[petsc-users] error using GetType in FORTRAN
Mark Adams mfadams at lbl.gov
Wed May 27 14:15:18 CDT 2015
FYI, this does not seem to be fixed.
On Sat, Apr 18, 2015 at 5:49 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Looks like a bunch of these things are missing from
> lib/petsc/conf/bfort-petsc.txt  it should be listed under native
>   Barry
> > On Apr 17, 2015, at 4:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > Does bfort have to be told that PCCompositeType is an enum?
> >    Matt "bfort's biggest fan"
> > On Fri, Apr 17, 2015 at 4:37 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > It looks like fieldsplitf.c has an extra PetscToPointer.  type is
> already a pointer:
> > PETSC_EXTERN void PETSC_STDCALL  pcfieldsplitgettype_(PC
> pc,PCCompositeType *type, int *__ierr ){
> > *__ierr = PCFieldSplitGetType(
> >     (PC)PetscToPointer((pc) ),
> >     (PCCompositeType* )PetscToPointer((type) ));
> > On Fri, Apr 17, 2015 at 4:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    Likely need to run in the debugger to see what generates the error.
> Perhaps a missing ierr?
> > Barry
> > > On Apr 17, 2015, at 9:10 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > I declare
> > >   PCCompositeType::pcctype
> > > But PCFieldSplitGetType does not seem to like it?
> > > Mark
> > > [1]PETSC ERROR: --------------------- Error Message
> > > [1]PETSC ERROR: Invalid pointer
> > > [1]PETSC ERROR: Invalid Pointer to Int: Parameter # 2
> > > [1]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > > [1]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2702-g1f714da
> GIT Date: 2015-04-16 11:32:06 -0500
> > > [1]PETSC ERROR: ../../XGC1_3/xgc-em on a arch-macosx-gnu-g named
> MacBook-Pro.local by markadams Fri Apr 17 10:06:09 2015
> > > [1]PETSC ERROR: Configure options --download-hypre=1 --download-p4est
> --download-superlu=1 --download-mumps --download-scalapack
> --download-superlu_dist=1 --download-parmetis=1 --download-metis=1
> --download-triangle=1 --with-hdf5-dir=/Users/markadams/Codes/hdf5
> --with-x=0 --with-debugging=1 PETSC_ARCH=arch-macosx-gnu-g
> > > [1]PETSC ERROR: #1 PCFieldSplitGetType() line 2046 in
> /Users/markadams/Codes/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150528/a6972b78/attachment.html>
