtl",&user.prandtl,NULL);CHKERRQ(ierr);
  ierr = PetscOptionsGetReal(NULL,"-grashof",&user.grashof,NULL);CHKERRQ(ierr);
  ierr = PetscOptionsHasName(NULL,"-contours",&user.draw_contours);CHKERRQ(ierr);
  ierr = DMDASetFieldName(da,0,"x_velocity");CHKERRQ(ierr);
  ierr = DMDASetFieldName(da,1,"y_velocity");CHKERRQ(ierr);
  ierr = DMDASetFieldName(da,2,"Omega");CHKERRQ(ierr);
  ierr = DMDASetFieldName(da,3,"temperature");CHKERRQ(ierr);
     Create user context, set problem data, create vector data structures.
     Also, compute the initial guess.
     Create nonlinear solver context
  ierr = DMCreateLocalVector(da, &user.temp);CHKERRQ(ierr); // added by rlchen
  ierr = VecZeroEntries(user.temp);CHKERRQ(ierr); // added by rlchen
  ierr = DMSetApplicationContext(da,&user);CHKERRQ(ierr);
  ierr = DMDASNESSetFunctionLocal(da,INSERT_VALUES,(PetscErrorCode (*)(DMDALocalInfo*,void*,void*,void*))FormFunctionLocal,&user);CHKERRQ(ierr);
  ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
  ierr = PetscPrintf(comm,"lid velocity = %g, prandtl # = %g, grashof # = %g\n",(double)user.lidvelocity,(double)user.prandtl,(double)user.grashof);CHKERRQ(ierr);
     Solve the nonlinear system
  ierr = DMCreateGlobalVector(da,&x);CHKERRQ(ierr);
  ierr = FormInitialGuess(&user,da,x);CHKERRQ(ierr);
  ierr = SNESSolve(snes,NULL,x);CHKERRQ(ierr);
  ierr = SNESGetIterationNumber(snes,&its);CHKERRQ(ierr);
  ierr = PetscPrintf(comm,"Number of SNES iterations = %D\n", its);CHKERRQ(ierr);
     Visualize solution
  if (user.draw_contours) {
    ierr = VecView(x,PETSC_VIEWER_DRAW_WORLD);CHKERRQ(ierr);
     Free work space.  All PETSc objects should be destroyed when they
     are no longer needed.
  ierr = VecDestroy(&x);CHKERRQ(ierr);
  ierr = VecDestroy(&user.temp);CHKERRQ(ierr); // added by rlchen
  ierr = DMDestroy(&da);CHKERRQ(ierr);
  ierr = SNESDestroy(&snes);CHKERRQ(ierr);
  ierr = PetscFinalize();
  return 0;
#undef __FUNCT__
#define __FUNCT__ "FormInitialGuess"
   FormInitialGuess - Forms initial approximation.
   Input Parameters:
   user - user-defined application context
   X - vector
   Output Parameter:
   X - vector
PetscErrorCode FormInitialGuess(AppCtx *user,DM da,Vec X)
  PetscInt       i,j,mx,xs,ys,xm,ym;
  PetscReal      grashof,dx;
  Field          **x;
  grashof = user->grashof;
  ierr = DMDAGetInfo(da,0,&mx,0,0,0,0,0,0,0,0,0,0,0);CHKERRQ(ierr);
  dx   = 1.0/(mx-1);
     Get local grid boundaries (for 2-dimensional DMDA):
       xs, ys   - starting grid indices (no ghost points)
       xm, ym   - widths of local grid (no ghost points)
  ierr = DMDAGetCorners(da,&xs,&ys,NULL,&xm,&ym,NULL);CHKERRQ(ierr);
     Get a pointer to vector data.
       - For default PETSc vectors, VecGetArray() returns a pointer to
         the data array.  Otherwise, the routine is implementation dependent.
