[petsc-users] DMPlex examples in parallel/3D?
Tue May 19 10:38:10 CDT 2015
On Tue, May 19, 2015 at 10:32 AM, Mark Lohry <mlohry at princeton.edu> wrote:
> Great thanks, I'll look more into this.
> Question on the dofs that wasn't clear from the manual - are the dofs on
> cells, faces, edges, and vertices *all* actual degrees of freedom /
> solution unknowns in the system to solve, or does one say the dofs on the
> cells represent actual solution unknowns, and face dofs are just things to
> be communicated for inter-cell flux computation? e.g. say i was doing the
> simplest cellwise-constant finite volume scheme for a scalar; do i have 1
> dof per cell, and zero dofs anywhere else?
There are many ways you could imagine structuring the data. The thing about
PetscSection is that is easily allows
you to pick any one of those.
In a FV example for PETSc, TS ex11, we choose to store only cell data. Then
in loops over the faces, you
  1) Call DMPlexGetSupport(dm, face, &cells) to get the two cells
  2) Call DMPlexGetPointGlobalRead(dm, cell[i], solArray, &val) to get the
cell data
>> You can easily get started by just calling DMPlexDistribute() on a serial
>> mesh.
> perfect, i'll start with that.
>> I do cG FEM in SNES ex12 and ex62.
> Great thanks, didn't see these linked from the DMPlex doc pages.
They are in the dev docs I believe.
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150519/246f97bf/attachment-0001.html>
