[petsc-users] Installation error: C++ preprocessor
Gautam Bisht
gbisht at lbl.gov
Tue May 19 10:54:19 CDT 2015
For both, master and v3.5.3+Satish's patch, I get the C preprocessor error
related to installation of sowing. Attached below are log files.
-Gautam.
PS: My previous emails bounced, so I'm re-trying to send log files as tar
file.
On Tue, May 19, 2015 at 8:14 AM, Gautam Bisht <gbisht at lbl.gov> wrote:
> Please disregard the logfile in the last email. The correct ones are
> attached below.
> -Gautam.
>> error related to installation of sowing. Attached below are log files.
>> -Gautam.
>> On Mon, May 18, 2015 at 12:33 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> Can you try using petsc development branch 'master' and see if
>>> it works? It should also add in the c++ compiler to hdf5 configure..
>>> Wrt petsc-3.5 - perhaps the attached patch will work..
>>> Satish
>>> On Mon, 18 May 2015, Gautam Bisht wrote:
>>> > Attached below is the config.log for HDF5.
>>> > -Gautam.
>>> > On Mon, May 18, 2015 at 12:18 PM, Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>> > > On Mon, 18 May 2015, Matthew Knepley wrote:
>>> > > > On Mon, May 18, 2015 at 1:35 PM, Gautam Bisht <gbisht at lbl.gov>
>>> wrote:
>>> > > > > Hi,
>>> > > > > While trying to install v3.5.3 with intel 15.0.0 on a linux
>>> machine,
>>> > > I'm
>>> > > > > getting an error related to C++ preprocessor. Any help to
>>> resolve the
>>> > > issue
>>> > > > > would be greatly appreciated.
>>> > > > > Attached below is the logfile.
>>> > > > The HDF5 configure is failing because it says your preprocessor
>>> does not
>>> > > > work. We would need
>>> > > > to see
>>> /clusterfs/esd/esd2/gbisht/MODELS/petsc3.5.3/lrc-intel-2015-0-090-fort-debug/externalpackages/hdf5-1.8.10-patch1.1/config.log
>>> > > I think the issue is - hdf5 configure is looking for c++ compiler -
>>> > > but PETSc configure is not providing this info to hdf5 configure.
>>> > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150519/dba5bf58/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150519/dba5bf58/attachment-0001.bin>
