[petsc-users] MUMPS error and superLU error
    venkatesh g
    venkateshgk.j at gmail.com
    Fri May 29 12:16:25 CDT 2015
Hi Matt, users,
Thanks for the info. Do you also use Petsc and Slepc with MUMPS ? I get
into the segmentation error if I increase my matrix size.
Can you suggest other software for direct solver for QR in parallel since
as LU may not be good for a singular B matrix in Ax=lambda Bx ? I am
attaching the working version mumps log.
My matrix size here is around 47000x47000. If I am not wrong, the memory
usage per core is 272MB.
Can you tell me if I am wrong ? or really if its light on memory for this
matrix ?
Thanks
cheers,
Venkatesh
On Fri, May 29, 2015 at 4:00 PM, Matt Landreman <matt.landreman at gmail.com>
wrote:
> Dear Venkatesh,
> As you can see in the error log, you are now getting a segmentation fault,
> which is almost certainly a separate issue from the info(1)=-9 memory
> problem you had previously. Here is one idea which may or may not help.
> I've used mumps on the NERSC Edison system, and I found that I sometimes
> get segmentation faults when using the default Intel compiler. When I
> switched to the cray compiler the problem disappeared. So you could perhaps
> try a different compiler if one is available on your system.
> Matt
> On May 29, 2015 4:04 AM, "venkatesh g" <venkateshgk.j at gmail.com> wrote:
>> Hi Matt,
>> I did what you told and read the manual of that CNTL parameters. I solve
>> for that with CNTL(1)=1e-4. It is working.
>> But it was a test matrix with size 46000x46000. Actual matrix size is
>> 108900x108900 and will increase in the future.
>> I get this error of memory allocation failed. And the binary matrix size
>> of A is 20GB and B is 5 GB.
>> Now I submit this in 240 processors each 4 GB RAM and also in 128
>> Processors with total 512 GB RAM.
>> In both the cases, it fails with the following error like memory is not
>> enough. But for 90000x90000 size it had run serially in Matlab with <256 GB
>> RAM.
>> Kindly let me know.
>> Venkatesh
>> On Tue, May 26, 2015 at 8:02 PM, Matt Landreman <matt.landreman at gmail.com
>> > wrote:
>>> Hi Venkatesh,
>>> I've struggled a bit with mumps memory allocation too.  I think the
>>> behavior of mumps is roughly the following. First, in the "analysis step",
>>> mumps computes a minimum memory required based on the structure of nonzeros
>>> in the matrix.  Then when it actually goes to factorize the matrix, if it
>>> ever encounters an element smaller than CNTL(1) (default=0.01) in the
>>> diagonal of a sub-matrix it is trying to factorize, it modifies the
>>> ordering to avoid the small pivot, which increases the fill-in (hence
>>> memory needed).  ICNTL(14) sets the margin allowed for this unanticipated
>>> fill-in.  Setting ICNTL(14)=200000 as in your email is not the solution,
>>> since this means mumps asks for a huge amount of memory at the start.
>>> Better would be to lower CNTL(1) or (I think) use static pivoting
>>> (CNTL(4)).  Read the section in the mumps manual about these CNTL
>>> parameters. I typically set CNTL(1)=1e-6, which eliminated all the
>>> INFO(1)=-9 errors for my problem, without having to modify ICNTL(14).
>>> Also, I recommend running with ICNTL(4)=3 to display diagnostics. Look
>>> for the line in standard output that says "TOTAL     space in MBYTES for IC
>>> factorization".  This is the amount of memory that mumps is trying to
>>> allocate, and for the default ICNTL(14), it should be similar to matlab's
>>> need.
>>> Hope this helps,
>>> -Matt Landreman
>>> University of Maryland
>>> On Tue, May 26, 2015 at 10:03 AM, venkatesh g <venkateshgk.j at gmail.com>
>>> wrote:
>>>> I posted a while ago in MUMPS forums but no one seems to reply.
>>>> I am solving a large generalized Eigenvalue problem.
