[petsc-users] SLEPc Bogus eigenvalues for large -eps_nev
Vijay Gopal Chilkuri
vijay.gopal.c at gmail.com
Thu May 14 12:13:52 CDT 2015
oups sorry, I send you a smaller one (540540) this should finish in a few
minutes.
It requires the same makefile and irpf90.a library.
so just replace the old problem.c file with this and it should compile.
Thanks again,
Vijay
On Thu, May 14, 2015 at 7:04 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> Ok. I was able to build the code, but I need a small problem in order to
> be able to run without having to access a big supercomputer.
> Jose
> El 14/05/2015, a las 18:00, Vijay Gopal Chilkuri escribió:
> > Ok I've sent a job with the -eps_mpd 50 option and I still get the same
> absurd eigenvalues !
> > You already have the driver .c file (called problem.c I also attach this
> file) I send you the makefile.
> > The subroutine unit_l1_ is a fortran subroutine which gives the number
> of nonzero elements in 22 rows at once. This subroutine can be compiled in
> the following way.
> > Firstly, it uses the IRPF90 library.
> > You can download the library from this github link:
> https://github.com/scemama/irpf90.git
> > the binary needed "irpf90" should be in the bin directory, just update
> the relevant PATH environment variables.
> > Second, get the codes that generate the unit_l1_ subroutine from the
> following repository: https://github.com/v1j4y/slepc_version.git
> > please change to branch slepc_testing !
> > make
> > make irpf90.a
> > should give you the irpf90.a library nessessary to compile the problem.c
> file, I attach the makefile to compile the problem.c file with this mail.
> > To compile the final executable, please do "make problem"
> > and that should be enough !
> > sorry that it is not simpler.
> > Please write if you run into problems.
> > Thanks,
> > Vijay
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/cebfaa2e/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/cebfaa2e/attachment-0001.c>
