[petsc-users] SLEPc Bogus eigenvalues for large -eps_nev
Vijay Gopal Chilkuri
vijay.gopal.c at gmail.com
Fri May 15 08:00:04 CDT 2015
Yes, those seem to be the right eigenvalues.
Ok so the solution is to recompile PETSc/SLEPc with a basic configuration
and test with --with-debugging=1
Would it make a difference if I use *-esp_type lanczos *or some other
diagonalization procedure ?
I'll run the test with a new version of PETSc/SLEPc and report back.
Thanks a lot,
Vijay
On Fri, May 15, 2015 at 2:55 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 14/05/2015, a las 19:13, Vijay Gopal Chilkuri escribió:
> > oups sorry, I send you a smaller one (540540) this should finish in a
> few minutes.
> > It requires the same makefile and irpf90.a library.
> > so just replace the old problem.c file with this and it should compile.
> > Thanks again,
> > Vijay
> I was able to compute 300 eigenvalues of this matrix of size 540540. All
> eigenvalues are in the range -4.70811 .. -4.613807, and the associated
> residual is always below 1e-9.
> There must be something in your software configuration that is causing
> problems. I would suggest trying with a basic PETSc/SLEPc configuration,
> with no openmp flags, using --download-fblaslapack (instead of MKL). Also,
> although it should not make any difference, you may want to try with a
> smaller number of MPI processes (rather than 741).
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150515/72741c4d/attachment.html>
