[petsc-users] SLEPc Eigenvalue problem - Zero Pivot
venkatesh g
venkateshgk.j at gmail.com
Thu May 14 12:34:33 CDT 2015
Actually krylovschur it is giving excellent results when my B matrix is not
singular.
This time my B matrix is large with very little non-zero entries. There are
entire rows and columns with zeros.
So other than MUMPS, which I will try now, is there another way ?
Venkatesh
On Thu, May 14, 2015 at 11:01 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> This has nothing to do with ARPACK.
> El 14/05/2015, a las 19:29, venkatesh g escribió:
> > I am trying to use ARPACK. will it help?
> > It is not linking Arpack however, when I give ./configure
> --with-arpack-dir=..... command from manual.
> > Venkatesh
> > On Thu, May 14, 2015 at 10:54 PM, Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > El 14/05/2015, a las 19:13, venkatesh g escribió:
> > > Hi,
> > > 1. I am not calling EPSSetFromOptions in source code. I am using the
> ex7.c given in the SLEPc webpage.
> > > 2. A-matrix is not singular. Only B is singular.
> > > 3. I will try with MUMPS.
> > > 4. Matrix sizes are same as in Matlab. If B is not singular it is
> giving same result as Matlab, but if B is singular it gives the zero pivot
> issue which Matlab doesnt give.
> > > So is there a way ?
> > The ex7.c example calls EPSSetFromOptions(). If it is not called, then
> command-line options are ignored.
> > It is strange that you get zero pivots when factoring A-sigma*B for
> different values of sigma. Try with MUMPS.
> > Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/85f0bf1a/attachment.html>