       - You MUST call VecRestoreArray() when you no longer need access to
         the array.
  ierr = DMDAVecGetArray(da,X,&x);CHKERRQ(ierr);
     Compute initial guess over the locally owned part of the grid
     Initial condition is motionless fluid and equilibrium temperature
  for (j=ys; j<ys+ym; j++) {
    for (i=xs; i<xs+xm; i++) {
      x[j][i].u     = 0.0;
      x[j][i].v     = 0.0;
      x[j][i].omega = 0.0;
      x[j][i].temp  = (grashof>0)*i*dx;
     Restore vector
  ierr = DMDAVecRestoreArray(da,X,&x);CHKERRQ(ierr);
  return 0;
#undef __FUNCT__
#define __FUNCT__ "FormFunctionLocal"
PetscErrorCode FormFunctionLocal(DMDALocalInfo *info,Field **x,Field **f,void *ptr)
  AppCtx         *user = (AppCtx*)ptr;
  PetscInt       xints,xinte,yints,yinte,i,j;
  PetscReal      hx,hy,dhx,dhy,hxdhy,hydhx;
  PetscReal      grashof,prandtl,lid;
  PetscScalar    u,uxx,uyy,vx,vy,avx,avy,vxp,vxm,vyp,vym;
  prandtl = user->prandtl;
  lid     = user->lidvelocity;
     Define mesh intervals ratios for uniform grid.
     Note: FD formulae below are normalized by multiplying through by
     local volume element (i.e. hx*hy) to obtain coefficients O(1) in two dimensions.
    PetscScalar ***z; // added by rlchen
    ierr = DMDAVecGetArray(info->da,user->temp, &z);CHKERRQ(ierr); // added by rlchen
    ierr = DMDAVecRestoreArray(info->da,user->temp,&z);CHKERRQ(ierr); // added by rlchen
  dhx   = (PetscReal)(info->mx-1);  dhy = (PetscReal)(info->my-1);
  hx    = 1.0/dhx;                   hy = 1.0/dhy;
  hxdhy = hx*dhy;                 hydhx = hy*dhx;
  xints = info->xs; xinte = info->xs+info->xm; yints = info->ys; yinte = info->ys+info->ym;
  /* Test whether we are on the bottom edge of the global array */
  if (yints == 0) {
    j     = 0;
    yints = yints + 1;
    /* bottom edge */
    for (i=info->xs; i<info->xs+info->xm; i++) {
      f[j][i].u     = x[j][i].u;
      f[j][i].v     = x[j][i].v;
      f[j][i].omega = x[j][i].omega + (x[j+1][i].u - x[j][i].u)*dhy;
      f[j][i].temp  = x[j][i].temp-x[j+1][i].temp;
  /* Test whether we are on the top edge of the global array */
  if (yinte == info->my) {
    j     = info->my - 1;
    yinte = yinte - 1;
    /* top edge */
      f[j][i].u     = x[j][i].u - lid;
      f[j][i].omega = x[j][i].omega + (x[j][i].u - x[j-1][i].u)*dhy;
      f[j][i].temp  = x[j][i].temp-x[j-1][i].temp;
  /* Test whether we are on the left edge of the global array */
  if (xints == 0) {
    i     = 0;
    xints = xints + 1;
    /* left edge */
    for (j=info->ys; j<info->ys+info->ym; j++) {
      f[j][i].omega = x[j][i].omega - (x[j][i+1].v - x[j][i].v)*dhx;
      f[j][i].temp  = x[j][i].temp;
  /* Test whether we are on the right edge of the global array */
  if (xinte == info->mx) {
    i     = info->mx - 1;
    xinte = xinte - 1;
    /* right edge */
      f[j][i].omega = x[j][i].omega - (x[j][i].v - x[j][i-1].v)*dhx;
      f[j][i].temp  = x[j][i].temp - (PetscReal)(grashof>0);
  /* Compute over the interior points */
