[petsc-users] Setting Pmat for an ASM subksp
Luc Berger-Vergiat
lb2653 at columbia.edu
Thu May 14 14:17:33 CDT 2015
Hi all,
I am using the ASM preconditioner and it works fine with regular options.
However I am having difficulties setting the Pmat operator for on of my
ASM domain.
Here is what I coded:
call PCASMSetLocalSubdomains(pcdd,2,isddi,isddi,ierr)
call PetscOptionsGetInt(PETSC_NULL_CHARACTER,
& '-n_overlap',n_ol,chk,ierr)
if (chk.eqv.PETSC_TRUE) then
call PCASMSetOverlap(pcdd,n_ol,ierr)
endif
call PCSetUp(pcdd,ierr)
call KSPSetUp(schurKSP,ierr)
call PCASMGetSubKSP(pcdd,nddl,fbl,ddsubksp, ierr)
do i = 1,nddl
if(i.eq.1) then
if( (nstep.eq.1).and.(niter.eq.0) ) then
call KSPGetOperators(ddsubksp(i),HKmat,
& HPmat,ierr)
else
& PETSC_NULL_OBJECT,ierr)
endif
call PetscObjectReference(HKmat, ierr)
call PetscObjectReference(HPmat, ierr)
call KSPSetOperators(ddsubksp(i),HKmat,HPmat,ierr)
call PetscObjectDereference(HKmat, ierr)
call PetscObjectDereference(HPmat, ierr)
endif
call KSPGetPC(ddsubksp(i),ddsubpc(i),ierr)
call PCSetType(ddsubpc(i),PCLU,ierr)
call KSPSetType(ddsubksp(i),KSPPREONLY,ierr)
enddo
I am suspecting that the PetscObjectReference is not working well based
on the following output from valgrind:
==24001== Invalid read of size 4
==24001== at 0x8EDC69: PetscObjectReference (in
/home/luc/research/feap_repo/ShearBands/parfeap/feap)
==24001== by 0x8F5778: petscobjectreference_ (in
==24001== by 0x4331A2: reuseschur_ (in
==24001== by 0x4297F5: feapuserpcapply_ (in
==24001== by 0xA3FB56: ourshellapply (in
==24001== by 0xD9BAE3: PCApply_Shell (in
==24001== by 0xD74AC3: PCApply (in
==24001== by 0xE0FE2D: KSPSolve_PREONLY (in
==24001== by 0xDFD7E3: KSPSolve (in
==24001== by 0xA41BEC: kspsolve_ (in
==24001== by 0x4288ED: usolve_ (in
==24001== by 0x460179: psolve_ (in
==24001== Address 0x802ea30 is 64 bytes inside a block of size 1,072 free'd
==24001== at 0x4C2BDEC: free (in
/usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==24001== by 0xA66C4C: PetscFreeAlign (in
==24001== by 0x95A5F6: MatDestroy (in
==24001== by 0x9672BC: MatDestroyMatrices (in
==24001== by 0xDDD221: PCReset_ASM (in
==24001== by 0xD73A26: PCReset (in
==24001== by 0xD73BB7: PCDestroy (in
==24001== by 0xDFFF53: KSPDestroy (in
==24001== by 0xA41C1F: kspdestroy_ (in
==24001== by 0x432F00: reuseschur_ (in
==24001==
==24001== by 0xD76924: PCSetOperators (in
==24001== by 0xE045DD: KSPSetOperators (in
==24001== by 0xA41B40: kspsetoperators_ (in
==24001== by 0x4331C4: reuseschur_ (in
==24001==
==24001== Invalid read of size 8
==24001== at 0x96999F: MatGetNullSpace (in
==24001== by 0xE0468C: KSPSetOperators (in
==24001== Address 0x802ed98 is 936 bytes inside a block of size 1,072
free'd
==24001==
==24001== at 0x8EDC90: PetscObjectDereference (in
==24001== by 0x8F5798: petscobjectdereference_ (in
==24001== by 0x4331EB: reuseschur_ (in
==24001== Address 0x802e9f8 is 8 bytes inside a block of size 1,072 free'd
==24001==
==24001== at 0x8EDC94: PetscObjectDereference (in
==24001== Address 0x10 is not stack'd, malloc'd or (recently) free'd
==24001==
Can you let me know how I should issue the PetscObejctReference
subroutine call?
If PetscObejctReference is not fully working in FORTRAN (that's always a
possibility), I assume that I cannot do the following:
call MatGetSubMatrix(Kmat, isddi(1), isddi(1),
MAT_INITIAL_MATRIX, DDPMat, ierr)
call KSPSetOperators(ddsubksp(i),DDPMat,DDPMat,ierr)
because of the overlap that is set after I computed issddi(1), is there
a way to get an updated isddi(1) that contain the overlap created by
PCASMSetOverlap?
Best,
Luc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/5219696c/attachment-0001.html>
