[petsc-users] Large Matrix eigenvalue problem : configuration
venkatesh g
venkateshgk.j at gmail.com
Sun May 17 02:02:16 CDT 2015
Thank you. So the single eigenvector's size which is Nx1 is the number of
unknowns and should be less than 2^31-1 so as to avoid configuring with
'--with-64-bit-indices=1' ??
On Sat, May 16, 2015 at 8:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, May 16, 2015 at 3:49 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
>> Hi,
>> I am trying to solving AX=lambda BX
>> A and B are of size 57000 x 57000
>> Currently I solve my small matrices using -st_type sinvert and -eps_nev 1
>> So I get 1 eigenvalue and eigenvector.
>> So for the 57000x57000 large matrix problem, the unknown eigenvector is
>> 57000x1
>> Should I configure the petsc as '--with-64-bit-indices=1' for this
>> problem ?
> It is not necessary.
> Matt
>> Is the unknowns being considered as the entire eigenspace 57000x57000 ?
>> kindly let me know.
>> Venkatesh
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150517/387f9c22/attachment.html>