  for (j=yints; j<yinte; j++) {
    for (i=xints; i<xinte; i++) {
       convective coefficients for upwinding
      vx  = x[j][i].u; avx = PetscAbsScalar(vx);
      vxp = .5*(vx+avx); vxm = .5*(vx-avx);
      vy  = x[j][i].v; avy = PetscAbsScalar(vy);
      vyp = .5*(vy+avy); vym = .5*(vy-avy);
      /* U velocity */
      u         = x[j][i].u;
      uxx       = (2.0*u - x[j][i-1].u - x[j][i+1].u)*hydhx;
      uyy       = (2.0*u - x[j-1][i].u - x[j+1][i].u)*hxdhy;
      f[j][i].u = uxx + uyy - .5*(x[j+1][i].omega-x[j-1][i].omega)*hx;
      /* V velocity */
      u         = x[j][i].v;
      uxx       = (2.0*u - x[j][i-1].v - x[j][i+1].v)*hydhx;
      uyy       = (2.0*u - x[j-1][i].v - x[j+1][i].v)*hxdhy;
      f[j][i].v = uxx + uyy + .5*(x[j][i+1].omega-x[j][i-1].omega)*hy;
      /* Omega */
      u             = x[j][i].omega;
      uxx           = (2.0*u - x[j][i-1].omega - x[j][i+1].omega)*hydhx;
      uyy           = (2.0*u - x[j-1][i].omega - x[j+1][i].omega)*hxdhy;
      f[j][i].omega = uxx + uyy + (vxp*(u - x[j][i-1].omega) + vxm*(x[j][i+1].omega - u))*hy +
                      (vyp*(u - x[j-1][i].omega) + vym*(x[j+1][i].omega - u))*hx -
                      .5*grashof*(x[j][i+1].temp - x[j][i-1].temp)*hy;
      /* Temperature */
      u            = x[j][i].temp;
      uxx          = (2.0*u - x[j][i-1].temp - x[j][i+1].temp)*hydhx;
      uyy          = (2.0*u - x[j-1][i].temp - x[j+1][i].temp)*hxdhy;
      f[j][i].temp =  uxx + uyy  + prandtl*((vxp*(u - x[j][i-1].temp) + vxm*(x[j][i+1].temp - u))*hy +
                                            (vyp*(u - x[j-1][i].temp) + vym*(x[j+1][i].temp - u))*hx);
     Flop count (multiply-adds are counted as 2 operations)
  ierr = PetscLogFlops(84.0*info->ym*info->xm);CHKERRQ(ierr);
  PetscFunctionReturn(0);
#undef __FUNCT__
#define __FUNCT__ "NonlinearGS"
PetscErrorCode NonlinearGS(SNES snes, Vec X, Vec B, void *ctx)
  DMDALocalInfo  info;
  Field          **x,**b;
  Vec            localX, localB;
  DM             da;
  PetscInt       xints,xinte,yints,yinte,i,j,k,l;
  PetscInt       max_its,tot_its;
  PetscInt       sweeps;
  PetscReal      rtol,atol,stol;
  PetscScalar    fu, fv, fomega, ftemp;
  PetscScalar    dfudu;
  PetscScalar    dfvdv;
  PetscScalar    dfodu, dfodv, dfodo;
  PetscScalar    dftdu, dftdv, dftdt;
  PetscScalar    yu=0, yv=0, yo=0, yt=0;
  PetscScalar    bjiu, bjiv, bjiomega, bjitemp;
  PetscBool      ptconverged;
  PetscReal      pfnorm,pfnorm0,pynorm,pxnorm;
  AppCtx         *user = (AppCtx*)ctx;
  tot_its = 0;
  ierr    = SNESNGSGetTolerances(snes,&rtol,&atol,&stol,&max_its);CHKERRQ(ierr);
  ierr    = SNESNGSGetSweeps(snes,&sweeps);CHKERRQ(ierr);
  ierr    = SNESGetDM(snes,(DM*)&da);CHKERRQ(ierr);
  ierr    = DMGetLocalVector(da,&localX);CHKERRQ(ierr);
  if (B) {
    ierr = DMGetLocalVector(da,&localB);CHKERRQ(ierr);
     Scatter ghost points to local vector, using the 2-step process
        DMGlobalToLocalBegin(), DMGlobalToLocalEnd().