>>>> I am getting the following error which is attached, after giving the
>>>> command:
>>>> /cluster/share/venkatesh/petsc-3.5.3/linux-gnu/bin/mpiexec -np 64
>>>> -hosts compute-0-4,compute-0-6,compute-0-7,compute-0-8 ./ex7 -f1 a72t -f2
>>>> b72t -st_type sinvert -eps_nev 3 -eps_target 0.5 -st_ksp_type preonly
>>>> -st_pc_type lu -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14
>>>> 200000
>>>> IT IS impossible to allocate so much memory per processor.. it is
>>>> asking like around 70 GB per processor.
>>>> A serial job in MATLAB for the same matrices takes < 60GB.
>>>> After trying out superLU_dist, I have attached the error there also
>>>> (segmentation error).
>>>> Kindly help me.
>>>> Venkatesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150529/49452c18/attachment-0001.html>
Generalized eigenproblem stored in file.
 Reading COMPLEX matrices from binary files...
Entering ZMUMPS driver with JOB, N, NZ =   1       46656              0
 ZMUMPS 4.10.0
L U Solver for unsymmetric matrices
Type of parallelism: Working host
 ****** ANALYSIS STEP ********
 ** Max-trans not allowed because matrix is distributed
 ... Structural symmetry (in percent)=   75
 Density: NBdense, Average, Median   =    0 6488 5186
 Ordering based on METIS
 A root of estimated size        17063  has been selected for Scalapack.
Leaving analysis phase with  ...
INFOG(1)                                       =               0
INFOG(2)                                       =               0
 -- (20) Number of entries in factors (estim.) =       987031396
 --  (3) Storage of factors  (REAL, estimated) =      1059159558
 --  (4) Storage of factors  (INT , estimated) =         9996429
 --  (5) Maximum frontal size      (estimated) =           17063
 --  (6) Number of nodes in the tree           =             226
 -- (32) Type of analysis effectively used     =               1
 --  (7) Ordering option effectively used      =               5
ICNTL(6) Maximum transversal option            =               0
ICNTL(7) Pivot order option                    =               7
Percentage of memory relaxation (effective)    =              35
Number of level 2 nodes                        =             209
Number of split nodes                          =              12
RINFOG(1) Operations during elimination (estim)=   1.182D+13
Distributed matrix entry format (ICNTL(18))    =               3
 ** Rank of proc needing largest memory in IC facto        :         0
 ** Estimated corresponding MBYTES for IC facto            :      6275
 ** Estimated avg. MBYTES per work. proc at facto (IC)     :      1478
 ** TOTAL     space in MBYTES for IC factorization         :    177411
 ** Rank of proc needing largest memory for OOC facto      :         0
 ** Estimated corresponding MBYTES for OOC facto           :      6345
 ** Estimated avg. MBYTES per work. proc at facto (OOC)    :      1484
 ** TOTAL     space in MBYTES for OOC factorization        :    178120
Entering ZMUMPS driver with JOB, N, NZ =   2       46656      241356672
 ****** FACTORIZATION STEP ********
 GLOBAL STATISTICS PRIOR NUMERICAL FACTORIZATION ...
