[petsc-users] NASM FormFunctionLocal
Rongliang Chen
rongliang.chan at gmail.com
Sat May 30 05:05:31 CDT 2015
Hi there,
I am trying to use NASM to solve a nonlinear problem. In my
FormFunctionLocal, I need to call DMDAVecGetArray(da, myvec, z). For the
"-da_overlap 0" case, the code works fine.
For the "-da_overlap 1" case, when I use the vector "myvec" created by
DMCreateLocalVector, it works fine. But if I use the vector "myvec" created
by DMCreateGlobalVector, I got the error messages:
[6]Arguments are incompatible
[6]PETSC ERROR: Vector local size 597870 is not compatible with DMDA local
sizes 619528 664392
And when I switch to "-da_overlap 2", both of the global and local version
of "mrvec" got error messages:
[10]PETSC ERROR: Arguments are incompatible
[10]PETSC ERROR: Vector local size 589680 is not compatible with DMDA local
sizes 633144 678680
[3]PETSC ERROR: Arguments are incompatible
[3]PETSC ERROR: Vector local size 619528 is not compatible with DMDA local
sizes 650256 696540
Can any one tell me how to use DMDAVecGetArray in FormFunctionLocal for
NASM? Thanks.
Best regards,
Rongliang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150530/95f3c7b3/attachment.html>