  ierr = DMGlobalToLocalBegin(da,X,INSERT_VALUES,localX);CHKERRQ(ierr);
  ierr = DMGlobalToLocalEnd(da,X,INSERT_VALUES,localX);CHKERRQ(ierr);
  if (B) {
    ierr = DMGlobalToLocalBegin(da,B,INSERT_VALUES,localB);CHKERRQ(ierr);
    ierr = DMGlobalToLocalEnd(da,B,INSERT_VALUES,localB);CHKERRQ(ierr);
  ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
  ierr = DMDAVecGetArray(da,localX,&x);CHKERRQ(ierr);
  if (B) {
    ierr = DMDAVecGetArray(da,localB,&b);CHKERRQ(ierr);
  /* looks like a combination of the formfunction / formjacobian routines */
  dhx   = (PetscReal)(info.mx-1);dhy   = (PetscReal)(info.my-1);
  xints = info.xs; xinte = info.xs+info.xm; yints = info.ys; yinte = info.ys+info.ym;
  /* Set the boundary conditions on the momentum equations */
  if (yints == 0) {
    j     = 0;
    yints = yints + 1;
    /* bottom edge */
    for (i=info.xs; i<info.xs+info.xm; i++) {
      if (B) {
        bjiu = b[j][i].u;
        bjiv = b[j][i].v;
      } else {
        bjiu = 0.0;
        bjiv = 0.0;
      x[j][i].u = 0.0 + bjiu;
      x[j][i].v = 0.0 + bjiv;
  if (yinte == info.my) {
    j     = info.my - 1;
    yinte = yinte - 1;
    /* top edge */
      if (B) {
        bjiu = b[j][i].u;
        bjiv = b[j][i].v;
      } else {
        bjiu = 0.0;
        bjiv = 0.0;
      x[j][i].u = lid + bjiu;
      x[j][i].v = bjiv;
  if (xints == 0) {
    i     = 0;
    xints = xints + 1;
    /* left edge */
    for (j=info.ys; j<info.ys+info.ym; j++) {
      if (B) {
        bjiu = b[j][i].u;
        bjiv = b[j][i].v;
      } else {
        bjiu = 0.0;
        bjiv = 0.0;
  if (xinte == info.mx) {
    i     = info.mx - 1;
    xinte = xinte - 1;
    /* right edge */
      if (B) {
        bjiu = b[j][i].u;
        bjiv = b[j][i].v;
      } else {
        bjiu = 0.0;
        bjiv = 0.0;
  for (k=0; k < sweeps; k++) {
    for (j=info.ys; j<info.ys + info.ym; j++) {
      for (i=info.xs; i<info.xs + info.xm; i++) {
        ptconverged = PETSC_FALSE;
        pfnorm0     = 0.0;
        pfnorm      = 0.0;
        fu          = 0.0;
        fv          = 0.0;
        fomega      = 0.0;
        ftemp       = 0.0;
        for (l = 0; l < max_its && !ptconverged; l++) {
          if (B) {
            bjiu     = b[j][i].u;
            bjiv     = b[j][i].v;
            bjiomega = b[j][i].omega;
            bjitemp  = b[j][i].temp;
          } else {
            bjiu     = 0.0;
            bjiv     = 0.0;
            bjiomega = 0.0;
            bjitemp  = 0.0;
          if (i != 0 && i != info.mx - 1 && j != 0 && j != info.my-1) {
            /* U velocity */
            u     = x[j][i].u;
            fu    = uxx + uyy - .5*(x[j+1][i].omega-x[j-1][i].omega)*hx - bjiu;
            dfudu = 2.0*(hydhx + hxdhy);
            /* V velocity */
            u     = x[j][i].v;
            fv    = uxx + uyy + .5*(x[j][i+1].omega-x[j][i-1].omega)*hy - bjiv;
            dfvdv = 2.0*(hydhx + hxdhy);
            /* Omega */
            u      = x[j][i].omega;
            fomega = uxx + uyy +  (vxp*(u - x[j][i-1].omega) + vxm*(x[j][i+1].omega - u))*hy +
                     .5*grashof*(x[j][i+1].temp - x[j][i-1].temp)*hy - bjiomega;
            /* convective coefficient derivatives */
            dfodo = 2.0*(hydhx + hxdhy) + ((vxp - vxm)*hy + (vyp - vym)*hx);
            if (PetscRealPart(vx) > 0.0) dfodu = (u - x[j][i-1].omega)*hy;
            else dfodu = (x[j][i+1].omega - u)*hy;
            if (PetscRealPart(vy) > 0.0) dfodv = (u - x[j-1][i].omega)*hx;
            else dfodv = (x[j+1][i].omega - u)*hx;
            /* Temperature */
            u     = x[j][i].temp;
