[petsc-users] Copy solution and function from one SNES to another
Harshad Sahasrabudhe
hsahasra at purdue.edu
Thu May 28 00:34:08 CDT 2015
I'm trying to copy the solution and functions vecs from a Newton SNES to a
Shell SNES. I'm doing it like this:
SNES newton_snes, shell_snes;
Vec newton_function, newton_solution;
Vec shell_function, shell_solution;
Newton SNES initialized and solved here. Shell SNES initialized.
SNESGetFunction(newton_snes, &newton_function, 0, 0);
SNESGetFunction(shell_snes, &shell_function, 0, 0);
VecDestroy(&shell_function);
VecDuplicate(newton_function, &shell_function);
SNESGetSolution(newton_snes, &newton_solution);
SNESGetSolution(shell_snes, &shell_solution);
VecDestroy(&shell_solution);
VecDuplicate(newton_solution, &shell_solution);
But I get this error on first VecDuplicate line:
[0]PETSC ERROR: VecDuplicate() line 511 in
/home/hsahasra/NEMO5/libs/petsc/build-real/src/vec/vec/interface/vector.c
Null Object: Parameter # 1
Is there any other better way to do this?
Harshad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150528/fb438457/attachment.html>
