[petsc-users] SLEPc Eigenvalue problem - Zero Pivot
venkatesh g
venkateshgk.j at gmail.com
Fri May 15 05:49:41 CDT 2015
'make test' was successful on the $PETSC_DIR.
I configured MUMPS, metis, parmetis, scalapack through
'--download-mumps=/path/MUMPS_4.10.0-p3.tar.gz' and etc..
I will anyway download the new version and start installing it now., Is it
due to some flag issue ? I have attached my makefile.
Venkatesh
On Fri, May 15, 2015 at 4:12 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 15/05/2015, a las 12:34, venkatesh g escribió:
> > Hi,
> > I configured and installed MUMPS along with PETSc and installed SLEPc.
> > Now I am trying to make the executable for ex7.c from SLEPc examples.
> > I am getting following errors while doing make:
> ../../petsc-3.3-p7/linux-gnu-intel-cmplx-batch/lib//libpetsc.a(mumps.c.o):
> In function `MatDestroy_MUMPS':
> /cluster/share/venkatesh/petsc-3.3-p7/src/mat/impls/aij/mpi/mumps/mumps.c:493:
> undefined reference to `zmumps_c'
> In function `MatSolve_MUMPS':
> /cluster/share/venkatesh/petsc-3.3-p7/src/mat/impls/aij/mpi/mumps/mumps.c:546:
> In function `MatFactorNumeric_MUMPS':
> /cluster/share/venkatesh/petsc-3.3-p7/src/mat/impls/aij/mpi/mumps/mumps.c:664:
> In function `PetscInitializeMUMPS':
> /cluster/share/venkatesh/petsc-3.3-p7/src/mat/impls/aij/mpi/mumps/mumps.c:799:
> In function `MatLUFactorSymbolic_AIJMUMPS':
> /cluster/share/venkatesh/petsc-3.3-p7/src/mat/impls/aij/mpi/mumps/mumps.c:896:
> ../../petsc-3.3-p7/linux-gnu-intel-cmplx-batch/lib//libpetsc.a(mumps.c.o):/cluster/share/venkatesh/petsc-3.3-p7/src/mat/impls/aij/mpi/mumps/mumps.c:974:
> more undefined references to `zmumps_c' follow
> ../../petsc-3.3-p7/linux-gnu-intel-cmplx-batch/lib//libpetsc.a(pmetis.c.o):
> In function `MatPartitioningApply_Parmetis':
> /cluster/share/venkatesh/petsc-3.3-p7/src/mat/partition/impls/pmetis/pmetis.c:101:
> undefined reference to `ParMETIS_V3_PartKway'
> In function `MatMeshToCellGraph':
> /cluster/share/venkatesh/petsc-3.3-p7/src/mat/partition/impls/pmetis/pmetis.c:360:
> undefined reference to `ParMETIS_V3_Mesh2Dual'
> > collect2: ld returned 1 exit status
> > make: *** [ex7] Error 1
> > Pls let me know what to do ?
> > Venkatesh
> Suggest upgrading to the latest PETSc/SLEPc, version 3.3 is almost 3-years
> old.
> Did 'make test' on $PETSC_DIR work?
> Did you install a standalone MUMPS yourself? Maybe it is better to let
> PETSc install it for you. In 3.5, run PETSc's configure with:
> --download-mumps --download-metis --download-parmetis --download-scalapack
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150515/fd1f38b0/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150515/fd1f38b0/attachment.obj>
