[petsc-users] SNESNRICHARDSON with LibMesh
Harshad Sahasrabudhe hsahasra at purdue.edu
Wed May 27 12:22:46 CDT 2015
Hi Matt,
Thanks for your comments. I see that SNESNRICHARDSON has changed a lot from
3.4.3 to 3.5.3. What do I need to do to make the code compatible with both
3.4.3 and 3.5.3?
Harshad
On Tue, May 26, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 26, 2015 at 3:07 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu
> > wrote:
>> Hi Matt,
>> Actually I just checked, I don't need to re-init the preconditioner
>> LibMesh solver.
>> The wrapper is interfaced to the mesh and makes it easier to assemble the
>> system matrices. It also keeps track of constraints. The wrapper function PetscNonlinearSolver::solve
>> updates the system vectors and matrices, then calls SNESSolve. Thus, I
>> need to call PetscNonlinearSolver::solve instead of SNESSolve in
>> SNESApplyNPC.
>> Do you mean wrap it in SNESSHELL?
> Yes, exactly.
>   Thanks,
>      Matt
>> Thanks,
>> Harshad
>> On Tue, May 26, 2015 at 3:25 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, May 26, 2015 at 12:42 PM, Harshad Sahasrabudhe <
>>> hsahasra at purdue.edu> wrote:
>>>> Hi,
>>>> I'm using LibMesh for meshing a non-linear equation. I want to use
>>>> NRichardson non-linear solver to solve the equation. I have a Newton trust
>>>> region non-linear solver as a pre-conditioner. Both these SNES are created
>>>> via the LibMesh NonlinearImplicitSystem and PetscNonlinearSolver wrappers.
>>>> I need to re-init the LibMesh NonlinearImplicitSystem each time the
>>>> preconditioner is applied. Also, I need the preconditioner to be solved via
>>>> the LibMesh wrapper instead of directly through SNESSolve. How can make it
>>>> work this way? Any help is appreciated!
>>> I think the easiest way is to have them both look like SNES objects.
>>> Then you can just call SNESSetNPC() or use -snes_npc_side left
>>> -npc_snes_type newtonls
>>> Can you explain what the LibMesh wrapper is doing that you you need? We
>>> could wrap that object in a SNES, but it sounds
>>> simpler to me to unwrap it.
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Harshad
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150527/472aa819/attachment.html>