 NUMBER OF WORKING PROCESSES              =         120
 OUT-OF-CORE OPTION (ICNTL(22))           =           0
 REAL SPACE FOR FACTORS                   =  1059159558
 INTEGER SPACE FOR FACTORS                =     9996429
 MAXIMUM FRONTAL SIZE (ESTIMATED)         =       17063
 NUMBER OF NODES IN THE TREE              =         226
 Convergence error after scaling for ONE-NORM (option 7/8)   = 0.93D+00
 Maximum effective relaxed size of S              =   305345800
 Average effective relaxed size of S              =    29225972
 REDISTRIB: TOTAL DATA LOCAL/SENT         =    71295798   -58336695
 GLOBAL TIME FOR MATRIX DISTRIBUTION       =     41.2996
 ** Memory relaxation parameter ( ICNTL(14)  )            :        35
 ** Rank of processor needing largest memory in facto     :         0
 ** Space in MBYTES used by this processor for facto      :      6275
 ** Avg. Space in MBYTES per working proc during facto    :      1478
 ELAPSED TIME FOR FACTORIZATION           =    138.3655
 Maximum effective space used in S   (KEEP8(67)   =   118089792
 Average effective space used in S   (KEEP8(67)   =    17422614
 ** EFF Min: Rank of processor needing largest memory :         0
 ** EFF Min: Space in MBYTES used by this processor   :      3310
 ** EFF Min: Avg. Space in MBYTES per working proc    :      1289
 GLOBAL STATISTICS
 RINFOG(2)  OPERATIONS IN NODE ASSEMBLY   = 3.060D+10
 ------(3)  OPERATIONS IN NODE ELIMINATION= 1.164D+13
 INFOG (9)  REAL SPACE FOR FACTORS        =   980699854
 INFOG(10)  INTEGER SPACE FOR FACTORS     =     9059190
 INFOG(11)  MAXIMUM FRONT SIZE            =       17063
 INFOG(29)  NUMBER OF ENTRIES IN FACTORS  =   689553885
 INFOG(12) NB OF OFF DIAGONAL PIVOTS      =           4
 INFOG(13)  NUMBER OF DELAYED PIVOTS      =           1
 INFOG(14)  NUMBER OF MEMORY COMPRESS     =         782
 KEEP8(108) Extra copies IP stacking      =           0
Entering ZMUMPS driver with JOB, N, NZ =   3       46656      241356672
 ****** SOLVE & CHECK STEP ********
 STATISTICS PRIOR SOLVE PHASE     ...........
 NUMBER OF RIGHT-HAND-SIDES                    =           1
 BLOCKING FACTOR FOR MULTIPLE RHS              =           1
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ** Rank of processor needing largest memory in solve     :         0
 ** Space in MBYTES used by this processor for solve      :      5105
 ** Avg. Space in MBYTES per working proc during solve    :       626
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           1
  --- (30)                                     =           0
 Number of iterations of the method: 10
 Number of linear iterations of the method: 99
 Solution method: krylovschur
 Number of requested eigenvalues: 3
 Stopping condition: tol=1e-08, maxit=5184
 Number of converged approximate eigenpairs: 9
           k          ||Ax-kBx||/||kx||
 -0.010645+0.000000 i      1.78065
 -0.010672-0.000000 i     0.358554
 -0.011290+0.000000 i     0.360215
 -0.011517+0.000000 i    0.0574819
 -0.012048-0.000000 i    0.0545338
 -0.014239-0.000000 i   0.00326724
 -0.018303-0.000000 i    0.0152795
 -0.024691-0.000000 i   0.00253268
 -0.033922-0.000000 i    0.0041931
Entering ZMUMPS driver with JOB, N, NZ =  -2       46656      241356672
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./ex7 on a linux-intel named nid01404 with 120 processors, by esdveng Thu May 28 06:00:20 2015
Using Petsc Release Version 3.5.3, Jan, 31, 2015
                         Max       Max/Min        Avg      Total
Time (sec):           2.872e+03      1.00001   2.872e+03
Objects:              1.030e+02      1.01980   1.017e+02
Flops:                1.921e+09     80.08812   5.266e+08  6.320e+10
Flops/sec:            6.691e+05     80.08753   1.834e+05  2.201e+07
Memory:               2.726e+08     79.01630              1.576e+10
MPI Messages:         5.523e+03     21.12046   2.531e+03  3.038e+05
MPI Message Lengths:  2.432e+09   1394.39160   1.845e+04  5.603e+09
MPI Reductions:       3.023e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 2.8715e+03 100.0%  6.3197e+10 100.0%  3.038e+05 100.0%  1.845e+04      100.0%  3.022e+03 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer       1 1.0 1.0540e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