            ftemp =  uxx + uyy  + prandtl*((vxp*(u - x[j][i-1].temp) + vxm*(x[j][i+1].temp - u))*hy +
                                           (vyp*(u - x[j-1][i].temp) + vym*(x[j+1][i].temp - u))*hx) - bjitemp;
            dftdt = 2.0*(hydhx + hxdhy) + prandtl*((vxp - vxm)*hy + (vyp - vym)*hx);
            if (PetscRealPart(vx) > 0.0) dftdu = prandtl*(u - x[j][i-1].temp)*hy;
            else dftdu = prandtl*(x[j][i+1].temp - u)*hy;
            if (PetscRealPart(vy) > 0.0) dftdv = prandtl*(u - x[j-1][i].temp)*hx;
            else dftdv = prandtl*(x[j+1][i].temp - u)*hx;
            /* invert the system:
             [ dfu / du     0        0        0    ][yu] = [fu]
             [     0    dfv / dv     0        0    ][yv]   [fv]
             [ dfo / du dfo / dv dfo / do     0    ][yo]   [fo]
             [ dft / du dft / dv     0    dft / dt ][yt]   [ft]
             by simple back-substitution
            yu = fu / dfudu;
            yv = fv / dfvdv;
            yo = fomega / dfodo;
            yt = ftemp / dftdt;
            yo = (fomega - (dfodu*yu + dfodv*yv)) / dfodo;
            yt = (ftemp - (dftdu*yu + dftdv*yv)) / dftdt;
            x[j][i].u     = x[j][i].u - yu;
            x[j][i].v     = x[j][i].v - yv;
            x[j][i].temp  = x[j][i].temp - yt;
            x[j][i].omega = x[j][i].omega - yo;
          if (i == 0) {
            fomega        = x[j][i].omega - (x[j][i+1].v - x[j][i].v)*dhx - bjiomega;
            ftemp         = x[j][i].temp - bjitemp;
            yo            = fomega;
            yt            = ftemp;
            x[j][i].omega = x[j][i].omega - fomega;
            x[j][i].temp  = x[j][i].temp - ftemp;
          if (i == info.mx - 1) {
            fomega        = x[j][i].omega - (x[j][i].v - x[j][i-1].v)*dhx - bjiomega;
            ftemp         = x[j][i].temp - (PetscReal)(grashof>0) - bjitemp;
            yo            = fomega;
            yt            = ftemp;
          if (j == 0) {
            fomega        = x[j][i].omega + (x[j+1][i].u - x[j][i].u)*dhy - bjiomega;
            ftemp         = x[j][i].temp-x[j+1][i].temp - bjitemp;
            yo            = fomega;
            yt            = ftemp;
          if (j == info.my - 1) {
            fomega        = x[j][i].omega + (x[j][i].u - x[j-1][i].u)*dhy - bjiomega;
            ftemp         = x[j][i].temp-x[j-1][i].temp - bjitemp;
            yo            = fomega;
            yt            = ftemp;
          tot_its++;
          pfnorm = PetscRealPart(fu*fu + fv*fv + fomega*fomega + ftemp*ftemp);
          pfnorm = PetscSqrtReal(pfnorm);
          pynorm = PetscRealPart(yu*yu + yv*yv + yo*yo + yt*yt);
          pfnorm = PetscSqrtReal(pynorm);
          pxnorm = PetscRealPart(x[j][i].u*x[j][i].u + x[j][i].v*x[j][i].v + x[j][i].omega*x[j][i].omega + x[j][i].temp*x[j][i].temp);
          pxnorm = PetscSqrtReal(pxnorm);
          if (l == 0) pfnorm0 = pfnorm;
          if (rtol*pfnorm0 > pfnorm ||
              atol > pfnorm ||
              pxnorm*stol > pynorm) ptconverged = PETSC_TRUE;
  ierr = DMDAVecRestoreArray(da,localX,&x);CHKERRQ(ierr);
  if (B) {
    ierr = DMDAVecRestoreArray(da,localB,&b);CHKERRQ(ierr);
  ierr = DMLocalToGlobalBegin(da,localX,INSERT_VALUES,X);CHKERRQ(ierr);
  ierr = DMLocalToGlobalEnd(da,localX,INSERT_VALUES,X);CHKERRQ(ierr);
  ierr = PetscLogFlops(tot_its*(84.0 + 41.0 + 26.0));CHKERRQ(ierr);
  if (B) {
    ierr = DMLocalToGlobalBegin(da,localB,INSERT_VALUES,B);CHKERRQ(ierr);
    ierr = DMLocalToGlobalEnd(da,localB,INSERT_VALUES,B);CHKERRQ(ierr);
  ierr = DMRestoreLocalVector(da,&localX);CHKERRQ(ierr);
  if (B) {
    ierr = DMRestoreLocalVector(da,&localB);CHKERRQ(ierr);
