[petsc-users] Hypre + openMP
Matthew Knepley
knepley at gmail.com
Wed May 13 00:05:33 CDT 2015
On Wed, May 13, 2015 at 12:01 AM, Michele Rosso <mrosso at uci.edu> wrote:
> Thanks Matt,
> Could you give me an example of not-native partitioning? I have a cubic
> domain and a 3D domain decomposition. I use dmda3d to create the
> partitioning.
"naive", and I was talking about coarse grids. Coarse grids should be
partitioned onto fewer than P processes.
Matt
> Thanks,
> Michele
> On May 12, 2015 9:51 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
>> On Tue, May 12, 2015 at 11:41 PM, Michele Rosso <mrosso at uci.edu> wrote:
>>> Barry,
>>> thanks for your answer. The reason I'm asking is that multigrid limits
>>> the number of MPI tasks I can use for a given grid, since k multigrid
>>> levels require at least 2^(k-1) grid nodes per direction. I was wondering
>>> if using OpenMP together with MPI could help circumventing the problem. If
>>> you have any other suggestions, it would be greatly appreciated.
>> This is only for naive partitioning. Good AMG necks down the processor
>> set correctly, for example GAMG in PETSc.
>> Thanks,
>> Matt
>>> Best,
>>> Michele
>>> You could compile hypre yourself with the OpenMP feature turned on and
>>> then configure PETSc to use that version of hypre; of course the rest of
>>> the PETSc code would not utilize the OpenMP threads.
>>> Barry
>>> BTW: I don't know of any evidence that using hypre with OpenMP is
>>> superior to using hypre without so I aside from academic curiosity I don't
>>> think there would be a reason to do this.
>>> > On May 12, 2015, at 7:55 PM, Michele Rosso <mrosso at uci.edu> wrote:
>>> > Hi,
>>> > is it possible to use the openmp capabilities of hypre via petsc?
>>> > Thanks,
>>> > Michele
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150513/8e8a2d3e/attachment.html>