ThreadCommBarrie       1 1.0 4.0531e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult              117 1.0 2.7497e+00124.8 1.90e+09937.7 1.1e+05 5.8e+03 0.0e+00  0 96 37 12  0   0 96 37 12  0 22023
MatSolve              99 1.0 8.6172e+01 1.0 0.00e+00 0.0 1.7e+05 6.3e+02 1.0e+02  3  0 57  2  3   3  0 57  2  3     0
MatLUFactorSym         1 1.0 2.5466e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 89  0  0  0  0  89  0  0  0  0     0
MatLUFactorNum         1 1.0 1.8082e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
MatConvert             1 1.0 1.2173e-01 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       3 1.0 3.8287e+0110.8 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatAssemblyEnd         3 1.0 4.6185e+00 1.0 0.00e+00 0.0 1.6e+04 7.1e+02 4.2e+01  0  0  5  0  1   0  0  5  0  1     0
MatGetRow            778 1.0 5.5872e-0215.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 1.4498e-03160.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 3.1960e-03 7.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLoad                2 1.0 4.7483e+01 1.0 0.00e+00 0.0 9.0e+03 5.4e+05 4.6e+01  2  0  3 86  2   2  0  3 86  2     0
MatAXPY                1 1.0 5.2885e+00 1.0 0.00e+00 0.0 7.9e+03 7.1e+02 2.2e+01  0  0  3  0  1   0  0  3  0  1     0
VecNorm               18 1.0 8.2703e-03 2.0 5.60e+04 1.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  1   0  0  0  0  1   812
VecCopy               20 1.0 1.8883e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               113 1.0 7.5676e-03 9.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 6.5203e-03 1.3 2.80e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   515
VecScatterBegin      315 1.0 9.9498e-02 7.1 0.00e+00 0.0 2.8e+05 2.7e+03 9.9e+01  0  0 93 14  3   0  0 93 14  3     0
VecScatterEnd        216 1.0 2.0806e-0141.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
EPSSetUp               1 1.0 2.7329e+03 1.0 0.00e+00 0.0 7.9e+03 7.1e+02 6.7e+01 95  0  3  0  2  95  0  3  0  2     0
EPSSolve               1 1.0 2.8219e+03 1.0 1.62e+0974.8 2.6e+05 2.1e+03 2.8e+03 98 72 85 10 93  98 72 85 10 93    16
STSetUp                1 1.0 2.7329e+03 1.0 0.00e+00 0.0 7.9e+03 7.1e+02 4.6e+01 95  0  3  0  2  95  0  3  0  2     0
STApply               99 1.0 8.8469e+01 1.0 1.60e+09 0.0 2.5e+05 2.2e+03 3.0e+02  3 68 82 10 10   3 68 82 10 10   488
STMatSolve            99 1.0 8.8451e+01 1.0 0.00e+00 0.0 1.7e+05 6.3e+02 3.0e+02  3  0 57  2 10   3  0 57  2 10     0
BVCopy                19 1.0 1.1969e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 5.6e+01  0  0  0  0  2   0  0  0  0  2     0
BVMult               205 1.0 4.4088e-02 1.1 1.32e+07 1.0 0.0e+00 0.0e+00 3.9e+02  0  3  0  0 13   0  3  0  0 13 35896
BVDot                194 1.0 7.7536e-02 1.2 8.59e+06 1.0 0.0e+00 0.0e+00 1.9e+02  0  2  0  0  6   0  2  0  0  6 13281
BVOrthogonalize      100 1.0 1.9655e-01 1.0 1.66e+07 1.0 0.0e+00 0.0e+00 1.6e+03  0  3  0  0 51   0  3  0  0 51 10110
BVScale              100 1.0 6.5482e-03 1.1 1.56e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2850
BVSetRandom            1 1.0 7.0076e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSSolve               10 1.0 3.2166e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSVectors             20 1.0 3.5219e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSOther               10 1.0 1.0614e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSetUp               1 1.0 9.0599e-06 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              99 1.0 8.8438e+01 1.0 0.00e+00 0.0 1.7e+05 6.3e+02 3.0e+02  3  0 57  2 10   3  0 57  2 10     0
PCSetUp                1 1.0 2.7275e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01 95  0  0  0  1  95  0  0  0  1     0
PCApply               99 1.0 8.6174e+01 1.0 0.00e+00 0.0 1.7e+05 6.3e+02 1.0e+02  3  0 57  2  3   3  0 57  2  3     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     3              2         1504     0
              Matrix    17             17      3542976     0
              Vector    54             54      1459280     0
      Vector Scatter     6              6         7200     0
           Index Set    13             13       122048     0
