[petsc-users] Multigrid preconditioner parameters
Feng Xing snakexf at gmail.com
Fri May 29 14:44:21 CDT 2015
Hello,
Thank you for replying so quick.
It’s a variation of 3d Poisson equation ( -Delta u=f, u is unknown, f is a given function ). Mathematically, they have similar properties.  So, I didn’t precise the details to make it look like too complicated. Numerically, the discretisation is by the standard finite element method or the finite volume method.
Feng Xing
Postdoc Inria, France
> On 29 May 2015, at 21:17, Jed Brown <jed at jedbrown.org> wrote:
> Feng Xing <snakexf at gmail.com> writes:
>> I want to use the the multigrid preconditioner in Petsc/hypre library
>> to a finite element elliptic problem. But there are a lot of
>> parameters. I would to ask if some of them are important for the
>> convergence and the computation time.
> Yes, some of them are important.  We can't comment without further
> information on your problem, but custom tuning of solvers for each
> problem encountered by each user is not scalable for the PETSc
> developers, so we recommend that you consult the Hypre manual (if you're
> using Hypre) and experiment with the usual tuning parameters (e.g., the
> "strong threshold" discussed in the manual).  When you have more
> experience with the problem you're solving and the behavior of the
> parameters, feel free to write with more specific questions.