Eigenvalue Problem Solver     1              1         2156     0
         PetscRandom     1              1          648     0
  Spectral Transform     1              1          840     0
       Basis Vectors     1              1        10744     0
              Region     1              1          648     0
       Direct solver     1              1        25272     0
       Krylov Solver     1              1         1160     0
      Preconditioner     1              1         1096     0
Average time to get PetscTime(): 1.19209e-07
Average time for MPI_Barrier(): 2.94209e-05
Average time for zero size MPI_Send(): 1.11659e-06
#PETSc Option Table entries:
-eps_nev 3
-eps_target 0.5
-f1 a72t
-f2 b72t
-log_summary
-mat_mumps_cntl_1 1e-6
-mat_mumps_icntl_4 2
-st_pc_type lu
-st_type sinvert
#End of PETSc Option Table entries
Compiled with FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 16 sizeof(PetscInt) 4
Configure options: --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 PETSC_ARCH=linux-intel -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140 --with-scalar-type=complex --with-fortran-kernels=1 -known-mpi-shared-libraries=0 --with-large-file-io=1 --with-64-bit-indices=0 --with-batch FC=ifort --with-valgrind-dir=/home/proj/14/esdveng/apps/valgrind-3.10.1 --download-mumps=/home/proj/14/esdveng/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/home/proj/14/esdveng/apps/scalapack-2.0.2.tgz --download-blacs=/home/proj/14/esdveng/apps/blacs-dev.tar.gz --download-parmetis=/home/proj/14/esdveng/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/home/proj/14/esdveng/apps/metis-5.0.2-p3.tar.gz --download-cmake=/home/proj/14/esdveng/apps/cmake-2.8.12.2.tar.gz
Libraries compiled on Tue May 19 06:39:06 2015 on login4
Machine characteristics: Linux-3.0.101-0.31.1_1.0502.8394-cray_ari_s-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /mnt/lustre/esd2/esdveng/petsc-3.5.3
Using PETSc arch: linux-intel
Using C compiler: gcc  -fPIC -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: ifort  -fPIC -g   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/mnt/lustre/esd2/esdveng/petsc-3.5.3/linux-intel/include -I/mnt/lustre/esd2/esdveng/petsc-3.5.3/include -I/mnt/lustre/esd2/esdveng/petsc-3.5.3/include -I/mnt/lustre/esd2/esdveng/petsc-3.5.3/linux-intel/include -I/opt/cray/mpt/7.0.5/gni/mpich2-intel/140/include
Using C linker: gcc
Using Fortran linker: ifort
Using libraries: -Wl,-rpath,/mnt/lustre/esd2/esdveng/petsc-3.5.3/linux-intel/lib -L/mnt/lustre/esd2/esdveng/petsc-3.5.3/linux-intel/lib -lpetsc -Wl,-rpath,/mnt/lustre/esd2/esdveng/petsc-3.5.3/linux-intel/lib -L/mnt/lustre/esd2/esdveng/petsc-3.5.3/linux-intel/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lparmetis -lmetis -lX11 -lpthread -lssl -lcrypto -Wl,-rpath,/opt/cray/mpt/7.0.5/gni/mpich2-intel/140/lib -L/opt/cray/mpt/7.0.5/gni/mpich2-intel/140/lib -lmpich -lssl -luuid -lpthread -lrt -ldl -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/4.3 -L/usr/lib64/gcc/x86_64-suse-linux/4.3 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/ipp/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/tbb/lib/intel64/gcc4.1 -L/opt/intel/composer_xe_2015.1.133/tbb/lib/intel64/gcc4.1 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -lm -lstdc++ -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/4.3 -L/usr/lib64/gcc/x86_64-suse-linux/4.3 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/ipp/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/tbb/lib/intel64/gcc4.1 -L/opt/intel/composer_xe_2015.1.133/tbb/lib/intel64/gcc4.1 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/4.3 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/tbb/lib/intel64/gcc4.1 -Wl,-rpath,/usr/x86_64-suse-linux/lib -lstdc++ -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/4.3 -L/usr/lib64/gcc/x86_64-suse-linux/4.3 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/ipp/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/tbb/lib/intel64/gcc4.1 -L/opt/intel/composer_xe_2015.1.133/tbb/lib/intel64/gcc4.1 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -ldl -lgcc_s -ldl
Application 407926 resources: utime ~342719s, stime ~1191s, Rss ~7065700, inblocks ~12131942, outblocks ~35052
